Homemade wooden pushpits?
Re: Homemade wooden pushpits?
Thanks for the info in the white oak. Both tillers are works of art.
Hi,
I made my tiller out of the okoume marine ply cut outs of the keel and laminated them the same way as the keel and then shaped it.
Rudder and tiller finished
That was on my boat building the best usage of plywood which I would have otherwise thrown away.
Maybe Tony could let us know what cover ( see through ? ) he has for his tiller and is it also on the tiller whilst sailing ? I have varnished my tiller and will have to do it again before spring time.
Greetings from Karl
Greetings from Karl
My little 28.5 Irwin had a tiller, but was graphite composite.
That little Irwin was fun in heavy seas!
Sailing has a way of breaking things, through time or just hard weather. You just never know when the microwave will come loose and fly across the cabin! Build strong my friend.....
Nice looking Adelie pieces Karl.
CaptUB. I can't wait to get her out in the ocean and get her rock'n and roll'n.
I am curious about these tillers that are laminated. You guys use epoxy or did you use a waterproof glue? Reason I ask is it is said that epoxy is strongest with a gap and forming the wood to shape I would think the force would squeeze out most epoxy leaving a very thin layer and what soaked into the wood. Most wood glues need compression and good penetration into the wood to form a strong bond.
Or should I just keep my thinking to myself?
OrangeQuest wrote: ↑Mon Feb 18, 2019 8:52 am I am curious about these tillers that are laminated. You guys use epoxy or did you use a waterproof glue? Reason I ask is it is said that epoxy is strongest with a gap and forming the wood to shape I would think the force would squeeze out most epoxy leaving a very thin layer and what soaked into the wood. Most wood glues need compression and good penetration into the wood to form a strong bond.
You are right OQ. The shop that made my backup tiller (5' long), used wood glue not epoxy. My old (wooden) whisker pole was built the same way, very pretty, but heavy!
Well I Googled.... lots are made with epoxy, I know my backup was wood glue, but that was 25 years ago! The whisker pole was 80 years old when I got it and had it repaired.
I used polyurethane glue (Gorilla glue) on a tiller I laminated (mahogany/teak), but I'd think that epoxy would work as well.
I would think so too Hank. When I have neat epoxy that drips on an area that I am not ready to coat yet and have to sand it down I can see where the resin soaked down into the wood. To remove all traces of the epoxy I would have to sand away a considerable amount of wood away. I would even guess that the epoxy would increase the rigidity of the wood as a whole making the tillers stronger than the wood/glue alone.
I used epoxy with wood flour mixed and left the 2 surfaces of the plywood rather rough and I made lots of dents with a pointed hammer into them from where the epoxy wood flour mxture could not get pressed out. In addition to that I did not press the plywood very hard with the clamps against the form giving jig blocks which were screwed to the table. I think it turned out as strong as if it were made of a solid hard wood block.
I used neat epoxy and didn't take Karl's precautions despite the wisdom of them. A few years now and no signs of delamination.
Karl asked:
Capt UB says:
Karl asked:
Generic sunbrella covers are available from many suppliers: https://www.shopsoundboatworks.com/36ti ... gKyk_D_BwE I don't keep it covered while sailing. That wouldn't be good for your grip, and besides, when are you going to show it off? The varnish hasn't deteriorated at all in several years--except for the occasional ding or scratch.Maybe Tony could let us know what cover ( see through ? ) he has for his tiller and is it also on the tiller whilst sailing
Capt UB says:
Ahh, yes, and the wonder and mystery is that you don't even have to take the boat off the mooring for things to break. That happens by through magic of the sea.Sailing has a way of breaking things, through time or just hard weather.
Tony
