Was watching a video on a guy running a test between the PU expanding foam and an epoxy expanding foam. The epoxy foam took a lot longer to expand but seemed to be a lot cleaner than the PU stuff.
Anyone worked with it before? Looks like it adds buoyancy.
http://www.sicomin.com/products/epoxy-systems/foaming
Expanding epoxy foam?
Eric (aka, piperdown)
- Netpackrat
Re: Expanding epoxy foam?
I think I fell asleep partway through this one so not sure if it is the video you were referring to.
https://m.youtube.com/watch?v=2RFzH_NB148
Yep, that's the one.Netpackrat wrote: ↑Tue Apr 30, 2019 3:17 pm I think I fell asleep partway through this one so not sure if it is the video you were referring to.
Was curious if the properties are similar, specifically the buoyancy question.
If I am reading the data sheet on the foam correctly it absorbs water in a 48 hour window.
What page was that on the data sheet?OrangeQuest wrote: ↑Tue Apr 30, 2019 5:53 pm If I am reading the data sheet on the foam correctly it absorbs water in a 48 hour window.
Go where it has foam in the right column and then click on where it states "download this" scroll down to the bottom. Here is the link:
http://www.sicomin.com/markets/marine
OrangeQuest wrote: ↑Tue Apr 30, 2019 8:02 pm Go where it has foam in the right column and then click on where it states "download this" scroll down to the bottom. Here is the link:
I had downloaded the data sheet http://www.sicomin.com/datasheets/product-pdf188.pdf but don't see a reference in the 13 pages to that.
- BB Sig
Page 10 & 11.
I wouldn't use it!
I wouldn't use it!
It sounds like they did a lot of testing on their product and are not afraid to share the data. It seems the stuff could be used in the place of plywood used as the core or anywhere else you would want a thick, hard structure from a mold.
- Netpackrat
Looks like the water absorption is listed at less than 1% by weight, which in itself is kind of meaningless without similar data to compare with on whatever polyurethane foam is also being considered.
