Building in hot and humid climate
southmsfiveo
New Poster
New Poster
Post by southmsfiveo »
I live on the Mississippi gulf coast. Hot and very humid climate. I do not have an enclosed location in which to build a boat. I can build in my carport to keep the rain off the project. Are these circumstances workable? I am specifically concerned about the resin set up and cure times.
Thanks in advance for your response!
Jeff
Re: Building in hot and humid climate
Post by Jeff »
southmsfiveo, First, welcome to our Builders Forum. You will find good support and assistance from the group!! Regarding your questions, many of our builders use their garages as build space. You just need to ensure you select the appropriate boat to build based on the work area you have at your home. You will need to use a Slow hardener or maybe even Tropical Slow due to your temps which are not really any different from Florida or Texas. You will find many of our current builders in both states building or rebuilding a boat!! Let others respond back as well!! Again, welcome to our Builders Forum. Jeff
fallguy1000
Post by fallguy1000 »
southmsfiveo wrote: Tue Jul 16, 2019 12:08 pm I live on the Mississippi gulf coast. Hot and very humid climate. I do not have an enclosed location in which to build a boat. I can build in my carport to keep the rain off the project. Are these circumstances workable? I am specifically concerned about the resin set up and cure times.
You will be able to build, but you also need to avoid fast hardener, and deal with the extreme heat and sun on the part in certain ways.
Especially making it shaded to avoid direct sunlight will help.
viewtopic.php?f=12&t=62495
OrangeQuest
Post by OrangeQuest »
Welcome to the forum. Use the hot weather to your advantage. Try to mix and spread in the cooler morning and then the heat will cause the epoxy to set faster.
A. A. Milne-- Winnie the Pooh
Salty F17
Post by Salty F17 »
[/quote]
Here to help
Check out my build----C17---- hit the link https://forums.bateau2.com/viewtopic.php?f=2&t=63575 ,OD18 build link Nola OD18 - Boat Builder Central - Builder Forums
viewtopic.php?t=65341
Salty F17
Post by Salty F17 »
Salty F17 wrote: Tue Jul 16, 2019 6:29 pm
Im in Louisiana and its humid and hit here Take a look at my build i am doing the same thing you are asking i work outside under a carport use the med speed when it cooler use slow when its hot as hell i pretty much use a med hardener the whole build so far tho just take advantage of the weather let it work with you not against you try to work im the am this will give you the best shot a get multiple jobs done in one day as you go thru the build you will get your own flow to it
OrangeQuest
Salty F17 wrote: Tue Jul 16, 2019 6:30 pm
Im in Louisiana and its humid and hit here Take a look at my build i am doing the same thing you are asking i work outside under a carport use the med speed when it cooler use slow when its hot as hell i pretty much use a med hardener the whole build so far tho just take advantage of the weather let it work with you not against you try to work im the am this will give you the best shot a get multiple jobs done in one day as you go thru the biuld you will get your own flow to it
That is what I am talking about!! :D
Temps drop below 60s and we guys down south pretty near stop building!
Salty F17
Post by Salty F17 »
OrangeQuest wrote: Tue Jul 16, 2019 6:35 pm
Na u could get away with fast /med hardner when it get to the 50's'-60's
With no issue but u better have fast or med or you gonna be in trouble lol also i would not paint in those cooler temp
southmsfiveo
New Poster
New Poster
Thanks guys!
Pulled the trigger and bought the FS18 plans today!
I'm finishing up a big repair/remodel job on the house. I hope to begin this build in August. Semi-retired so I have a good bit of time to work on the boat.
Bogieman
Post by Bogieman »
southmsfiveo wrote: Tue Jul 16, 2019 6:47 pm Thanks guys!
You'll be fine. I'm building the AD16 in my backyard. There are pros and cons though: Pros are you have plenty of room to work and can document your build with pics from all different angles (which usually can't be done in an enclosed space) and you never have to worry about sweeping up the shop (at least I don't anyway). Cons are the weather, weather, and weather. Keeping the boat dry is the biggest challenge I've faced. I'm not building under any kind of shelter, just have the thing covered with a tarp. Working in the heat is a real bear too. The advice about the slow hardener is spot on. It's the only speed I've used.
Good luck on your build. It's exciting stuff and we all like following along and helping out where we can
Bogie
