Hello,
I am studying the plans of the Runabout 18. On the 310/5 sheet, I do not identify some parts.
- It seems like there are 4 stringers, but in the rest of the plan, only 2 appear
- The same for the transom part : it's drawn 3 times on plans
Should these pieces be glued to each other to be stonger ? (2 stringers of 20mm and the transom of 30mm thick)
Is this correct ?
Thanks for your help !
RB18 - Unknown parts
Re: RB18 - Unknown parts
The stringers and transom are laminated ply. 2 for each stringer, 3 for transom.
So it is correct. Thank you !
Thanks Caveman.
JBCarre, see how the stringers are placed on the nesting drawing. The idea is to offset the seams between the pieces.
Of course, that's what I'll do ! But now, I only prepare the job with dxf files... I am not yet in the woodworking.
Merci pour votre aide Jacques !
