https://doc.jamestowndistributors.com/u ... 5.3.18.pdf
Water absorption <= 0.06 lbs/sq ft
Looks PU expanding foam has the ability to absorb water too, although I haven't looked at converting any numbers to percentages.
I haven't looked at the buoyancy numbers in detail but I don't think the epoxy foam is as buoyant as the PU foam.
I was only interested in it due to the slower expansion rate, but if it's not as buoyant I won't be using it.
Expanding epoxy foam?
Re: Expanding epoxy foam?
Eric (aka, piperdown)
They do make the statement that it could be used where you would use foam core or honeycomb.
- Netpackrat
The dude in the video wants to use it in his rudder, where the buoyancy would not necessarily be desirable anyway
I recently did an experiment with PU 38 foam ... https://www.amtcomposites.co.za/product ... d-60-rigid
My results have me quaking at the knees...
I poured a sample in a bag and it weight 165 grams.
I then put a hole through it, threaded a string through the hole and submerged it in the pool attached to a dive weight.
It was about 6" below the surface for a month
It now weighs 724 grams...
Thats a lot of water absorption for "bouyancy" foam!!
A technician with AMT has suggested that by puncturing the hole through it, I broke the surface and allowed water to get in... and that had I not done that the results might be different.
This foam states it is closed cell so I thought that wasn't an issue.
Others have stated that if you allow the foam to contact a surface ... eg stringers and sole when pouring in hull, the layer in contact seals itself.
I am now thinking if I do use foam I will make sure that I pour it into the compartments with a temporary lid covered in PVC on the compartment and a vent hole. That way all sides of foam should "self seal" except at the vent, which I will paint with epoxy...
I still have massive doubts about PU foam and would love to hear more comments...
Unless he loses his rudder a lot!Netpackrat wrote: ↑Wed May 01, 2019 11:02 am The dude in the video wants to use it in his rudder, where the buoyancy would not necessarily be desirable anyway
