Epoxy Fillet Tool
Posted: Thu Oct 25, 2018 2:00 pm
by Eric1
I just wanted to share these with the forum.
I've been using a short piece of 3/4" schedule 1120 PVC pipe to make my fillets.
This has an outside diameter of 1.05" (.525" radius) so it makes a great fillet for fiberglass.
Jacques specified a 1/2" radius and this works perfect except when you have to pull that radius in the corner like
when installing frames.
I looked on the internet for a ball tool to do this and found them. The thing is they were made from stainless and expensive.
Every one I found was over $40.00.
Here is my solution,. I machined a spherical ball end that matches the PVC. You just press this into a short section of PVC and your set.
This truly makes the task easier to do. If a larger size is needed (1.25") I can run them as well.
I'm sending samples to Jeff today.
I hope you all will want to have one!
Re: Epoxy Fillet Tool
Posted: Thu Oct 25, 2018 2:59 pm
by piperdown
Where's the action shot?!
Posted: Thu Oct 25, 2018 3:03 pm
by OrangeQuest
That is really a good idea. Any idea on the $$?
Posted: Thu Oct 25, 2018 3:40 pm
by Eric1
piperdown wrote: ↑Thu Oct 25, 2018 2:59 pm
In the morning.
OrangeQuest wrote: ↑Thu Oct 25, 2018 3:03 pm
That will be up to Jeff.
Posted: Thu Oct 25, 2018 3:43 pm
by BB Sig
Nice way to make your hobby part of the business! I bet that these would make the corners much nicer!
Posted: Thu Oct 25, 2018 4:20 pm
by Eric1
I shared this on several Facebook groups. You would not believe how many people have told me to just form a radius on a squeegee.
I can only take the horse to the water....
Posted: Thu Oct 25, 2018 6:37 pm
by Fuzz
I made up something similar but no where as nice.
Jeff please let us know if you do stock them.
Posted: Thu Oct 25, 2018 6:53 pm
by Jeff
Yes, Eric sent me a photo earlier today and is actually shipping me a few (UPS) today as well!! I think they are a great idea and will have them on the site soon!! Jeff
Posted: Thu Oct 25, 2018 7:57 pm
by fallguy1000
I use a washer on a stick.
I can cheat a bit if I am long or short on filler and I know what I can get away with.
Gonna be hard to compete with my price.
I gotta save every penny I have for Silvertip, right Jeff?
Posted: Thu Oct 25, 2018 9:03 pm
by Eric1
I don't intend to compete with you. It can be done your way. As much of the world wipes themselves with their hand, I get it, it works. I simply prefer paper.
Posted: Thu Oct 25, 2018 9:17 pm
by Jaysen
Y’all have TOOLS for this?
I just used my finger. I guess I need to discover paper...
Posted: Thu Oct 25, 2018 10:23 pm
by fallguy1000
His tool does have one potential great use.
Finishing fillets.
Posted: Thu Oct 25, 2018 10:31 pm
by Fuzz
Eric1 wrote: ↑Thu Oct 25, 2018 9:03 pm
Dang it buddy..............put a warning sign on stuff like this
Posted: Fri Oct 26, 2018 5:30 am
by OrangeQuest
We all have tools that we have found work best for the way we like to do some things but I am still on a quest to find that tool when it comes to "finish" fillets. One thing that Eric's tool will help is the angle you hold it is not that important so corners, double 90 degrees, will be cleaner that are hard for a lot of people. I can see using Eric's tool will keep me from flinging so much epoxy putty!
It does need a name and don't call it Eric's balls!
Posted: Fri Oct 26, 2018 5:34 am
by Eric1
OrangeQuest wrote: ↑Fri Oct 26, 2018 5:30 am
Dear God No!
Posted: Fri Oct 26, 2018 8:44 am
by topwater
I did my whole boat with a 1" wooden dowel that was epoxy coated and it worked great . That being said i think Eric's
tool would work better and i will buy one to use . Definitely would work better in the corners
Posted: Fri Oct 26, 2018 8:54 am
by Dr. Pete
Gem from the Port A plywood boat fest......The guys at Chesapeake Light craft have some CNC precut various radius tools to the smooth a fillet with. They then went over with a cloth lightly with rubbing alcohol. NOT ISOPROPYL. Left only a little edge on each side of the fillet and was smooth as a babies behind. Have not started my build or done it myself but was quit impressive. He went over with the alcohol after it was getting pretty close to set up. Dougster saw this together and he may have some input.
Posted: Fri Oct 26, 2018 10:44 am
by piperdown
Eric1 wrote: ↑Fri Oct 26, 2018 5:34 am
Dear God No!
Eric's Shiny Balls for help getting into tiny crevices!
Posted: Sun Nov 04, 2018 7:02 pm
by Dutch1
piperdown wrote: ↑Fri Oct 26, 2018 10:44 am
Dear God No!
Yikes, now that's funny! My brother mentioned using a "brass sealant spoon" that he uses on aircraft when he and I were talking about building boats. I haven't tried it but they are cheap. I've always just used my finger with a size small glove on to make the fillet nice and smooth.
Posted: Mon Nov 12, 2018 6:54 pm
by BB Sig
Dutch1 wrote: ↑Sun Nov 04, 2018 7:02 pm
How do you get a small glove on those hands?!
Posted: Sat Dec 01, 2018 11:03 am
by Dutch1
BB Sig wrote: ↑Mon Nov 12, 2018 6:54 pm
LOL, Where there's a will there's a way...
Normally, I use the xl gloves. We had a size small box at the house. I kept having trouble smoothing out the fillet with my finger due to the end of the glove having a crease. I thought a smaller glove would work and it does. But yes, it is tight and they will break easy. Now I just keep a box of small gloves around for that purpose.
Posted: Sat Dec 01, 2018 8:10 pm
by Aripeka Angler
I use a baby feeding spoon.
Posted: Fri Dec 07, 2018 12:38 pm
by cape_fisherman
Looks like something a 3D printer could knock out with no issues.
Posted: Fri Dec 07, 2018 12:50 pm
by lung
Check out Puppydrum's post in his old XF20 build. Used a brick mason's tool from Lowes. A couple bucks.
Posted: Fri Dec 07, 2018 2:29 pm
by OrangeQuest
You can get epoxy fillet tools in different sizes at art supply stores in the clay section and I found them in the cake decorating section too. Made of wood and plastic, I think I even seen them in metal. I was looking for powdered pigment to add to epoxy so didn't really pay much attention.
Posted: Sun Feb 10, 2019 11:00 pm
by Jwhitakeriii
Did these ever make production. I haven't seen them on the website to buy?
Posted: Mon Feb 11, 2019 3:03 am
by Eric1
No, I found them to be problematic.
