C19 in Richmond, VA
Posted: Fri Aug 23, 2019 10:19 pm
by Dan_Smullen
Plans in hand for a few weeks now. Scheming and planning. Sourcing material, and starting at the beginning, which I believe is the strongback.
Because I'm a cad/cnc nerd, i did a quick model of the strong back and 2 piece gussets I'll cut out to keep the vertical stanchions plumb and rigid. A nest of 20 on the cnc will be a quick project.
Probably overkill, but I'm anticipating a slow build and don't want things to sag. I've ordered LSLs, (Laminated Strand Lumber) for the beams. Spaced 40" apart so the outside of the verticals align with the insides of the stringers. Next pics should be the real thing!
Re: C19
Posted: Sat Aug 24, 2019 3:15 am
by glossieblack
Dan_Smullen wrote: ↑Fri Aug 23, 2019 10:19 pm
Welcome to the forum. Good call on the laminated lumber.
Re: C19
Posted: Sat Aug 24, 2019 3:32 am
by Fuzz
As long as you are planning for the strongback I would think long and hard about mounting casters to it. Big ones that are overkill. Being able to move the boat around with little effort is a wonderful thing.
Re: C19
Posted: Sat Aug 24, 2019 8:13 am
by Dan_Smullen
Fuzz wrote: ↑Sat Aug 24, 2019 3:32 am
Exactly what’s on my mind. Garage is just barely big enough to hold it, but the ability to move it around so the kids can still reach their bikes is key.
Re: C19
Posted: Sat Aug 24, 2019 10:21 am
by Dougster
Big nice castors for sure. My LB22 build took years and two of the castors flattened out a bit.
Dougster
Re: C19
Posted: Tue Sep 03, 2019 8:39 pm
by Dan_Smullen
LSLs in the house, and big, beefy castors procured!
Question regarding drawing for Station B...
There are two horizontal lines in the area of the sole, but neither is marked with a dimension from the keel or baseline. Which line is the bottom of the sole, and what is a dimension to it?
Thanks.
Re: C19
Posted: Wed Sep 04, 2019 8:42 am
by pee wee
The drawing is small and kind of blurry, but the designer asks that we not post any copies of the drawings, just refer to the plan page in question. Anybody with access to the plans can look to see what you're talking about.
The base line is normally the bottom of the sole, that's all the help I can offer.
Re: C19
Posted: Wed Sep 04, 2019 8:56 am
by Dan_Smullen
pee wee wrote: ↑Wed Sep 04, 2019 8:42 am
Understood. Thanks for that.
Edited post above.
Re: C19
Posted: Wed Sep 04, 2019 9:10 am
by fallguy1000
Any sign of Jacques?
Re: C19
Posted: Wed Sep 04, 2019 12:32 pm
by Jeff
Dan, Welcome to the Builders Forum!!! Also, please give Jacques a little time to respond as he evacuated the area last Friday due to the hurricane!! Jeff
Re: C19
Posted: Wed Sep 04, 2019 1:48 pm
by pee wee
You should get an answer, but in the meantime:
Sometimes the answer can be found by looking at different views of the same area, possibly one piece of information on one page put together with another piece from a different page (top view plus side view e.g.). Sometimes a necessary piece of information is in the build notes. Apologies if you've already looked everywhere, but usually everything you need can be found somewhere in your plans.
Re: C19
Posted: Wed Sep 04, 2019 9:02 pm
by Dan_Smullen
I estimate commercial woodwork and have definitely been known to miss a detail on a drawing. :/
It’s not a deal breaker question. The profile of the frame is clear. This line, I think, only regards the depth of the stringer notch. I can worry about it when the boat is flipped, but would like to know.
Hey, glad you guys dodged a bullet with the storm!
Re: C19
Posted: Thu Sep 05, 2019 10:26 am
I ran away from hurricane Dorian. 5 days ago, it was a cat 5 aimed directly at my house.
Those two lines show the sole thickness. The reason for the existence of those lines is to show the depth of the notches.
Re: C19
Posted: Thu Sep 05, 2019 7:37 pm
by Dan_Smullen
Thank you, Jacque!
What is the dimension to the bottom of the sole from the keel at this station? 11”?
Re: C19
Posted: Fri Sep 06, 2019 12:01 pm
Look at station C. It shows the level of the sole measured from the baseline. It is also visible on D. What you see is the level of the lower face of the sole (= top of the stringers) measured from the baseline. It is the same all through the boat. You can see it on some other drawings too.
The way dimensions are shown, it take a couple additions to get that distance but it is 40-1/4".
All other dimensions refer in some way to the baseline and can get them from there.
I don't show dimensions that way anymore. All my new drawings have separate drawings for the stations and for the frames, it's easier to read but so many C19's were built from those plans that I prefer not to change the drafting even if is a little crowded.
You don't need that dimension but I suppose that you want to redraw the hull in CAD and that's fine.
PS: dimension tolerance is set to 1/8. If you add or subtract some of the dimensions, you may get a 1/8" difference. Use 40-1/4".
Re: C19
Posted: Fri Sep 06, 2019 9:11 pm
by Dan_Smullen
There going to be at least one more built from these plans.
Re: C19
Posted: Sat Sep 14, 2019 7:05 pm
by Dan_Smullen
Small but relevant milestone! Garage organized and strong back constructed on casters! Dimensions 43" x 208". I'm loving the LSLs. Nice and straight and stiff as a board.
Looking ahead to stringers, are the stringers labeled inboard and outboard inversed on the drawing? It looks like the stringer with the knee should be outboard. Correct?
Re: C19
Posted: Sat Sep 14, 2019 7:10 pm
by fallguy1000
Casters are less than ideal because you won't ever be level.
You could build bolts in hardwood for levelers.
Hard maple works well.
1/2-13" bolts mount in threads tapped into the wod and the bolt head sets on the ground; then you know you are level.
My vac table required them for like 8 setups each side, iirc I made 16 adjusters.
Re: C19
Posted: Sat Sep 14, 2019 7:25 pm
by fallguy1000
You won't need to be level all the time, but plenty of times...
So you make it so you can stand up off the casters when needed.
Re: C19
Posted: Sun Sep 15, 2019 11:35 am
by cracked_ribs
Dan_Smullen wrote: ↑Sat Sep 14, 2019 7:05 pm
I think in mine (metric) the labeling is reversed; the longer one is the inner one.
Re: C19
Posted: Sun Sep 15, 2019 7:24 pm
by joe2700
fallguy1000 wrote: ↑Sat Sep 14, 2019 7:10 pm
I find using casters then jacking it up and dropping it straight onto blocks when you need it level works well. I end up using my floor jack all the time with the boat to make adjustments and move around. Do make sure they are strong casters, the boat gets heavier and heavier if you keep using the same strongback as a cradle after flipping.
Re: C19
Posted: Mon Sep 16, 2019 8:08 pm
by Dan_Smullen
joe2700 wrote: ↑Sun Sep 15, 2019 7:24 pm
I’ve thought about that, but for me, it has weighed out to be more of a benefit to be mobile in a tight work area. My intention is to set the frames level on the jig with a laser, while the jig is located in the position in which it will sit while epoxy is curing. But it will be essential for me to push it out of the way in between work sessions.
My wife isn’t going to abide a boat in various stages of construction obstructing her path to the driveway for too long.
I like the idea of leveling feet that I can move up and down as needed.
Re: C19
Posted: Mon Sep 23, 2019 8:57 am
by Dan_Smullen
This seems like another worthwhile milestone. Jig assembled.
At 43” wide, my jig is much wider than any recommended size, but this was intentional, to aid in assembly. I had the notion that I would make the jig width match the stringer spacing. In hindsight, any benefit was minimal.
On each temporary frame, I routed a bottom of sole reference line, and cut the vertical supports to be the 40-3/16” baseline to sole dimension, plus the width of the 7-1/2” for the width of the jig rails. I aligned the top of the support with the bottom of sole line, and clamped it tight at 20” off center to align with the inside of the jig. Flipped over the frames with supports clamped to it, and screwed from the face.
On the jig, I marked locations of the frames, and then offset for my gussets, which when installed squarely in a precise location, provided a hard stop against which vertical supports could be indexed, and clamped in place.
I then used a story stick to check bottom of sole dimension from top of jig, which represents the baseline.
It was a simple system, but I didn’t have an appreciation for how high this assembly would place the keel line. If I don’t lower all of this somehow, working on the bottom panels is going to be challenging. Not sure what will be a greater challenge, glassing and fairing something high, or lowering the entire assembly.
Big thanks to Jacques for taking the time to correspond with me about adding flair to the bow. I have to take some time this week to dig into his notes, but I feel like he has blessed the plan, and it is in motion!
This week is install motor well sides, and laminate and install transom.
Re: C19
Posted: Mon Sep 23, 2019 11:28 am
by Dan_Smullen
Regarding clamping board, will either sapele mahogany or white oak be suitable materials? I have enough of either to work with.
Thanks,
Re: C19
Posted: Mon Sep 23, 2019 2:29 pm
by piperdown
Dan_Smullen wrote: ↑Mon Sep 23, 2019 11:28 am
Thanks,
Clamping board like on the transom?
Re: C19
Posted: Mon Sep 23, 2019 3:23 pm
by Dan_Smullen
piperdown wrote: ↑Mon Sep 23, 2019 2:29 pm
Thanks,
Yes. Exactly.
Re: C19
Posted: Mon Sep 23, 2019 3:47 pm
by narfi
hehe, looking good, but the fisheye camera lens makes that the most bowed looking strong-back I have ever seen
Re: C19
Posted: Mon Sep 23, 2019 4:17 pm
by piperdown
Dan_Smullen wrote: ↑Mon Sep 23, 2019 3:23 pm
Thanks,
Yes. Exactly.
I don't have the plans for the C19 but I guess I'm a bit surprised that it has a clamping board instead of multiple layers of ply bonded together to make the appropriate thickness.
Ask Jeff or Reid about the white oak. I've heard (never used/experimented) that white oak didn't bond well with epoxy but that might be from older epoxies.
https://www.epoxyworks.com/index.php/epoxy-with-oak/
Re: C19 in Richmond, VA
Posted: Sat Oct 05, 2019 6:21 pm
by Dan_Smullen
After what felt like a nearly catastrophic transom lamination, I re-thought my Gel Magic game and whipped up some notched spreaders on some lexan. 8'x10" hobby sheet from the big box yielded 2, which worked like a charm. I also learned to mix the goo on a larger sheet with a plastic putty knife. Combined with the spreader, some tips from ya'll, the application on these stringers was worry free!
I also DIY'ed some puzzle joints on the stringers. Had the notion of a calm glue up, first "scarfing" two halves together, then laminating, but the cool temps today caused a batch of epoxy mixed this morning to cure slowly. I got tired of waiting, and with my new spreader attached the first inboard stringer. A cool head, a nice mixing board, the spreader, and some help flipping from my wife, made for an easy lamination. Also realized puzzle joints are not necessary on the stringers. The overlapping joints is where the strength comes from, but it was a good exercise before it's time to cut some hull panels, which hopefully, will not be too far into the future.
I'm happy with the way all of the parts are fitting together. Everything seems straight. My intention is to hang the transom and clamping board off the end of the stringers. I was waiting to see the dimension between the bottom edge of the notch in the motor well sides and the notch in the stringer knee. I'll rip the clamping board to this dimension, minus a little for glue. Temporary attachment between stringers and transom for now.
Just for fun, here's a pic of some work from the real job. What will be a decorative mirror grill for a house in Easton, MD.
Posted: Tue Oct 08, 2019 6:01 am
by changeat44
Hello Dan,
I follow your build, looks nice!
Did you make your flared bow in AutoCAD? Or will the result be something that will surprise you when it's done?
I'm also interested in a flared bow on my CX21, can't wait to see yours.
I've read somewhere on this forum it has been done before; are there any pictures, I can't find them?
Daniel
Posted: Tue Oct 08, 2019 12:18 pm
by Dan_Smullen
Thanks, Daniel! I’m enjoying the process.
A little bit of both on the bow. I drew all of the parts in Fusion 360, which is 3D modeling software. From here I creat the cnc programs to cut parts. It’s more user friendly for me. Rather than set up and do full size layouts on sheets to cut by hand, this process allows me to work on things a little at a time as free time allows.
I read the thread about flared bows, and reversed the camber on station 1 and the bow mold. Jacque offered to take a look at my model, which he did, and have some advice on how to make the hull panels work. Thread is here.
https://forums.bateau2.com/viewtopic.php?f=2&t=25003
I haven’t dug into his advice yet; I’ve been focused on stringers and transom, but plan on laying out the bottom panels this week, making my way toward the side panels, which will be affected by the reverse camber.
Jacque also suggested kerfing the hull panels to allow them to bend easier, which I will. I’m going to squeeze as much flare as I can!
Posted: Tue Oct 08, 2019 12:38 pm
by changeat44
Sounds you know what your doing, must be exciting for you!
I keep an eye on your build
Thanks and good luck,
Daniel
Posted: Tue Oct 08, 2019 5:25 pm
by Dan_Smullen
I wouldn’t say I know what I’m doing, but I am trying to use the tools I have.
I’m excited for sure. Definitely the most complex single product project I’ve ever undertaken!
Posted: Sun Oct 13, 2019 7:59 pm
by Dan_Smullen
Posted: Sun Oct 13, 2019 10:26 pm
by Bogieman
That level is important. It's been one of my best friends during my build
Everything looks nice and solid. Fun times. I look forward to watching the rest of your build.
Bogie
Posted: Mon Oct 14, 2019 12:51 am
by changeat44
Nice work Dan!
Daniel
Posted: Mon Oct 14, 2019 7:11 am
by Rmarsh
Nice work!
Posted: Mon Oct 14, 2019 7:38 am
by Jeff
Good start!!! Jeff
Posted: Tue Oct 15, 2019 9:06 am
by Eric1
Nice work!!
Posted: Tue Oct 15, 2019 10:41 am
by Dan_Smullen
Eric1 wrote: ↑Tue Oct 15, 2019 9:06 amNice work!!
Thanks, Gents!
Question for you, Eric. Standing here, looking at the keel at about eye level, I’m wondering how I’m going to be able to effectively sand and paint the bottom of this boat.
Assuming you faced similar challenges on your C21. What do you to manage sanding over your head? Just work off a ladder or something more creative?
Posted: Tue Oct 15, 2019 12:22 pm
by Eric1
I have two heavy butcher block tables I stood on.
Posted: Wed Oct 16, 2019 11:00 am
by Dougster
I used an 8' 2 x 6 as staging. Set it on two of anything the right height. It was a bit of a pita but more fun fooling with that than the actual sanding
Dougster
Posted: Wed Oct 23, 2019 7:32 pm
by Dan_Smullen
Stitching is going well. I'm kind of a one piece flow type of guy, so started with the bottom panels. Puzzle joints worked well.
First attempt without any spacers didn't work at all.
Notice the overlapped edges.
A brief search through the forums, and I was well armed with the experience of others, and ready for success.
The pipe pieces were key. Notice the hole drilled in the pipe which holds the spacer nail.
Also, slow and steady, tightening as I went, and in an hour or so, the bottom panels were stitched.
I went into this build fired up to create a flaired bow. Modified the bow mold and station one to accommodate. Jacques, more than graciously looked at the little cad work I had done, offered sound advice and wished me the best. However, looking at how well the panels are coming together, taking shape with very little help from the frames, I'm reluctant to try to change a good thing. I don't have the stomach for the test cuts while I have such a good design as is. Looking at the line of the keel, transitioning into the front of the bow, it's easy to see how the hull panels, as designed will provide a sexy, and functional front end, without a bunch of experimentation.
I'm taking the easy route, but I'm not willing to tackle the unknowns, especially while things are going so well.
So it's side panels next!
Posted: Thu Oct 24, 2019 5:09 am
by Eric1
Looking good Dan! Build On!!
Posted: Thu Oct 24, 2019 7:38 am
by Jeff
Nice progress!!!! Jeff
Posted: Thu Oct 24, 2019 8:45 am
by Reid
Looks good Dan! Nice job troubleshooting the issue.
-Reid
Posted: Sun Oct 27, 2019 3:08 pm
by Dan_Smullen
I couldn't have asked for the panels to have come together better than they did!
Great dimensions, Jacques!
Posted: Mon Oct 28, 2019 9:51 am
by piperdown
Good work! That's a fair looking boat
Posted: Mon Oct 28, 2019 8:12 pm
by Dan_Smullen
piperdown wrote: ↑Mon Oct 28, 2019 9:51 am
Thank you, Sir! The panels are coming together very well.
The upper side panel seems to be running long at the bow.
I'm not worried about this. It actually gives me a little material to shape at the bow. I'd like to taper the end so it's aligned with the lower side panel, but tapered to nothing where the tip of the bow is in the picture. Simply aesthetic.
Also, there is a bit of a buckle at the seam in the forwardmost 6 feet of the upper side panel. I can make it go tight by riding down off of the 6" line by an inch or two.
Am I correct to think the riding down a small amount is better than fighting a buckle?
Posted: Mon Oct 28, 2019 11:38 pm
by Fuzz
I would do what I could to get rid of the buckle rather than have to deal with it later. Also if the upper panels are not glued on yet you can lower them down until they line up at the bow. Too long or short with the upper panels is all about where they are located on the lower panels.
No matter what you do it will not matter much, the boat is looking very nice.
Posted: Tue Oct 29, 2019 6:40 pm
by Dan_Smullen
Good points, Fuzz. I’ve seen some other posts where an improper overlap caused the problem. I thought it is supposed to be 6”, but need to double check.
Maybe the bigger question is, how much minimum overlap is required. If it goes from 5-4” and everything is fair, is there a problem?
Jacques?
Posted: Tue Oct 29, 2019 7:26 pm
by Dan_Smullen
Dan_Smullen wrote: ↑Tue Oct 29, 2019 6:40 pm
Jacques?
Question answered by Jacques in another post,
"I think the building notes say 6" but there is no need to measure anything. The lower panel start at the chine, the upper panel ends at the sheer. You know where the sheer is. That's all, no need to measure."
Posted: Sun Nov 03, 2019 11:24 am
by Dan_Smullen
Pretty much a consistent 4" overlapped worked for the upper side panel. Plenty of screws, but none of them seemed to cause an deformation, and the sides still look fair.
Up to this point, I've used about 85% of a 1-1/2 gallon Gel Magic bucket. With this, I have laminated the transom, applied the transom clamp, laminated all 4 stringers, and the 2 side panels. Happy with the yield for sure.
All panels are spot welded. Over the next few days I'm going to do some research on how much resin it will take to fill and tape the joints wet on wet to be sure I have enough before jumping into that. I have 2 gallons on hand. Thinking that will be enough, but would like to double check.
Posted: Mon Nov 04, 2019 9:14 am
by Jeff
Good progress Dan!!! Jeff
Posted: Mon Nov 04, 2019 9:40 am
2 gallons of EazyFillet should be enough.
Do not use too much putty. A 1/2" radius is fine. The fillet's job is to allow the fiberglass to take a nice turn around the corners. 1/2" is more than enough for biaxial 12 oz. and 3/8 is sufficient for small corners like furniture done with woven glass.
Posted: Mon Nov 04, 2019 10:46 am
by Dan_Smullen
Thanks, Jacques.
I plan on working wet on wet for fillets and tape. Is the EZ Fillet better suited for this more so than epoxy and wood flour mix? Also, should I be backing up the inside of these joints with packing tape inside the hull?
Posted: Fri Nov 08, 2019 8:39 am
by Bogieman
Dan_Smullen wrote: ↑Mon Nov 04, 2019 10:46 am
Thanks, Jacques.
Hi Dan,
I've never used EZ Fillet so I can't help you there. And, yes, tape those inside seems to prevent the fillet from leaking through. Everything looks great!
Posted: Fri Nov 08, 2019 3:25 pm
by Fuzz
EZ Fillet is nice and easy to use. But like most things you pay for that use of use. I mix my own fillet mix but would not hesitate to use EZ Fillet if I had it.
Posted: Mon Nov 11, 2019 8:31 am
by Eric1
It is easy to use and mix. I find it tends to kick off faster than when I mix my own wood flour and epoxy.
Posted: Mon Nov 25, 2019 7:57 pm
by Dan_Smullen
Not too bad! I think I had been sub consciously delaying out of anxiety, having never taken on a fiberglass/epoxy project of this size, but thanks to the many tips and much advice I've got from you guys directly, and by reading about your own experiences, this went rather well.
Rolled neat on first. Mixed a new batch or two or wood flour. Filled seams with it by using the now famous piping bag method, then covered it all with precut lengths of tape. I saturated the tape with subsequent batches using a variety of application methods which included, but not limited too, brushing, rolling, dumping and squeegeeing. Did two layers each on the transom and keel Saturday night, one layer on each chine on Sunday.
Altogether, worked at a leisurely pace using fast hardener in a 66 deg. garage, mixing about 1/2 a quart at a time. Rolling with 1/8" nap rollers from West System seemed to be the neatest, although dumping and controlling the puddle with a squeegee worked well too, as long as I rolled it out after.
I have one or two small white spots that will need some attention. I believe in these areas the peanut butter sagged in and away from the tape, or my fillet on the edge of the plywood wasn't quite enough.
Pictures are terrible due to night time garage lighting, but I'm stoked to be at yet another milestone! Thanks for the help fellas!
Hull glass may have to wait until after Christmas, the next few weeks look busy on the family front!
Posted: Tue Nov 26, 2019 9:51 am
by Bogieman
Posted: Tue Nov 26, 2019 10:04 am
by Eric1
I think you are good to go!
Posted: Sun Dec 01, 2019 2:12 pm
by Dan_Smullen
Eric1 wrote: ↑Tue Nov 26, 2019 10:04 am
I think you are go to go!
That has a nice ring to it!
Some Thanksgiving fish action. Hope to be bringing these guys over the rail next year!
Posted: Sun Dec 01, 2019 2:18 pm
by Eric1
Nice!
Posted: Mon Dec 02, 2019 5:54 pm
by jw01
Nice fish Dan. "Yak attack" huh? Rudee's Inlet or Lynnhaven by chance? We are neighbors … Colonial Heights … so simply had to register once I saw this current thread. Done a little kayak fishing there myself.
I've been contemplating taking the plunge. Kinda had my eyes set initially on the OB15 for the wife and I. Then was considering possibly the OD16. Now "seriously" considering the OB17. She's definitely a pretty ride but realistically more than I need. Probably gonna end up going with the 16 as the majority will be along the James River with a trip now and then South. The warden has given me the green light on whatever route I choose … silly woman …. Decisions, Decisions …….
Posted: Mon Dec 02, 2019 7:44 pm
by Dan_Smullen
jw01 wrote: ↑Mon Dec 02, 2019 5:54 pm
Niether. WNB...
Right on, JW! Glad to run into a neighbor! Thanks for posting.
Either hull will be nice, but the xtra foot of the 17 may be nice from time to time, for not much more investment.
Plans are easy to follow. If you take the plunge, speak up. It will be good to collaborate!
Posted: Mon Dec 02, 2019 10:03 pm
by Fuzz
Boat is looking good.
Do my eyes deceive me or do I see a moose rack hanging on the wall?
Posted: Tue Dec 03, 2019 7:14 am
by Jeff
Good progress Dan!!!! Jeff
Posted: Tue Dec 03, 2019 12:47 pm
by Dan_Smullen
Fuzz wrote: ↑Mon Dec 02, 2019 10:03 pm
You are correct. I worked with some guys in Seward and Nikiski who ran a gold mine in Coldfoot, where I got to go a few times, and we hunted there. This was Fall '98 or '99, don't recall which. Definitely thankful for the opportunity to experience that for sure. I haven't been back to AK since '01. On my bucket list to go back.
I see you're from Kasilof. I spent some time there on a tender working for Cook Inlet Processing, Fond memories for sure, but regret only the fact that I don't think I'm welcome back at the Big T Lodge.
Posted: Tue Dec 03, 2019 1:32 pm
by Fuzz
I am always surprised at the number of folks who have been up here. You must have been having a lot of fun to wear out your welcome at the Big T
Posted: Sat Dec 14, 2019 7:37 am
by Dan_Smullen
Rmarsh wrote: ↑Mon Oct 14, 2019 7:11 amNice work!
Thank you sir! As was your C17!
I unsuccessfully tried to find your photo gallery. Do you have a link?
Posted: Sat Dec 14, 2019 2:37 pm
by Rmarsh
Hi Dan..I do have pictures in the builders gallery....C17 in Mass.
Been enjoying watching the progress and quality of your build.
Bob
Posted: Sun Dec 15, 2019 9:14 pm
by Dan_Smullen
Rmarsh wrote: ↑Sat Dec 14, 2019 2:37 pm
Bob
I've been looking and searching for your album, but coming up short. If you have a shortcut to share, please post!
Posted: Mon Dec 16, 2019 5:50 am
by Rmarsh
Posted: Mon Dec 16, 2019 8:15 pm
by Dan_Smullen
You da man! Thanks for that. Great looking boat. The swim step looks great and well thought out. It's nice to get a look ahead by seeing how others have gone before.
Posted: Mon Dec 30, 2019 1:06 pm
by Dan_Smullen
I took advantage of some down time after Christmas to glass the outside of the hull with 12oz. biax as specified. Started with the transom a few days ago to work get a sense of what the process was going to be.
All in, I laid out about 25 yards, using a little 420 ounces of epoxy. Not counting the transom, the hull took me about 8 hours to complete, all in one day.
I think it went well. Used a a PVC roller on the bottom where it is relatively flat. Dumped small batches of material on the boat, moved them around with the roller, then squeegeed excess material to dry areas. Looking back on wet out areas, I looked for white spots that may have indicated some bubbles, and sniped those by dabbing epoxy and flattening any glass that was puckered.
On the sides, I opted for again pouring material on the bottom where the side panels overlapped, and spread epoxy with chip brushes, and then squeegeing excess. As directed, I cut glass at the bottom edge of the upper side panels with a razor after the epoxy got a little green.
Great tips from Fallguy about marking the locations of the dry glass with a marker, which acted as a guide while laying the cut glass on top of a tacky hull.
Jeff, also appreciate the suggestion of some medium hardener. I used it all wetting out the glass.
Also, took some time on the computer to start working on the console design. To me, this will be the funnest part of the project.
So now, off the begin fairing!
Posted: Mon Dec 30, 2019 1:16 pm
by Jeff
Dan, nice glass work!! I really like the console design as well!!! Jeff
Posted: Tue Dec 31, 2019 8:23 am
by Dan_Smullen
Jeff wrote: ↑Mon Dec 30, 2019 1:16 pm
Thanks Jeff! I’m learning as a I go. Couldn’t do it without you and everyone else on here!
Posted: Tue Dec 31, 2019 9:24 am
by Eric1
Great job Dan. I like your console!
Posted: Wed Jan 01, 2020 4:27 pm
by Dan_Smullen
Eric1 wrote: ↑Tue Dec 31, 2019 9:24 am
Thanks Eric! Now I just need to get there, and build it!
Posted: Wed Jan 01, 2020 4:33 pm
by Dan_Smullen
Happy New Year Folks!
Fairing has begun!
After knocking off the splinters and nibs with the belt sander, I'm spreading a mix of phenolic microballons and glass spheres. Mixing 6oz batches with fast hardener, and getting good coverage just trying to fill low areas. Mainly the "ledges" at overlapping glass, and the weave. Spreading with a relatively stiff 12" plastic squeegee.
4"x19" DIY torture board and I will get to know each other well over the next few weeks I'm sure.
Posted: Thu Jan 02, 2020 4:52 pm
by jw01
There ye go Dan. Was wondering if you had been working on it. Looks good man. Nice rendering on that console !!
Posted: Thu Jan 02, 2020 9:37 pm
by Dan_Smullen
jw01 wrote: ↑Thu Jan 02, 2020 4:52 pm
Thanks, JW.
Winter has fallen. The fairing has begun...
Posted: Fri Jan 03, 2020 7:05 am
by Jeff
Dan, glad to see the fairing has begun!! Jeff
Posted: Sun Jan 05, 2020 8:04 pm
by Dan_Smullen
Jeff wrote: ↑Fri Jan 03, 2020 7:05 am
Me too, Jeff! Thanks!
New tool in the shop to help!
Looking pretty good athwartships, but a little hook to contend with on back half of the port side bottom panel.
Opting to apply reverse chines and skeg before continuing to fair.
Posted: Mon Jan 06, 2020 3:03 pm
by tcason
love your console!
Have you considered a console toe kick? - Would make it harder to fabridate but may save some toes?
Posted: Mon Jan 06, 2020 5:10 pm
by Dan_Smullen
tcason wrote: ↑Mon Jan 06, 2020 3:03 pm
love your console!
I hadn't considered it, but I like the idea! Definitely going to keep that in mind when I get closer.
Posted: Mon Jan 06, 2020 5:17 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Jan 05, 2020 8:04 pm
I have a similar issue, same place, interested to see how you handle it. I am tempted to leave it as I am horrible at fairing and could end up with a bigger problem than I have now. I've read all about the potential issues with hook, still tempted to leave it.
Posted: Mon Jan 06, 2020 6:59 pm
by Browndog
The toe kick on the console is a nice modification that will gain you several inches of deck space and allow you to mount whatever seating system you choose closer to the console. It is a small detail, but a very effective customization.
I added one to the console I built for my brother’s FS-19. Works well in real life.
Makes the console installation a little harder due to the recess. Sanding, priming and painting also are somewhat more difficult as well, but the payoff is worth it.
Building a mock console out of cardboard was very helpful to me. It really helped with fine tuning the dimensions, fore and aft placement, leaning post placement, steering wheel placement, dash board angle, console height & depth.
For example, the depth of the instrument panel had to be changed to accommodate the electronics that were flush mounted. The amount of clearance needed behind the instrument panel to accommodate the VHF, Sonar/GPS and all the wiring to support them was greater than I first thought. I also had to incorporate access panels on the front and back to be able to install and wire everything. I ended up adding a front door with tackle box storage and a rear bi fold door. I also added a shelf on the inside to hold safety equipment, flares, air horn, etc. I also mounted the fire extinguisher inside the console on a bracket.
The console fabrication and modification ended up being one of the most satisfying parts of the project because it really embodied the custom build aspect of the whole project. Everything is set-up to be at the correct height with optimal sight lines and instrument locations for my brother when he is standing or sitting. He is 6’3”, I’m 5’11”. I can still use the console but it is not as comfortable for me as it is for him.
Adding the custom dash panel with switches and circuit breakers really took it to the next level. It saved me a lot of time wiring all the switches and I feel it was well worth the expense.
To save you time searching through the forum, here are a few pictures of the finished console with & without the windshield.
Posted: Mon Jan 06, 2020 7:59 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Jan 06, 2020 5:17 pm
Hey! How'd you get my level?
Took me a minute to place the pic in your shop...
I think applying the skeg and chines flat and straight will give me two points to work between as I move forward down the bottom of the hull. If the hook is not too deep, I'm thinking I can screed filler between the straight edges of skeg and chine. I had a little low spot at the stem that I filled with a piece of glass. It worked well there, could do the same here if it's deeper than 3/16".
Also tempted to just move on too, but don't think I can. Worst part is that before taping, I told myself to add a strut or two between frames to support the panels, but I didn't, which probably would have prevented it from developing.
Browndog wrote: ↑Mon Jan 06, 2020 6:59 pm
Thanks for the pics, Browndog. I've read over your build thread a few times. I'm sure I'll be referring back to again soon. Actually hoping I can touch base with your brother sometime and take a look at the finished product. Its a beautiful boat.
Definitely going to build a mock up or two before making sawdust on the console.
Posted: Mon Jan 06, 2020 8:11 pm
by Dan_Smullen
Posted: Mon Jan 06, 2020 8:58 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Jan 06, 2020 7:59 pm
I actually did do that after reading nightmares of others. I wedged something between the stringer and the bottom panel on both sides and *thought* I had them flat before I glassed. I'm adding strakes on each side instead of a single on the keel/center so I can get some tracking without adding depth, maybe that will take some of the hollow out, we'll see.
Appreciate the input Dan, and very nice level!
Posted: Mon Jan 06, 2020 9:01 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Jan 06, 2020 8:11 pm
I'm a sucker for a sweet machine set up.
Damn! Nice operation!
Posted: Tue Jan 07, 2020 7:10 am
by Browndog
I recall a discussion in the past where it was said that Jacques has occasionally designed the hull and fiberglass overlaps to have a slight hook near the transom.
Posted: Tue Jan 07, 2020 10:57 am
by Dan_Smullen
Browndog wrote: ↑Tue Jan 07, 2020 7:10 am
I remember reading something along these lines, but I think JM was saying that he designs the transom to sit a little lower to prevent hook developing as fg is lapped over the edges. I'd have to look to be sure, but I think this was in the build thread for "Auspicious".
Posted: Wed Jan 08, 2020 12:57 pm
by Eric1
Sorry for the hack Dan, Brown dog do you by chance have dimensions of your console?
I absolutely love it and would like to copy it for my C21.!
Posted: Wed Jan 08, 2020 5:01 pm
by Browndog
Eric,
Found some old sketches of the console. Not sure if the dimensions are 100% correct since the boat isn’t here to measure, but at least it’s a start. Attached is a picture of the Side view. The sketch is definitely not to scale, but you’ll get most of the pertinent info from it.
The front of the console dimensions are a trapezoid 34” wide on the bottom and 33” wide at the top and 48” tall. From the picture of the sketch you can see that the console is also raked to the rear by 3”. This really adds to the comfort of standing behind the console with the added toe kick.
Posted: Wed Jan 08, 2020 7:16 pm
by Dan_Smullen
Eric1 wrote: ↑Wed Jan 08, 2020 12:57 pm
No problem, Eric. If all goes well I’m going to meet up with Jonathan Evans on Monday and lay my eyes on this beauty. I’ll try to get some dimensions for you.
Posted: Thu Jan 09, 2020 10:36 am
by Eric1
Thanks guys.
Posted: Thu Jan 09, 2020 10:52 am
by VT_Jeff
Dan,
Interested to see how you're going to transition those reverse chines at their forward end. Did you taper them in that same milling operation or will that happen later?
Posted: Thu Jan 09, 2020 12:58 pm
by Dan_Smullen
VT_Jeff wrote: ↑Thu Jan 09, 2020 10:52 am
Dan,
Currently developing a plan that involves a template to match the edge of the bottom panel, tapered to nothing about 18” back from the stem.
Hope to be working through this over the weekend
Posted: Thu Jan 09, 2020 1:34 pm
by VT_Jeff
Dan_Smullen wrote: ↑Thu Jan 09, 2020 12:58 pm
Dan,
Sounds like more fun than fairing, good luck!
Posted: Thu Jan 09, 2020 5:05 pm
by Dan_Smullen
This is the first part of it.
Will glue these together and then cut out to match the template. I think the majority of the shaping will happen by hand.
Posted: Fri Jan 10, 2020 9:41 am
by pee wee
Dan_Smullen wrote: ↑Thu Jan 09, 2020 5:05 pm
As a longtime woodworker I can appreciate the love of a good setup, but also have come to understand there are times it's much faster and just as good to pick up a hand tool (like a plane or draw knife) and get to work! Jigs and fixtures really shine when you need repeatability and accuracy, they make fast work of multiples. I like that work you did through the power planer, though, and what a planer! I'd love to have access to some equipment like that.
I enjoy watching how other people look at a problem and find a solution. Looking good.
Posted: Mon Jan 13, 2020 8:54 pm
by Dan_Smullen
Eric1 wrote: ↑Thu Jan 09, 2020 10:36 amThanks guys.
Eyes laid on the beauty this afternoon. She stood out like a diamond in the ruff amongst the Lake Anna pontoon fleet. Console closet matches Browndog’s dimensions in the pic.
Posted: Mon Jan 27, 2020 9:59 pm
by Dan_Smullen
Have spent time fairing the transom. After some advice from here and You Tube auto body guys, I made progress. The correct sandpaper, 40 grit aluminum oxide on a 16" Durablock has been a game changer.
Hit the transom with guide powder and 40 grit, no powder was left behind, so after some 80 and 120 grit, the transom will be ready for primer. Will blend in the edges with the bottom later.
Before moving on to the rest of the fairing, I resolved to complete the reverse chines/spray rails, which caused much head scratching. It was examination of this 18' Parker, that unlocked the mystery of the spray rail geometry!
It appears to me, that the bottom face of the spray rail remains parallel to the angle of the reverse chine at the stern, in this case, ~6 degrees from the waterline. The outside face remains in line with the face of the side panel.
To get the blanks, 8/4 fir was scarfed to rough shape. Cut out to match template. Re-sawn to 3/16" ,then laminated in place place on the hull.
After cured, and edges cleaned up, I chiseled in at angles parallel to the face of the chine, then band-sawed away material between, then planed and shaped the face by hand to close enough.
The aft portion of the reverse chine is about 9' long and straight; kerfed the last 24" of so to bend into place along the shape of the hull, to pair up with the end of the laminated section.
Now, just need to mirror onto the other side...
I've kept them screwed in place while shaping, but will glue permanently, fill voids with peanut butter, round corners, then glass over with 10 oz. woven. Funny thing is, I bought the woven from BBC a month ago, because for sure, I would be glassing in spray rails that weekend.
This step has been a puzzler for sure, but a joy to work through. I'm'm glad they will soon be in the rear view mirror! Will be nice to have them glassed in, and fairing the bottom.
Posted: Tue Jan 28, 2020 7:17 am
by Jeff
Nice work!!!! Jeff
Posted: Wed Jan 29, 2020 4:26 pm
by Dan_Smullen
Jeff wrote: ↑Tue Jan 28, 2020 7:17 am
Nice work!!!! Jeff
Thank you, Jeff!
pee wee wrote: ↑Fri Jan 10, 2020 9:41 am
Thanks, Pee Wee! Feeling good too!
There is a lot satisfying about a whisper thin wood shaving whisking out of the top of a hand plane for sure, but watching this planer automatically adjust thickness precisely to .000", is satisfying too! Especially after years of cranking a giant wheel of some sort to adjust thickness. Not a lot of room for hand plane work in the commercial work we do in our shop, but agree, that the most accomplished woodworkers are so because they understand the time and the place for each.
Dan,
The kerfing at the end allowed the straight section to begin the bend in the last 18' or so.
Posted: Wed Jan 29, 2020 7:12 pm
by Eric1
Way to adapt and move forward. Speaks well of your character!
Posted: Sun Feb 02, 2020 7:39 pm
by Dan_Smullen
Eric1 wrote: ↑Wed Jan 29, 2020 7:12 pm
I appreciate that, but I wish character was that easy. A mentor taught me that it is imperative to come out on the other side of challenge, in better position than where you expected to be.
Bent the port side froward rail in place the other night. Shaped it in place with a borrowed power plane, and fine tuned with spoke shave and block plane.
Will glue these in place, then fillet and cover with 10oz.
Posted: Mon Feb 03, 2020 9:24 am
by Jeff
Nice work Dan!!!! Jeff
Posted: Sun Feb 09, 2020 7:18 pm
by Dan_Smullen
Thank you as always, Jeff!
Good advice from the boys on another thread made me to think enough to break out the big clamps. Got the chine rails glued in place on both sides. Glued onto a wet layer of 12oz, with a generous helping of wood flour thickened epoxy between the cloth and the rail.
Used a few screws forward on the spray rails, but drilled out the holes after removing the screws, and will plug with epoxy and a dowel.
Posted: Sun Feb 09, 2020 7:39 pm
by Aripeka Angler
Very nice work, clean and fair.
Posted: Sun Feb 16, 2020 2:16 pm
by Dan_Smullen
Man, I've been messing with these for nearly 6 weeks. Glad to have them glassed over. Reid, the 10oz. was perfect. It laid nicely over a small radius on the corner, <3/8" I believe.
Voids around them were filled with woodflour/cabosil thickened epoxy after wetting, before glassing. Happy with the way they are turning out.
Finished off the weekend with a thin coat of micro-balloons/glass spheres on both bottom sides, and a neat coat over the white oak skeg.
Most pics are from the starboard side, just because of better lighting on that side in the garage. Last pic is port side forward, where the spray rail tapers to nothing.
Estimating 24% complete...
Posted: Mon Feb 17, 2020 7:12 am
by Browndog
Looks great Dan!
Posted: Mon Feb 17, 2020 9:41 am
by Jeff
Nice Dan!!! Jeff
Posted: Mon Feb 17, 2020 9:14 pm
by Dan_Smullen
Thanks gents. Full send on fairing now.
Plan is to focus on getting bottom panels ready for primer, the. Apply rub rail, the. Prep sides for primer.
Transom, I believe, is all but ready, just needs a lick with 80–>120.
Posted: Mon Feb 17, 2020 9:27 pm
by VT_Jeff
Way to power through it Dan, nicely done!
Posted: Wed Mar 04, 2020 4:13 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Feb 17, 2020 9:27 pm
Only way to go! Still pushing when I can!
I'm calling the bottom ready for primer.
After some internet consultation, I addressed a slight hook at the transom with strips of 10 oz, and thickened epoxy. I'll sleep better knowing it's more flat than it was.
Smoothing in the forward ends of the spray rails is working well, but going to leave them alone until I fair the sides, which will be after I glass the upper panels, which will be after I apply the rub rails. Rub rails are cut, but need to be laminated to the hull.
Alexseal color cards are on the way!
Posted: Wed Mar 11, 2020 9:06 pm
by Dan_Smullen
Rub rails and upper side panel glass this week.
Made some efforts to do away with the little bit of dip at the bow by modifying the rub rails and holding them low (while upside down). This will require adding material back to the bottom side of the rub rail so the top and bottom edges remain parallel. It's the little things, I believe, that make a boat sexy, and worth the effort.
Cut strips of okuome, the top edge of which match the contour of the top edge of of the upper side panel, and offset in 1-3/4".
Pre-wet all surfaces with neat, then laminated with wood flour thickened epoxy, held in place with spring clamps.
Greasy fillet of more peanut butter on the bottom edge, then laid 10oz side panel on the wet fillet, lapping the bottom of the 3/4" thick applied rub rail.
Did the port side rub rail and glass in 3.5 hours on Sunday. Did a 2 hour after dinner sesh in the garage for the starboard yesterday; trimmed the excess off green this morning.
I'm optimistic fairing the sides is going to go more quickly than fairing the bottom. No ladder required anyway.
Time will tell...
Dangerously close to ordering primer, Jeff!
Posted: Thu Mar 12, 2020 8:05 am
by Jeff
Looking really nice Dan!! Great progress!! Jeff
Posted: Thu Mar 26, 2020 4:01 pm
by Dan_Smullen
Jeff wrote: ↑Thu Mar 12, 2020 8:05 am
Only fairing and vacuuming at this point.
, but down to places like this, and working on the shape of the stem. All progress...
Interested in opinions though, does it look like more fairing material on here than normal? This is the sum of 3-4 light (I think
) targeted coats.
Posted: Fri Mar 27, 2020 10:21 am
by Eric1
I think it's fine.
Posted: Fri Mar 27, 2020 3:11 pm
by Fuzz
Eric1 wrote: ↑Fri Mar 27, 2020 10:21 am
I think it's fine.
If the Zen Master of sanding thinks you are "fine" Then you are golden maybe better than golden
Posted: Fri Mar 27, 2020 3:37 pm
by Capt UB
Dan she is looking great. How are the Dura Blocks?
Posted: Mon Mar 30, 2020 5:13 pm
by Dan_Smullen
Capt UB wrote: ↑Fri Mar 27, 2020 3:37 pm
Thanks, Cap'n!
I wouldn't want to fair without this 16" Dura Block.
This weekend I made the switch from 40 grit to 80, and stepped down to a softer 3"x9" hand pad, and it too seems to be imperative.
Posted: Tue Mar 31, 2020 8:03 pm
by Dan_Smullen
Working my way towards the rub rails with a softer fairing compound.
Posted: Wed Apr 01, 2020 9:04 am
by VT_Jeff
Glad to see things progressing for you Dan, looking great, keep it up!
Posted: Wed Apr 01, 2020 10:38 am
by Jeff
Nice work Dan!! Jeff
Posted: Tue Apr 14, 2020 4:48 pm
by Dan_Smullen
If there are any more spots that need attention, I'm going to let the primer show them to me.
In the meantime, I'm scratching my head about strakes.
Easy, I believe, to add a few straight ones as drawn in the plans, but I'd like to bring the tips of them all the way forward which requires some bendi-ness.
The head scratching will continue...
Thanks to all for answering my questions when I hi-jack threads.
Posted: Tue Apr 14, 2020 5:49 pm
by Fuzz
Look above in FS-17ls page 8. I built spray rails with this method and they worked very well. Right out of the mould they are very flexible.
Posted: Tue Apr 14, 2020 8:15 pm
by Dan_Smullen
Fuzz wrote: ↑Tue Apr 14, 2020 5:49 pm
Thanks Fuzz. I'm looking for that post but haven't found it yet.
After laying this template in place, your method has me thinking though.
I might be able to use the template as a mold on the hull, and fill the bottom side, on the high side anyway, with thickened epoxy, then fill in the void between were the template met the hull on the low side, and the newly created dam.
Or, revert to shaping some solid wood.
Posted: Tue Apr 14, 2020 9:09 pm
by Fuzz
Here in builders power boats, third thing down is tech supports build of an fs17ls Page 8 close to the bottom.
https://forums.bateau2.com/viewtopic.ph ... 1&start=70
Posted: Tue Apr 14, 2020 9:38 pm
by Dan_Smullen
Great thread, Fuzz! Thanks for the link.
Posted: Wed Apr 15, 2020 12:41 pm
If you want them curved, you will have to laminate something. It is much easier to run them straight and besides a little better spray deflection, I see no other benefit.
Posted: Wed Apr 15, 2020 4:29 pm
by Dan_Smullen
jacquesmm wrote: ↑Wed Apr 15, 2020 12:41 pm
Easier is fine at this point. I'm looking forward to primer!
Posted: Sat Apr 25, 2020 8:50 pm
by Dan_Smullen
Posted: Tue May 19, 2020 3:45 pm
by Dan_Smullen
I hope this is my last post before the boat changes color with a coat of primer!
She's pretty fair overall, but need some primer to show me where I've missed. Blocked with up to 80 grit at this point. Will take it up to 150 before spreading primer.
Posted: Wed May 20, 2020 10:50 am
by VT_Jeff
Looking great, Dan, you're a workhorse! Looking forward to the primer "revelation".
Posted: Wed May 20, 2020 10:58 am
by Dan_Smullen
VT_Jeff wrote: ↑Wed May 20, 2020 10:50 am
It's a bit of an obsession.
Slow and steady is all I've got.
Posted: Wed May 20, 2020 3:16 pm
by OneWayTraffic
If you leave the strakes bright you will probably need to redo them in five or ten years. I did a skeg only. Got glass and may get a strip of UHMWPE.
Posted: Thu May 28, 2020 3:59 am
by OneWayTraffic
How is it going with the glass removal? On reflection I would have been removing all the glass I’m unsure about: anywhere that dry erase marker has been. 2” overlaps on the patch and the shear bond strength of epoxy is equivalent to the glass: no strength loss.
Posted: Thu May 28, 2020 5:08 pm
by Dan_Smullen
OneWayTraffic wrote: ↑Thu May 28, 2020 3:59 am
Thanks for checking in!
Ground down to all visible air bubbles, wet coat with neat, laid strips of 12oz biax in the deepest and widest areas, then skim coated with a mix of chopped stands and cabosil. Faired it all in, and I think I am back to normal.
Then, celebrated with fried redfish and the smoothest hazy IPA in the universe.
I appreciate the advice. Yall talked me down off the ledge.
Posted: Thu May 28, 2020 8:33 pm
by cape man
What's the brewery for the Falcon Smash?
Posted: Thu May 28, 2020 10:37 pm
by Dan_Smullen
cape man wrote: ↑Thu May 28, 2020 8:33 pm
Triple Crossing. Here in Richmond.
Posted: Thu May 28, 2020 11:58 pm
by OneWayTraffic
Good idea to make sure the inside has good glass over the same area as the patches.
Build on I suppose.
Posted: Fri May 29, 2020 7:23 am
by Jeff
Great looking dinner Dan!!! Nice progress as well!!! Jeff
Posted: Wed Jun 10, 2020 8:29 am
by Dan_Smullen
Seems like a milestone...
Block sanded with 120 before applying 2 successive coats of high build primer. Only have coated the transom, and starboard bottom half and side. Used a quart kit mixing 1:1 to get both coats. Best results rolling came from using a 1/8" nap foam West System roller.
Let it cure overnight, then block sanded with 180. For the most part, it feels beautiful. The low spots show themselves as stippling left behind from from the roller.
I think the best thing to do is to hit these with skim coats of fairing compound, then block sand in preparation for surfacing primer.
Posted: Wed Jun 10, 2020 8:50 am
by Jeff
Great milestone Dan, congrats!!! Jeff
Posted: Wed Jun 10, 2020 8:56 am
by Dan_Smullen
Thanks Jeff! The other side is still green and purple!
Posted: Sun Jun 28, 2020 4:14 pm
by Dan_Smullen
In the race to flip, I am focusing solely on the bottom. Mostly focusing on the bottom just because I want to keep moving, knowing a diy paint job could easily turn into a 2 month ordeal for me. Objectively, if I were to paint the transom with the sides, eventually I'm going to have to tie in the motor well sides, which would require touch up; might as well just paint it all at once sometime in the future.
3 coats of high build primer have been spread and sanded with 220, pretty much everywhere on sides and bottom. Bottom now has 3 coats of S3 Yacht Primer, rolled on in succession, with a hour or two in between for the previous coat to dry to the touch. These Wooster Pro roller covers did very well.
Primer initially rolled on fairly thin with lots of bubbles,
but most of them quickly dissipated and leveled themselves out.
I'm optimistic these coats will sand out well with 320, anticipating a few spots that need attention with additional fairing compound. I took the plunge last week and bought a quart of Awl Fair. Certainly not the cheapest option, but I'm always curious to see what is special about materials that are consistently recommended by professionals. I used a little bit of it. It's red, so that's a difference. The little bit I used seemed to go on a little more smoothly, maybe even a little less viscous than some of the other brands I've tried. All that to say, I think this should help me make short work of the few remaining low spots.
Hope to buy some paint this week! Looking at bright whites for the bottom, Fleet White or Stark White, but not quite sure yet.
Originally, I anticipated flipping by March.
, but getting done in July is looking pretty good.
Posted: Mon Jun 29, 2020 10:34 pm
by OneWayTraffic
Looking good. I was at one stage thinking I might flip it the first summer.
Don't spend too much time worrying about the bottom; you'll never see it after the flip.
Posted: Tue Jun 30, 2020 7:33 am
by Jeff
Nice Dan!!! Jeff
Posted: Thu Jul 09, 2020 8:54 pm
by Dan_Smullen
A few spots sanded through. Ordered paint for the bottom, but shipping was delayed for a week, and will arrive while we're out of town.
Its been a good opportunity fill a few spots with Awl Fair, and sand more. Skimmed lightly and sanded more which got rid of most of the guide powder seen in the pic. It feels good...
All has been sanded with 320. Will coat with fresh coat of primer before spreading top coat.
Posted: Fri Jul 10, 2020 4:28 am
by OrangeQuest
Looking very good!!
Posted: Fri Jul 10, 2020 11:25 am
by FluidDynamic
I had a few sand thru areas with my primer or at least you could see through it a little. I think if there is a thin layer of primer you should still be okay. I went ahead and topcoated mine and it looks good. No issues that I have seen nor are there any variations in the topcoat color.
Posted: Fri Jul 10, 2020 8:39 pm
by Dan_Smullen
Thanks, Gents!
FD, I appreciate the advice. Yours turned out great. A few spots are more exposed more than I think is fine, and it's a good opportunity to get products in line, prepping for Alexseal top coat!
Posted: Sat Jul 11, 2020 7:10 am
by Bogieman
Very nice!
Posted: Tue Jul 28, 2020 8:47 pm
by Dan_Smullen
The priming saga continues...
I used the necessity of more primer as the opportunity to get the paint products in line with what I'm using for top coat.
I feel like the S3 epoxy primer is a great seal/barrier coat, but this Alexseal finish primer will make a comfortable substrate for Alexseal 501 top coat. After a hose down wash, the S3 shows a smooth even surface which I believe is ready for finishing.
I tried to skimp, and only bought a quart of primer, including 1:1 converter = 2 quarts of material. With this I got 2.5 good coats, rolled. Sanded with 320 over quide coat and quickly broke through in several areas. After a Friday evening beer I resolved to buy a gallon of surfacing primer, and sand to as near as perfection as possible with 120 to prep for 3 or 4 solid, sprayed, coats. Gallon of primer and gallon of converter will be here tomorrow, and hop to get it all laid down and sanded before the weekend to spray top coat.
Lessons learned...?
Don't skimp on material. Get plenty of primer. Use guide coat religiously and let it tell you when it's time to apply the next layer. Also learned, 120 grit on a block is great prep for primer, sand surfacing primer with 320 with a DA is what is needed in prep for paint. I hope...
Posted: Tue Jul 28, 2020 11:11 pm
by FluidDynamic
I'm about to be back at the torcher board myself. I think this time, I may put 4 to 5 coats of primer on before I sand. The key is to get it thick enough. Seems like I just kept sanding off the primer.
Posted: Wed Jul 29, 2020 7:56 am
by Dan_Smullen
FluidDynamic wrote: ↑Tue Jul 28, 2020 11:11 pm
You might want to try high build. I wonder though if it will be better over the S3 rather than under.
But you're right, 4-5 coats of every layer to provide enough substrate to level with out breaking through. Nothing more frustrating than filling up the shop vac with expensive primer, only roll it back on and do it all over again.
Posted: Wed Jul 29, 2020 10:26 am
by fallguy1000
No no no.
The epoxy primers are much harder than fairing compounds. And a 2 mil paint build is 0.002" thick.
Much better to evaluate with closed eyes and fingers. Walk the hull and feel for deviations. Then put a trowel edge over those areas to determine fill needs.
Posted: Wed Jul 29, 2020 10:46 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed Jul 29, 2020 7:56 amNothing more frustrating than filling up the shop vac with expensive primer, only roll it back on and do it all over again.
I didn't spend a ton on my primer but felt the same frustration in drying time. Each stroke of the sandpaper felt like it was costing me another week. Hang in there; boat will be right-side up before you know it and this will all be a distant memory/recurring shoulder pain.
Posted: Sun Aug 02, 2020 1:51 pm
by Dan_Smullen
Man it has been a slog getting primer to a point that I was happy with, all in preparation to spray a few coats of Alexseal Stark White. On the bottom...
I sprayed 4 coats of Alexseal finish primer, then machine and block sanded guide coat with 320. This material was easy to sand, and left a silky, uniform surface.
Gave her a bath and lightly scrubbed with a scotch brite pad.
Started as early as possible this morning in a 81 degree garage. Mixed 24 oz of paint, and added 6 oz of slow reducer, for a mix of 1:1:.5.
Coverage was beautiful on the bottom, but when I got to the bow I got a little cocky with the thin material and got a few runs on the bow.
Best advice I got was to keep on spraying and deal with them later, so that's what I'm going to do. I imagine fixing a run will involve a razor blade and some 800 grit or finer paper. I'm open for suggestions. Also, have a number of dust nibs and some overspray. Might try to deal with them or just live with it. It’s the bottom. Right?
Overall, I think it will work, and hope to be ready to flip next weekend.
Posted: Sun Aug 02, 2020 11:14 pm
by FluidDynamic
No matter what I tried a little dust was present. Short of a controlled environment, i think most people end up with some dust. Looks great.
Posted: Mon Aug 03, 2020 2:11 am
by Fuzz
Little dust or not it sure looks good.
Posted: Mon Aug 03, 2020 9:47 am
by VT_Jeff
Be a shame to flip that boat over with the bottom looking that good!
Did you have experience with a sprayer before this?
Posted: Mon Aug 03, 2020 11:41 am
by Dan_Smullen
VT_Jeff wrote: ↑Mon Aug 03, 2020 9:47 am
Good point Jeff! Hoping the fish will like it!
I’ve sprayed a few things before. Painted cabinets and such. I used the nicest gun our shop has, and picked a lot of brains about how to shoot it. Alexseal has comprehensive product information about mixing as well as a local sales rep that is as reachable as the guys at BBC. Product, I think, is exceptional to shoot.
Posted: Mon Aug 03, 2020 1:01 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Aug 03, 2020 11:41 am
Well I know all too well that paint-job photos can be deceiving but that does look exceptional, nicely done.
Posted: Mon Aug 03, 2020 1:23 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Aug 03, 2020 1:01 pm
There is some deception. Some haze at spray overlap, bugs, dust, dog hair, etc... garage things.
But overall it will pass. Thanks for the compliments.
Posted: Mon Aug 03, 2020 8:16 pm
by Browndog
Looks more better than good Dan!
Posted: Wed Aug 05, 2020 9:32 am
by BB Sig
Looks great!
Posted: Wed Aug 05, 2020 3:29 pm
by cape man
I'm jealous.
Posted: Fri Aug 07, 2020 4:22 pm
by Dan_Smullen
Thank you all! Once all of you have shown me the potential of what these boats can become, I have no choice but to try to keep up!
Shes flipped! 10-1/2 months after the jig hit the floor.
https://youtu.be/5yI20HjukE0
A group of bros braved the most torrential downpour of the summer, which cleared as all arrived. I fueled them with pizza and local beer, and we got it done in about 20 minutes. Utilized the soft grass on the uphill side of our driveway.
This is a WIIIIIIIIIIDE 19 footer for sure!
Back into the garage, facing the other way for round 2!
Posted: Fri Aug 07, 2020 6:18 pm
by VT_Jeff
Massive milestone, congrats! It does look Uuge!
Inside glass and stringers next?
Posted: Fri Aug 07, 2020 6:33 pm
by Dan_Smullen
VT_Jeff wrote: ↑Fri Aug 07, 2020 6:18 pm
Yeap! Think so!
Posted: Fri Aug 07, 2020 9:35 pm
by Browndog
They always seem to look bigger after they are flipped. When you have to climb in and out to glass the interior it will really feel big.
Posted: Sat Aug 08, 2020 1:01 am
by BarraMan
Wow, that boat looks BIG!
My 'little' boat is only 22' x 8' - looks smaller than that one. Funny how looks can deceive!
Build on!
Posted: Sat Aug 08, 2020 6:37 am
by Jeff
Congrats!!! Great milestone!!! Jeff
Posted: Sat Aug 08, 2020 7:24 am
by Dan_Smullen
Browndog wrote: ↑Fri Aug 07, 2020 9:35 pm
Only for the next 12 months or so.
BarraMan wrote: ↑Sat Aug 08, 2020 1:01 am
8’ unusually wide on a 19’, but we will appreciate the extra hip room between the console and the gunwales. I bet a 22x8 will run more efficiently though.
Posted: Sat Aug 08, 2020 3:24 pm
by Fuzz
Is the transom cut for a 20 or a 25 inch shaft? Looks like a deep cut out from here.
Posted: Sat Aug 08, 2020 4:19 pm
by Dan_Smullen
Fuzz wrote: ↑Sat Aug 08, 2020 3:24 pm
I agree! It does look deep. i.e. too close to the water. It’s cut out per plans but I’ve been contemplating how to contend with the transom.
Earlier today I was looking at it considering adding 5” and commit myself to a long shaft outboard.
Posted: Sat Aug 08, 2020 5:23 pm
by Fuzz
That boat looks like an offshore boat to me and I would want at least a 25 inch for it. No idea of what you have planned for it.
Posted: Sat Aug 08, 2020 5:40 pm
by Dan_Smullen
Fuzz wrote: ↑Sat Aug 08, 2020 5:23 pm
Yeah man. I’m sold. Inshore and near shore for me and this boat.
21” from the keel to the bottom of the cut out. Transom is unfinished so adding won’t hurt too much.
Thanks for talking me into it!
Posted: Sat Aug 08, 2020 5:41 pm
by Fuzz
Posted: Sun Aug 16, 2020 11:18 am
by Dan_Smullen
Taping inside seams. 2 layers on the chines, 3 at the keel, all set in green wood flour fillets. Learning to let the fillets cure longer than I might think is acceptable. Kind of hard to tell, but in the last pic of the transom there is a layer of cloth on the transom under the transom clamp. Happy to have saved the cutoffs from when I glassed the outside of the transom, they fit perfectly with little trimming under the clamp!
Undecided about transom modification. Can see the potential benefits, but not sure I have the stomach for the work.
Fillets, it seems, would be best laid using fast epoxy, even though I'm using slow to wet out the tapes. I had concerns about mixing hardener types on top of one another, but I've since been told that this is not a problem.
Cutting big sheets of glass today.
Posted: Sun Aug 16, 2020 11:54 am
by fallguy1000
I like my fillet resin to be thick enough to not sag, but uncured enough to 'grab' the tape.
If my laminating fails, it won't be my tape seams.
Posted: Mon Aug 17, 2020 1:33 am
by TomW1
Dan_Smullen wrote: ↑Sat Aug 08, 2020 5:40 pm
That boat looks like an offshore boat to me and I would want at least d25 inch for it. No idea of what you have planned for it.
I would not worry about it. It is set for a 20" shaft motor and unless you are going far off shore it is not a big deal. To rebuild it up to 25" would require a major rebuild of the transom. With multiple boards and fiberglass added from across the total width of transom to support the boards added to raise the level in the cut out and you will need to build up the side boards. Remember Jacques designs his boats with a bulkhead ahead of the motor to prevent water from coming in from the stern. I know of at least of a couple guys that built to plans that went far off shore and had no problems. Jim W who built the first C19 routinely went far off shore and caught marlin and mahi. He put a 115 Yamaha on his boat.
Posted: Mon Aug 17, 2020 8:03 pm
by Dan_Smullen
TomW1 wrote: ↑Mon Aug 17, 2020 1:33 am
The best way to describe what it will take rhymes with duckery.
I’ve messaged back and forth with Jim a bit and his run in his C19 is impressive.
If I keep the momentum going on glassing I’ll pass on the modification, but give a little time to think about I could dive right in.
Posted: Mon Aug 31, 2020 8:56 am
by Dan_Smullen
No transom mods yet. Keeping progress moving on the inside.
After tapes went down, I laid out all of the interior fiberglass, cut to size, marked edges with a sharpie, and rolled each back up on a roll.
Last weekend, I laid the side and bottom panels on the starboard side. I didn't let the neat coat kick as much as I should have which caused a handful of bubbles I believe were caused by out gassing. Nothing too terrible. I ground out a few and filled with cabosil and chopped strands.
To avoid the same on the port side, I rolled the neat coat the night before, then started in the morning with wood flour thickened epoxy to smooth over rough edges and any remaining holes or imperfections on the inside of the plywood. Ate breakfast, and unrolled each sheet in place. I pinned the side panel sheet up and out of the way, and focused on the lap of the bottom panel at the chine. Had I tried to wet out both sheets at the chine, I surely would have run into bubbles caused by sheets not bedding tight into the corner. Both panels were wet out together. It took about 2 hours, 200 oz of slow cure MarinEpoxy.
I have a few bubbles on this side, but I think they are from little clumps of wood flour that got hard before I could push them flat under the the glass. Will grind and fill as needed.
Time to drag the stringers out and neat coat the bottoms of each.
Posted: Mon Aug 31, 2020 11:18 am
by fallguy1000
Things look good. I think you ought to live with a few paint flaws as am I. The thing I am battling now is a bad back and my hulls are outside and taking on all our damnable rain. My hulls have a few places that are wet as hell and even some leakdowns into areas supposed to be watertight.
Sigh.
In 8 weeks it'll all freeze.
Your boat looks good.
I like to run a smear of cabosil on high tape edges before glassing. I have done enough of the work to know where to expect air entrapment.
I am so curious about the c19s I want to go find some in the gallery now.
Posted: Mon Aug 31, 2020 12:24 pm
by Dan_Smullen
fallguy1000 wrote: ↑Mon Aug 31, 2020 11:18 am
Thank you, Dan! I did the same with thickened wood flour on the tape edges. 2 layers of 12oz with jagged edges can easily trap air I believe.
I like the C19 because it has the classic center console lines. I know Jim Wright built a beautiful version that is still performing well, and I'm a little partial to the one Welleflicker built a few years ago.
http://gallery.bateau2.com/index.php?cat=13680
It is a wide 19' at 96", but will perform well here in the Chesapeake Bay.
Posted: Mon Aug 31, 2020 8:21 pm
by TomW1
Dan_Smullen wrote: ↑Mon Aug 31, 2020 12:24 pm
Your C19 will serve you well. I wish Jim W hadn't taken down his posts and photo's, he thought they were to old after 20+ years. He had pictures of a Marlin he caught and Mahi well off shore from Jacksonville. His boat was powered by a 115 4ST Yamaha and could reach the low 40's at WOT. I think the C19 is great boat for medium conditions and yet if you need to can get you out of trouble, I know the CB can kick up fast at times.
Posted: Mon Aug 31, 2020 8:55 pm
by Dan_Smullen
TomW1 wrote: ↑Mon Aug 31, 2020 8:21 pm
Can’t leave our TomTom and his rig. All the bright work he did looks right at home on his C19 and also has some billfish under his belt.
Posted: Mon Aug 31, 2020 11:00 pm
by OneWayTraffic
A mod to 25" wouldn't be all that hard, not compared to the total amount of work that has gone in it. Messing up the faired outside of the transom would be the biggie. As an alternative you could get a little fixed jackplate.
Posted: Tue Sep 01, 2020 7:08 am
by Browndog
Last week I shipped the Bob’s Machine Shop manual jackplate that I took off of the FS19 that I built to Dan. He just received it. I traded it to him for a fishing trip on the Bay for my brother and I. Looking forward to Dan’s progress and to some fishing at the Bay Bridge Tunnel for Rockfish at some point with him in his newly finished boat.
Keep it up Dan! Go Dan!
Posted: Tue Sep 01, 2020 8:04 am
by Dan_Smullen
Browndog wrote: ↑Tue Sep 01, 2020 7:08 am
These 3 smiley faces represent Jordy, his brother and I holding up 26” sheepshead at the CBBT.
Thank you again sir! We’re moving!
Posted: Tue Sep 01, 2020 9:14 am
by Jeff
Nice!!! Jeff
Posted: Wed Sep 02, 2020 1:08 am
by fallguy1000
Jack was best for the situation.
Posted: Wed Sep 02, 2020 5:38 am
by TomTom
Dan_Smullen wrote: ↑Sat Aug 08, 2020 7:24 am
Ill keep you posted
Your boat looking great - love the chines and paintwork looks awesome.
Posted: Sun Sep 20, 2020 1:28 pm
by Dan_Smullen
TomTom wrote: ↑Wed Sep 02, 2020 5:38 am
Ill keep you posted
Thank you as always. Can't wait to see your girl back up on step!
The Stringer show continues...
Pulled a pair of strings athwartship, one forward, one aft, and shimmed the hull a little on the starboard to get a little bit of wind out of her.
Cut limber holes forward of each frame slot and coated the bottom edges and limber holes with a few coats of neat epoxy.
Spent a fair amount of time putting them in, and taking them out, using tempory frames and blocking checking for hard spots and level. After removing 3/8" or so from the bottom edge at the back of each, I set them on shims fore and aft, and spot welded each into place with thickened epoxy. With only a few short beads of cured glue, it was remarkable how much rigidity they added to the hull.
Ran fillets on the outboard port stringer and taped each side for the first time, need to do the 2nd run this afternoon. I bet I will have 12 hours in filleting and taping on all 4 stringers, as the first will have taken close to 3. One of many examples of how the time that goes into these builds grows and grows, but as the time grows, so do the milestones!
Posted: Sun Sep 20, 2020 3:24 pm
by fallguy1000
Keep on keepin on!
Posted: Sun Sep 20, 2020 9:02 pm
by Dan_Smullen
fallguy1000 wrote: ↑Sun Sep 20, 2020 3:24 pm
Keep on keepin on!
Just. Keep. Building.
I have a feeling these projects scale up exponentially the larger the boat.
Posted: Sun Sep 20, 2020 9:52 pm
by fallguy1000
Dan_Smullen wrote: ↑Sun Sep 20, 2020 9:02 pm
Keep on keepin on!
Or in the case of a catamaran, multiply by two.
Yesterday, for example, I tried the steering culinders the seastar tech specified. They don't fit. Neither one!
Posted: Sun Sep 20, 2020 9:59 pm
by Dan_Smullen
I can’t imagine, sir. You have the fortitude for it for sure.
Good news is, get it figured out for one hull, then just repeat on the others
Posted: Mon Oct 05, 2020 9:37 pm
by Dan_Smullen
Only appropriate, the morning after the late night sesh in the garage, taping the last stringer, I got the Fb memory notification laminating the stingers on the floor last year. It only took them a year to be fixed in their final resting place. Happy to have these done. I averaged about 16 oz of epoxy on each layer of tape. Each layer of tape was about 15' long. This is in addition to the ounces that went into putty and fillet material.
Outboard side of outboard starbourd stringer has a pile of air bubbles that will be ground out and covered. Limber holes need to be opened and sanded smooth. Nothches in stringers need to be widened because I got a deal on 12 sheets of 12mm okuome. Existing notches are for 3/8. No big deal. Will take care of these before cutting and installing frames.
Re: C19 in Richmond, VA
Posted: Sun Oct 11, 2020 5:32 pm
by Dan_Smullen
Got a sweet deal on 12 sheets of 12mm 1088, on the condition I took the whole stack, which I did. A few sheets had some damage and one was warped, but this will get me through the end. Plans call for mostly 9mm, but I'll use 12 for all of it, Sole, frames and deck.
Cut the frames on the CNC, did a little grinding where necessary, and sealed the bottom edges with epoxy. Need to re-up on materials this week, but after frames are glassed in and cleats in place, I'm not sure what to tackle next. Thinking gas tank, maybe? What do you all think?
Posted: Sun Oct 11, 2020 7:31 pm
by TomW1
Love the C19. Since you have all the frames in, now is the time to start running your PVC conduits for electrical wires and control lines. Also the gas tank and gas line placement. Do not skimp on the size of the conduits or the number of them, you will be surprised at how many and how large they need to be to get things through them. Use electrical sweep 90's not plumbing ones they will make pulling the wires and control cables easier.
Posted: Sun Oct 11, 2020 8:53 pm
by Dan_Smullen
TomW1 wrote: ↑Sun Oct 11, 2020 7:31 pm
Roger that. Plans give good direction on conduit layout, and will go with that.
Posted: Mon Oct 12, 2020 11:04 am
by VT_Jeff
Awesome progress, Dan, has to feel great to have another big task behind you! You just passed me again, btw; my stringers are filleted in, not glassed yet(I only have 2, not 4). My "72 hour window" is closing, hoping to glass tonight. Keep up the great work!
Posted: Mon Oct 12, 2020 6:16 pm
by Dan_Smullen
Stay on it Jeff! Good luck getting them glassed in this evening.
We’re pushing each other! A little peer pressure pushes us toward excellence!
Posted: Mon Oct 12, 2020 8:48 pm
by VT_Jeff
Got it done with my nephew. Boom!
Posted: Mon Oct 12, 2020 9:05 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Oct 12, 2020 8:48 pm
Hi five Bro!
Posted: Sun Nov 15, 2020 8:13 pm
by Dan_Smullen
Posted: Sun Nov 15, 2020 9:00 pm
by fallguy1000
Looks good Dan
Posted: Sun Nov 15, 2020 9:33 pm
by VT_Jeff
Holy cow, that's got to be nice to be looking back on! Once again, way to push through! Work looks great. Cleats and tubes will be a vacation!
Posted: Sun Nov 15, 2020 10:08 pm
by Dan_Smullen
Thanks, Dan. I was worried about the gaps, but got over it. Heavy fillets of wood flour and cabosil. Should be fine.
VT_Jeff wrote: ↑Sun Nov 15, 2020 9:33 pm
A cake walk, Jeff! A cake walk...
Posted: Mon Nov 16, 2020 10:00 am
by Jeff
Nice work Dan!!! Jeff
Posted: Tue Nov 17, 2020 6:23 am
by Browndog
Coming along nicely! Things will move along pretty quick now for a little while.
Posted: Tue Nov 17, 2020 12:41 pm
by Dan_Smullen
Browndog wrote: ↑Tue Nov 17, 2020 6:23 am
I like the way you think, BD, and appreciate the encouragement!
Posted: Thu Nov 19, 2020 5:28 am
by OneWayTraffic
Probably about halfway done now, if you spend the normal amount of time on finishing details.
Posted: Mon Dec 28, 2020 9:26 pm
by Dan_Smullen
OneWayTraffic wrote: ↑Thu Nov 19, 2020 5:28 am
I'm thinking 5/8 of the way.. What's that converted to metric? 15.5mm?
How about the Doldrums of the Bilge?
I think what has slowed me down is being at a point where decisions need to be made, and there is a lot I don't know about fuel and mechanical systems. Thankfully, I have some competent local resources to whom I can turn when I need to get talked up to the next milestone.
An acquaintance, Kevin Agee, recently completed this 27 foot beauty just down the road, and he has been a text away for the last few weeks. I encourage you all to take a look.
https://dudleydix.blogspot.com/2020/07/ ... ssion.html
He suggested a 1/2 plywood deck in the bilge on which the gas tanks will sit. This part is glassed on the bottom, set in a bed of peanut butter along the edges, soon to be filleted and tabbed in place. This large panel will sit between frames C and D, which will accommodate a 27 gallon aluminum tank. The smaller "1/2 panel", between B and C, glued in place this evening, will support what I suspect will be about a 12-15 gallon tank. I've been waiting to get these panels in before turning a local fabricator loose on building the tanks.
All the time I've spent crawling around in the bilge has allowed me to think about where floatation will be. I don't have a complete plan yet, but I'm sure I only want it in completely sealed compartments. This center cavity between frames D and E looks like a nice voluminous compartment for foam, but the limber holes presented a challenge. I used the opportunity to try my had at mold making, and utilized seasonally appropriate mold material; and empty wrapping paper tube. Covered it in plastic, and laid up 2 layers of 12 oz tape over it.
This was then glued into a bed of peanut butter, and too will be tabbed in place.
I'm visiting the local Suzuki guy this week with a handful of PVC pipes and fittings to get a sense of how all of the connections will fit, and whether or not they will pull through 2" tube.
I'm looking forward to laying down some cleats on top of the frames soon.
Happy New Year, Fellas!
Posted: Fri Jan 01, 2021 7:34 pm
by VT_Jeff
Best use of wrapping paper to date, great work!
Posted: Sun Jan 03, 2021 7:17 pm
by fallguy1000
Foam above a foot up the hullsides might even keep her upright floating sunk. Required stability in manufactured boats under ?21' or so.
Posted: Mon Jan 04, 2021 6:51 pm
by TomW1
Dan do not use white water line PVC pipe for your curves. Instead use gray electrical PVC for your curves. There is a large difference and the electrical PVC allows for easier pulling of wires and mechanical apparatus. For your motor controls you might even want to consider 2.5" tubing. Don't use less than an 1.5" for fuel line.
Your boat is looking good, just take your time coat every thing in epoxy and fiberglass. There is a C19 down in Florida that was the first one built in the mid-90s that is still going strong. He powered it with a Yamaha 115 but a 90 would be plenty.
Posted: Sun Feb 07, 2021 9:31 pm
by Dan_Smullen
Just a little bit more than a month since last post.
Took some time off to do house work, and had the pleasure of mild case of the Covids. We had our floors redone and my wife an I up-cycled our front room into a at home work area. While the floors were worked on, all the furniture went into the garage, which dictated the boat was rolled out to the driveway for a few weeks. I'm glad to have ber back in side, and at least the first phase of home improvement projects for the year are behind us.
I finished the drawer boxes and shoe molding and crown this weekend, but still need drawer fronts. White oak floating shelves, coated with Rubio Monocoat feel nice to the touch.
Temporary tarp support panels were cut per plans, which will be helpful for pulling in the sides when it's time to set the above sole frames.
Gas tanks are being made. Gas tank bed is good to go: 1/2" fir ply, 12oz bi-ax on both sides, bedded in a generous bead of epoxy thickened with wood flour.
Spent this afternoon fitting 1-1/2" x 2-1/2" douglas fir cleats which have a3/8" deep dado in the bottom. This extra height affords me a few more inches of gas tank height and feet above waterline. Probably some extra weight there, but this has to be better than fitting 900 1x cleats along the sides of stringers and frames.
As well as getting caught up on my build, I'm looking forward to getting caught up with ya'lls as well!
Happy New Year, fellas!
Posted: Sun Feb 07, 2021 10:48 pm
by Fuzz
Both AA and I did our cleats that way. It sure makes that job easier in my mind.
Posted: Mon Feb 08, 2021 8:57 am
by VT_Jeff
Dan_Smullen wrote: ↑Sun Feb 07, 2021 9:31 pm
Agreed. Root canal may be in the race as well.
I am usually on the constant lookout for shortcuts, not sure why I let this one pass by. I'm guessing that a deep dado and good adhesion on the sides of the stringers is the key.
Glad to see you back at it and knocking out some sweet home improvement projects at the same time. Floating shelves look great!
Posted: Sun Feb 14, 2021 11:20 am
by Dan_Smullen
VT_Jeff wrote: ↑Mon Feb 08, 2021 8:57 am
Much appreciated Jeff! They were fun. First time using Rubio as well. Pecking at the keyboard in the new office space currently, and it feels almost as good as crawling around the bottom of the boat racing to spread rapidly solidifying peanut butter.
It dawned on me last night as I wess fitting the few forward frame cleats as to how close I could be to setting at least one piec of deck. These cleats will be forward of station 2, and under a hatch/seat. Intentionally higher than the main sole so I can drain this compartment via weep hole onto the sole. While waiting for the gas tanks to arrive, I believe I will focus on this section and work my way toward the transom!
Posted: Sun Feb 14, 2021 11:49 am
by fallguy1000
Glad you got over the Covid crap.
Looks good. That fir is fancy lookin stuff for cleats, but at least it won't break on you.
Posted: Sun Feb 14, 2021 12:37 pm
by Dan_Smullen
fallguy1000 wrote: ↑Sun Feb 14, 2021 11:49 am
Thanks, Dan. I was fortunate to have a light case. 4 of us in the shop had it. Mild cases and one guy asymptomatic.
Cypress or white cedar would’ve been preferred, but cost and a availability respectively helped me land on the fir. Nice and straight, good grain, but kinda heavy.
Posted: Sun Feb 14, 2021 1:45 pm
by fallguy1000
Dan_Smullen wrote: ↑Sun Feb 14, 2021 12:37 pm
They say viral load can contribute to the severity, but I don't understand that. It seems like the container would be more of a factor.
That will be the day when you are ready and deck her.
Posted: Sun Feb 14, 2021 8:52 pm
by VT_Jeff
I used fir for all my framing, ended up ripping it to half my design height once I started to sense the weight.
Framing/cleats look top notch, no surprise. I can see the staff bringing the champagne from the locker room in prep for the deck celebration!
Posted: Mon Feb 15, 2021 12:26 am
by cracked_ribs
Definitely like that cleat setup...been going back and forth a little on how I will do mine but screwing around with a ton of little fiddly cleats isn't really my idea of a good time. I don't have a table saw with a dado blade or anything but I did build a little routing table that could probably handle the job, especially considering my requirements are for a lot fewer cleats than yours. Probably more comparable to an FS17 or so. Still have to do the hull-sole cleats the usual way, I guess, but still it has to save a lot of time.
Posted: Mon Feb 15, 2021 9:50 am
by VT_Jeff
cracked_ribs wrote: ↑Mon Feb 15, 2021 12:26 am
I was thinking(always dangerous): You could mimic the benefits of the dado'd cleat by taking 2 normal cleats, spaced at the stringer-width, and connecting them with a few blocks("brackets") screwed across the tops. Cover the insides of the cleats and outsides of the stringer with appropriate glue, drop the assembly on, let it cure and then remove the "brackets". Packing tape on the underside of the brackets before screwing on will probably be smart. This provides the same benefit as the dado cleats: no clamping/quick attachment/automatically flush with string top, but will potentially provide more glue area on the
sidesof the stringers, where you actually want it. And it will not raise your sole, which could be a benefit or a drawback depending on desire.
Posted: Mon Feb 15, 2021 3:58 pm
by Fuzz
Jeff's way would work like a champ also. In my case I wanted to raise the deck a little so the dado way let me kill two birds with one stone.
Posted: Mon Feb 15, 2021 7:51 pm
by Dan_Smullen
The few pieces I glued down up forward had no dado. Set them in a bed of goo and did 1/2" radius fillets between the bottom of the cleat and the side of the stringer. Doesn't seem much different than typical side cleat attachment. Don't know if anyone is brave enough to try that assembly on their cleats...
Cracked Ribs, is your rig going to be a low speed planing hull? Not near the forces exerted on the sole/stringers. Router to plow the dados will work too though.
Posted: Mon Feb 15, 2021 8:29 pm
by cracked_ribs
Dan_Smullen wrote: ↑Mon Feb 15, 2021 7:51 pm
Man, I thought it was tricky building my own design with no instructions...at least nobody is requiring me to glue in directions like that! One direction at a time is all I can handle. Down I can do, up I can do, or forward is fine also. All three together, forget it.
"Low speed planing" is probably a good description; I'm sure fillets would be tons of strength without any jointing. Good enough for the C19 is way more than good enough for me. I'd only dado stuff to make it a convenient drop-in item.
Of course if it has to be a drop-in out backward, that's different entirely, and I leave it to your ingenuity to solve.
Posted: Mon Feb 15, 2021 9:14 pm
by VT_Jeff
That's not boatbuilding. That's marine construction surgery!
Were you looking to add height by skipping the dado?
Posted: Mon Feb 15, 2021 9:20 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Feb 15, 2021 9:14 pm
[quote=Dan_Smullen post_id=485111 time=<a href="tel:1613436676">1613436676</a> user_id=81999]
[/quote]
Yes, but also, my table saw is 20 minutes away at the shop, and didn’t feel the dado was worth the drive. These cleats will support the sole in the forward compartment, so having it a little higher than the main sole will allow for the limber holes a little higher.
How do you feel about the strength of the cleat glued to the top of the stringer sans dado?
Posted: Mon Feb 15, 2021 9:43 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Feb 15, 2021 9:20 pm
[/quote]
I think your fillets do the same job: increase the glue area between the sole bottom and the stringer, and resist bending of the stinger by forming an I beam. The closer they mimick cleats, the less you'll sweat when you hit that wake head on at speed!
Posted: Tue Feb 16, 2021 10:00 am
by VT_Jeff
I think it's also important to remember that you're an engineer and that I write business software, btw......I'm probably more qualified to comment on the strength of the durable goods market than on the durability of your framing.
Posted: Tue Feb 16, 2021 11:52 am
by Dan_Smullen
VT_Jeff wrote: ↑Tue Feb 16, 2021 10:00 am
Understood, but we're all in this hobbyist boat building game, and all moderately successful at it, so I value your opinion.
Posted: Tue Feb 16, 2021 12:26 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Feb 16, 2021 11:52 am
Appreciate that, ditto, and more than glad to provide it. so.......
Cleats glued to the sides of the stringers would provide resistance to lateral bending on their own, in space. The fillets, I think, will only provide bend-resistance because they are attached to the sole, so it's the joint with the sole(or your cleat) that will be resisting the lateral bending of the stringers. On the stringer-to-hull joint, we're using fillets and sizable bi-ax tape in place of cleats, which would probably resist a lot of bending in space, even if they weren't joined to the hull.
So I don't know what the correct answer is, but that's the way I view the question.
Posted: Tue Feb 16, 2021 3:38 pm
by TomW1
Dan answering from the page before on the strength of the cleats. Use 1 x 1.5 cleats epoxied to the stringers and frames and clamped in place as the epoxy dries. This will create a box frame and once you glue down the sole a solid box that will prevent twisting and bending. The cheapest way to make all the clamps you will need is to buy some 3" PVC and cut them in 1" pieces and cut out a small section 1" of each one. They will then spring apart and clamp over the 1 1/2" that you need to clamp.
Well good luck, you have a lot of cleats to cut and glue on.
Posted: Mon Feb 22, 2021 8:59 pm
by Dan_Smullen
A few to glue, but I think the continuous pcs will reduce that work by a little.
Feels like a milestone. First piece of sole cut and fit!
Haters will say it's cheating, but I say it's efficient.
Used a laser template system we use at work to shoot a template of the forward sole. We bought the system a few months ago for a specific project, but have been looking forward to using it on the boat ever since the day I ordered it.
Edges beveled as needed for a closer fit.
Need foam and some PVC run up forward before gluing it down.
Posted: Mon Feb 22, 2021 10:23 pm
by VT_Jeff
That's an awesome use of tech right there! Congrats on your first horizontal surface, must feel great to finally have somewhere to stand!
Posted: Mon Feb 22, 2021 10:37 pm
by TomW1
I may be asking a dumb question but why isn't the back edge sitting on Frame A.
Posted: Tue Feb 23, 2021 6:01 am
by Dan_Smullen
TomW1 wrote: ↑Mon Feb 22, 2021 10:37 pm
Good observation. I think this is actually frame B.
I raised this forward portion 5/8”. This is basically the forward compartment floor. Frame B, above sole, will be up against the back edge of this section.
Tabbing to the forward face of above sole frame b will support this floor where it does not rest on framing. I think...
Posted: Tue Feb 23, 2021 8:47 am
by FluidDynamic
Are you planning on cleating on the hull sides like you did in the front? I know it will be stronger, but my plans didn't call for it and I got lazy and didn't do it. I see some people do it and some don't. I'd be interested to hear what the designer says on this issue.
Posted: Tue Feb 23, 2021 8:51 am
by fallguy1000
Progress. Most fun when sole is on.
Posted: Tue Feb 23, 2021 10:08 am
by Dan_Smullen
FluidDynamic wrote: ↑Tue Feb 23, 2021 8:47 am
Yes I do. Cleats get much simpler in the back. Simple bevel on the outside face.
I had similar thoughts up forward; bypassing the cleats. Once everything is glued in with peanut butter and tabbed in place, I think for the bottom of a compartment it would have been plenty strong. But why not make it strong-er.
Posted: Mon Mar 08, 2021 1:17 pm
by Dan_Smullen
Stinger caps are done. Spent as much time as was required to keep them all flat and co-planar, which I believe will be worth the effort as this was my last opportunity to make a flat deck.
A few lateral pieces to add, and cleats on the outside.
Posted: Mon Mar 08, 2021 2:08 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Mar 08, 2021 1:17 pm
Looks appropriately professional Dan, great work! Keep up the steam!
Posted: Mon Mar 08, 2021 6:25 pm
by narfi
Looks good!
This is a good time to go back over your hull lamination schedule and make sure you have all the layers you are supposed to have everywhere, glass and tape, etc....
It is heart wrenching to discover you left a layer out after its all closed up... ask me how I know
Posted: Mon Mar 08, 2021 9:31 pm
by TomW1
Looks good Dan, now on to the frames. Agree double check every thing before starting to close it up. I almost goofed on my rebuild.
Posted: Tue Mar 09, 2021 6:32 am
by Dan_Smullen
Sage advice, fellas. It could be easy to overlook something simple amid the excitement of closing up the bilge!
Posted: Tue Mar 09, 2021 7:47 am
by Browndog
Looking good Dan!
Posted: Tue Mar 09, 2021 9:36 am
by FluidDynamic
Looks great.
Posted: Tue Mar 09, 2021 8:08 pm
by Dan_Smullen
You and BD kinda miss being at this stage, don't ya?
Posted: Tue Mar 16, 2021 10:13 pm
by Dan_Smullen
Picked up some big jewelry from a local fabricator today.
Forward tan dropped right in the hole, aft tank well has some errant glass in the way that needs attention with a flapper wheel before the tank will set. 40 gallons total.
Posted: Wed Mar 17, 2021 1:13 am
by Fuzz
Nice bling
And having two tanks sure gives you options.
Posted: Wed Mar 17, 2021 1:52 pm
by TomW1
Hey looking good! What size motor are you planning on. A 115 will push you over 40, so maybe a 90? The way the lag time are on motors think on ordering early. One of the guys is still waiting and may not see it for another 2-3 months.
Love the C19's, Tom
Posted: Wed Mar 17, 2021 2:24 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Mar 16, 2021 10:13 pm
Those look awesome Dan, great milestone getting those done. I'm casually curious what drove the 2 tanks instead of 1 decision and how it works: are they in parallel, series, does one empty before the other starts drawing or are they drawn together?
Posted: Wed Mar 17, 2021 4:14 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed Mar 17, 2021 2:24 pm
I'll let you know when I figure it out. I envision independent lines from each tank to a valve on the uphill side of the fuel filter, mounted inside the transom. When it's time to switch tanks, switch the feed with the valve. I think it could be done without the motor knowing it switched.
Main compartment can only accommodate 24 gallon tank with comfortable clearance, which isn't enough in my opinion. The forward tank is 16. Chesapeake Bay Bridge Tunnel is 13 miles long, and an 18 mile run from my inlaws house. A little capacity will be comforting.
TomW1 wrote: ↑Wed Mar 17, 2021 1:52 pm
Love the C19's, Tom
Thanks, Tom! 115 is what I have my eye on. Suzuki makes a 140 too.
I wish I was ready to order an engine, but my wife still needs some convincing.
Posted: Wed Mar 17, 2021 5:30 pm
by joe2700
Dan_Smullen wrote: ↑Wed Mar 17, 2021 4:14 pm
Many fuel filters have 2 inputs(and ouputs). I put ball valves on each input and capped off the 2nd output on mine. For me the second input will just be for a portable tank, but you could do the same with 2 internals.
Imgur Album
Posted: Thu Mar 18, 2021 8:00 am
by TomTom
A 90 HP FICHT Ram gave me about 27 kts on my C19. I think the 115 will be a good choice. Unless it weighs the same I would start to worry about the 140 being a little heavy.
Have you kept console in same place as plans?
Posted: Thu Mar 18, 2021 2:34 pm
by Fuzz
I think the Suzuki 115 and 140 both weigh the same. The problem would be having enough self control to keep the speed down to a reasonable amount.
Posted: Thu Mar 18, 2021 4:29 pm
by TomW1
Dan let me run the numbers through my motor/prop calculators to see if the 140 or the 115 is the better choice for you. It will give you top speeds and the prop you will need with in one pitch if not right on. If you use PT Props they will exchange for $75. i know of one guy that spent $2000 on props before he got the right one.
I know you are still you are still in the early stages of your build but you probably have an idea of how you are going to fit it out.
Any way here is what I need.
Boat hull: I will take from study plans and add 75lbs for builder inefficiency
Console: I will add 150 for this
Will you use hydraulics or standard steering. I have weights for both.
Lighting, wiring and electronics: I have a number for this.
People:
Gas:
Water if you have bait wells:
Coolers and Ice:
I have a number I add for fishing gear, safety gear, etc:
Miscellaneous: Anchor, rope, and anything that has not been included else where, I add a number here
Are you going to add a T-top or any other attachments I have not mentioned?
Well when you have the time do this it does not have to be done now. but I will be honest one of the builders I have done the calcs for on a Suzuki is looking has been waiting for 3 months and is looking at maybe another 2-3 months wait. Once you have decided on which motor, after I run the numbers, you may want I would order it, or buy it if in stock. There are ships sitting off California and it could be on one of them so he could get it sooner, hard to tell. Who knows?
Buy the way I love the C19 even had the wood to build it, but had the chance to buy Cracker Larry's OD18 at a great price and did it.
Regards, Tom
Posted: Thu Mar 18, 2021 4:39 pm
by TomW1
Fuzz wrote: ↑Thu Mar 18, 2021 2:34 pm
Fuzz a 115 powers the C19 in the low 40's at max and is very nice for the boat. JimW had nothing but good things to say about it with his C19. He took his C19 offshore Florida and to the Gulf Stream catching Marlin and Mahi Mahi. He still has it and did a repaint a few years ago. He was also the first one to build a C19. Sort of funny in getting ready for working up Dan's numbers the 140 weighs less than the 115.
Posted: Sun Mar 21, 2021 7:54 pm
by Dan_Smullen
TomW1 wrote: ↑Thu Mar 18, 2021 4:39 pm
Thank you, Tom. I'll take you up the calcs when I get a little closer. Last time I checked, I think I recall the 140 as more thirsty than the 115 which might not be worth it.
I've picked Jim's brain quite a bit once we connected on FB. Great boat he's got there.
Tanks are in after minor surgery on some heavy glass that was in the way. Hence the dust...
Got the first 2 of the last 6 cleats in today.
Posted: Mon Mar 22, 2021 12:13 am
by TomW1
Dan_Smullen wrote: ↑Sun Mar 21, 2021 7:54 pm
I agree with you on the 115 a Yamaha 115 pushes JimW's C19 into the low 40's at max if you get into the upper 40's you will have to double up the fiberglass on the bottom. That should be plenty for you. And agree the fuel savings is not worth going for the extra HP. I'll run the numbers with the 140 just to see how much you gain out of curiosity, mine as much as yours.
Dan you also be able to get a higher pitched prop with the 2.49 drive ratio of the Suzuki over the 2.15 of the Yamaha. This will increase your speed some. I will tell you what to get when I do the calcs.
Posted: Mon Mar 22, 2021 1:29 am
by TomW1
Dan I lost a post to you. So here goes again. You need to turn that rear tank around badly. When you are on plane there may be 4" of gas at the back but only 1" at the front and it won't be long till it is sucking air. If it is at the back it will be able to pick up the gas for quite a while. The gas lines can be brought together after they passes through the frame. It doesn't matter if they are pointing port or starboard. You need to bring them together at some point to a y-valve so you can switch between the front and rear tank. I was going to hide mine behind a door in the console. Here is a y-vakve example:
https://www.amazon.com/Metaland-Brass-S ... =8-13&th=1
Regards, Tom
Posted: Mon Mar 22, 2021 6:12 am
by Dan_Smullen
The pic of the tanks is taken from the bow. Forward tank is the smaller. Fill for the larger tank is forward, but the pick up is aft. Will that address the potential starvation issue?
Posted: Mon Mar 22, 2021 2:14 pm
by TomW1
Okay I am oriented now so definitely
Posted: Sun Mar 28, 2021 9:03 pm
by Dan_Smullen
Mandatory Sunday evening weekend progress post...
Done with cleats. Laminated the forward bent cleats in place using 4 layers of 1/4" thick fir.
Marked them for DWL while still in place, but brought them to the cluttered bench to plane them to the water line.
Easily glued/filleted them in pace once shaped.
Finally decided on a chase tube configuration. I've had too many people tell me to use larger tube than 2-1/2", so went with a run of 4", and customized the bell of the elbow to fit within the footprint of the console.
Funny, VT Jeff mentions over complicating things, which is exactly what I was thinking, heat gun in hand, pvc in a clamp, making it look like a urinal for her. I'm sure there is a better way, but I'm going with this. Will stilla have one 2-1/2" run going back on the port side just for fun.
Unrelated to the boat, I finished my wife's cutting table, and have been staying busy in our shop. Custom 1-1/2" round handrail returns for the end of a complicated commercial project. Honestly, without the epoxy knowledge gained over the last year and a half, we wouldn't have thought about gluing the return blanks up like this to be machined. Always learnin'!
Posted: Sun Mar 28, 2021 9:49 pm
by VT_Jeff
Probably safe to park a small pickup truck on those cleats, those look nice and stout! The pvc looks straight out of a catalog, nice shaping.
That's a sweet desk! Cutting as in sewing etc or something else? You and narfi are leading the "keep the family happy during the build" awards!
Posted: Mon Mar 29, 2021 12:07 am
by TomW1
Nice work Dan. Love the cutting board for the wife.
Posted: Mon Mar 29, 2021 8:21 am
by VT_Jeff
You should definitely patent the "Herinal" btw, you could be a modern day Thomas Crapper if you play your cards right.
Posted: Mon Mar 29, 2021 9:24 am
by Dan_Smullen
VT_Jeff wrote: ↑Mon Mar 29, 2021 8:21 am
That’s golden, Jeff.
Posted: Mon Mar 29, 2021 9:57 am
by Jeff
Posted: Sun Apr 11, 2021 10:12 am
by Dan_Smullen
VT_Jeff wrote: ↑Sun Mar 28, 2021 9:49 pm
Cutting table for sewing. Best to keep the family happy. Might be the only reason they keep me around.
First bit of expanding foam poured and trimmed, and finalized plumbing for up forward and gas tank fill and vent hoses.
Coat of System worthwhile in the middle compartment? Will likely add an inspection hatch in the forward compartment.
Posted: Tue Apr 13, 2021 1:08 pm
by Dan_Smullen
Dan_Smullen wrote: ↑Sun Apr 11, 2021 10:12 am
Posted: Tue Apr 13, 2021 3:49 pm
by VT_Jeff
If that's the case then you should slow-roll those deliverables to stretch out your welcome!
Chase work looking great!
Posted: Wed Apr 14, 2021 9:21 am
by Dan_Smullen
VT_Jeff wrote: ↑Tue Apr 13, 2021 3:49 pm
Thank you. I'm in awe as to how rigid the forward sweep was before buried in foam, and now, even more so.
Posted: Wed Apr 14, 2021 10:15 am
by fallguy1000
You know #1 is not required to go into the blackwater tank.
Why scupper when you can herinal?
Things look good. Build on!
Posted: Wed Apr 14, 2021 10:37 am
by Dan_Smullen
fallguy1000 wrote: ↑Wed Apr 14, 2021 10:15 am
Took me a minute...
Thanks, FG!
Posted: Wed Apr 14, 2021 3:39 pm
by TomW1
Dan_Smullen wrote: ↑Tue Apr 13, 2021 1:08 pm
Dan you have made a major structural mistake by cutting into the boards supporting the deck. Some look to only be a 1/4" left. This is not good over the long term. You should have placed the tubing under the deck supports and down even an 1" lower. I was ready to build a C19 when I bought CL OD18 when he got sick. So I know a little bit about your boat. I even had the wood for it and frame built.
Well take care.
Posted: Thu Apr 15, 2021 7:32 am
by Dan_Smullen
TomW1 wrote: ↑Wed Apr 14, 2021 3:39 pm
Well take care.
I get it. I appreciate all the input I can get from this group. 1/4" is all that is left over the 2" tubes. I spent a fair amount of time deliberating that fact, but ultimately decides that once 1/2" sole, (spec is 3/8"), is stuck to the top pf the stringer cap, this homogeneous bond will provide 3/4" over the cut out.
If I had more room, I would have done it differently, but this is what I've got now. Full send...
Cheating...
First frame dry fit. Feels good to be working above the waterline!
Posted: Thu Apr 15, 2021 9:28 am
by VT_Jeff
You could save a lot of steps and just CNC-cut the fish.
Dan_Smullen wrote: ↑Thu Apr 15, 2021 7:32 am
Sweet!
Posted: Sun Apr 18, 2021 5:23 am
by OneWayTraffic
Build looks good. I must admit I thought the same as TomW when I saw those chases running through the stringers like that. Best to have cutouts in the middle 1/3 of the stringer. The sole on top will help, but I'd run it by the designer for an opinion.
You could sister on a support next to the stringer, or place a shelf or something above the sole there.
Posted: Sun Apr 18, 2021 7:27 am
by cape man
Make sure to fill any gap between the pvc and the stringers with thickened epoxy and you should be fine. Once hardened, the pvc will become part of the structure. The force on the top will be widely distributed with the sole and the wide cleats sitting on top, and it would take one hell of a force to compress the pipe. The other comments are correct in it would be better to go through the stringers more centrally, but you should be good as installed.
Posted: Sun Apr 18, 2021 8:52 pm
by OneWayTraffic
cape man wrote: ↑Sun Apr 18, 2021 7:27 am
Other concern would be whether the section moment of inertia of the stringer is too small with the cutout. Especially with several cutouts close together you effectively have a dogleg, not good in stringers. I suspect that it would be ok, if there is at least 75mm (3") over the bottom, but there will never be a better time than the present to take a couple of good photos and ask the designer.
Posted: Mon Apr 19, 2021 9:03 am
by VT_Jeff
Dan,
I'm quite certain you can drill the same sized hole, the same distance from the flange, every few inches along the top and bottom of that stringer without any structural issues.
Truss me on this.
Drill on/build on!
Posted: Mon Apr 19, 2021 3:17 pm
by OneWayTraffic
VT_Jeff wrote: ↑Mon Apr 19, 2021 9:03 am
Dan,
Truss me on this.
Drill on/build on!
I'll bite. How are you sure? It's almost impossible to accurately calculate the forces on a boat at sea, in waves. And if fatigue is an issue, it could take years to show. If it were mine, I'd like to not be worrying about it. Unless there's other C19s with holes there used in similar conditions for years, or it's already been answered in another post. What does it cost to ask the designer?
Posted: Mon Apr 19, 2021 3:37 pm
by VT_Jeff
OneWayTraffic wrote: ↑Mon Apr 19, 2021 3:17 pm
Dan,
Truss me on this.
Drill on/build on!
I have no idea, OneWay, just providing an alternative guess. Sort of the "One Dollar" answer, if you get that reference.
Posted: Mon Apr 19, 2021 3:59 pm
by OneWayTraffic
I'm afraid I didn't. We get a lot of US culture here, but some of it goes over our heads. Two countries divided by a common language.
Anyway I
think that the stringer would be fine, but I'd sure like to
know for sure. I decided not to have any chase tubes in my boat for reasons like this. Would rather go under a gunwale.
Posted: Mon Apr 19, 2021 4:31 pm
by VT_Jeff
OneWayTraffic wrote: ↑Mon Apr 19, 2021 3:59 pm
I'm going to do the group a solid and not explain it.
I will say that I did some quick research that showed only an 1/8" of flange is required when holing an I-member, and I know that trusses are used ubiquitously, and I know that drilling large holes in stringers/frames is a common way to reduce weight, so those anecdotes went into my otherwise totally hazardous guess. Dan's not going to make any decisions based on my ramblings in any case, he knows far better than that.
Posted: Mon Apr 19, 2021 5:01 pm
by TomTom
Dan glad to see such great progress on your build.
I was thinking about your white chase tubes there and maybe if you are worried you could wrap the pipe with a few layers of Fiberglass tape to stiffen where they pass the stringers just to stiffen up that portion. It would also be a better bond to the wood.
Posted: Mon Apr 19, 2021 5:56 pm
by OneWayTraffic
Now I think about it, I'd probably just make sure that the sole is really really secure on the cleats. I'd put biax on the top of the sole anyway, and that would help. Other thing I'd do is ensure that the seams in the sole are separated from the pvc tubes.
Posted: Mon Apr 19, 2021 5:57 pm
by Dan_Smullen
Thank you all for the spirited opinions, advice and debate. At the end of it all, this is what I've got. Pure speculation, but visualizing the compressive force required to fail the top of the fir stringer cap, after 1/2" ply is laminated atop, is hard for me to do.
Reducing the height of the tanks, or filling the tanks at the console were the only options to avoid this condition, but both of those seemed less appealing than an speculative calculations about compressive strength as compared to the unladen weight of a European swallow.
More suspect than this stringer, is my virgin stitching and glueing performance early in the build.
I think my puzzle joints are more likely to fail than this stringer. Of course if they all fail at once, I will ask the forum to warn all who follow, and to remember me as I sink into the drink.
Photo below taken during the most recent planning/decision making session. I will have one to share with anyone who wants to take a boat ride and help me field test the stringers!
Posted: Mon Apr 19, 2021 6:42 pm
by cape man
I'm in!
Posted: Mon Apr 19, 2021 7:35 pm
by OneWayTraffic
I wasn't thinking about compressive strength at all. I'm willing to bet that that is solid, and far in excess of whatever force you apply standing on top of it.
I'm more thinking about the boat wanting to bend globally as it slams into or falls off a wave. That force is resisted by the stringers, that now have a hole near the top of them. That force will get focused into that cut out, by how much depends on just what section modulus is effectively left. I don't know enough about the precise situation to say anything for sure.
Anyway that's all I've got to say about that.
Posted: Mon Apr 19, 2021 11:59 pm
by TomW1
I said my piece and there is not enough wood at the top to prevent breaking of the stringer if it hits multiple hard waves over time. I would at least take some 12oz and tie the top of the cleats to the lower part of the stringer. Right now I could snap the wood that is left with my two hands. Adding the 1/2" deck over my knee. I have worked with woods all my life and know where and how to place things for strength and durability. This has been discussed many times and shown and I believe is shown in the How To's. You must not reduce the strength of a stringer or a frame when running anything through them. The normal is like 1/3 down or 1/3 up. Peter in building his CS25 in Curacao had to reroute many of his tubing runs.
Well I have given you an idea on how to strengthen it. I don't like it, but it may keep your boat from breaking up.
Sorry I have been off line, my computer was hi-jacked and I just got it back today.
Posted: Tue Apr 20, 2021 3:52 am
by OneWayTraffic
I said I'd enough to say, but I will quote others.
viewtopic.php?f=12&t=16798&start=320
Cracker Larry wrote: ↑Tue Jul 14, 2009 5:06 pm
Peter, I just posted this in another chase tube thread, wanted to make sure you see it so I'm just going to copy it here.
TomW wrote:
Also always put the cutout in the center of the wood this leaves the strongest beam.
The building notes say to cut the chase holes as high up the frames & stringers as possible.This ensures that the maximum amount of wood is against the the hull,where you want it to be. on the panga the frames are quite deep, so it may be more academic, but on the fs17 I am building the frames/stringers are shallow, so it becomes more important.
Steve
I agree with Tom. From an engineering standpoint any I Beam or joist carries the load on it's top and bottom surfaces only. One side is in compression, the other side in tension. The center of the beam has no load. If you read any building codes concerning drilling holes for conduits in floor or ceiling joists, or I Beam timbers, it says that all holes must be drilled in the center 1/3 of the beam and not exceed 1/3 the height of the joist. And building floor joists don't get the flexing that a boat stringer does!
Photos like this really worry me, Peter
Not only is the load bearing portion of the stringers cut away, but there are several cuts right across from each other
This boat will hinge/ flex at that midships point and suffer very early hull failure.
Peter, you really need to pull out those chases and rebuild the stringers. I'm serious
Cracker Larry wrote: ↑Tue Jul 14, 2009 6:15 pm
Kick it where you want, do what you like. Please do ask Jacques. But as an almost certified marine surveyor, I'd flunk it. All 4 of those stringers are weakened in an athwartship plane. The boat will break in the middle over time. Stringers should never have a notch in the top of them, or any kind of step or change of level. Nothing but a straight line across the top, bow to stern. Sorry, please don't shoot the messenger
jacquesmm wrote: ↑Wed Jul 15, 2009 3:54 pm
I missed that.
Cracker Larry is correct: those cuts seriously weaken the stringers.
The chase tubes should go, as much as possible, through the middle of the stringer height.
You need 3", minimum 2 at the bottom and 1 or 2" plus the whole thickness of the cleats at the top.
I know that some production boats have that type of cuts in the top of the stringers but it is wrong.
Posted: Tue Apr 20, 2021 7:20 am
by Browndog
Dan,
When building the FS 19, there were a number of instances where I asked for advice, got none, then proceeded as planned only to get a bunch of Monday Morning quarterbacking from some of the forum participants after the fact.
In all cases it hasn’t made a difference.
The boat is looking great, you’re making good progress. Looking forward to helping you coat the boat in fish slime at some point in the not too distant future.
Posted: Tue Apr 20, 2021 9:28 am
by Dan_Smullen
Browndog wrote: ↑Tue Apr 20, 2021 7:20 am
Dan,
Roger that, BD. Thanks. I remember reading about your spray rails. The advice, I believe, is well intentioned.
The decisions we make aren't made on whims, but after much mental deliberation and risk calculation. At some point, it's time to go and to not look back.
Chasing big red drum on the Eastern Shore this time next year is not out of the question!
Posted: Tue Apr 20, 2021 2:55 pm
by OneWayTraffic
Of course at the end of the day, it's your boat. I've made decisions with mine that others may disagree with, and always thought it through too.
Keep in mind however that sometimes issues take years to show. If it were mine, and I was married to having the tubes through there, I'd probably put ply on top and raise the sole. The C19 like my 17 has a deep cockpit. That way you can have your cake and eat it. Nearly everybody who has built a boat wishes they had done that.
Either that or design something on top of the sole to reinforce it. Glass in a beam to retain the cooler, or put a seat there, tabbed in with biaxial, or just some extra UD glass or CF running longitudinally on top of the sole in that place. On top of the sole so it's far from the neutral axis. That will cost almost nothing in time or materials. Sealing in the PVC tubes with glass and gflex won't cost much either and will allow the PVC to assist in the structure.
Anyway, it's been great to watch a C19 go together in real time. I'd take you up on your offer, but what with the cost of international travel these days, you'd need to offer a lot of beer!
Posted: Tue Apr 20, 2021 3:56 pm
by Dan_Smullen
Solutions! That’s what’s it’s all about!
Onward to the forward bulkheads and hatches!
Posted: Tue Apr 20, 2021 5:00 pm
by VT_Jeff
OneWayTraffic wrote: ↑Mon Apr 19, 2021 7:35 pm
Just discussion for the sake of gaining knowledge at this point.
My impression:
I highly doubt Dan was referring to compression from walking, he was referring to the same compressive force you are: wave pounding, applying a force to the outside of the hull, which will be transferred, eventually to the cap/sole. In a I-Beam, the web component experiences sheer forces, the flanges bending forces. The sheer forces are distributed evenly throughout the web-depth, they are not concentrated at the top or bottom like in a "normal" beam. In a normal beam, the top and bottom experience tension or compression with a bending moment, the center neither, which is why holes need to be at the center. In an I-beam, it's not the case. A hole will weaken the web but the location of it, depth-wise, makes little-to-no difference.
As always, more than happy to be proven wrong, as my ONLY goal in this entire enterprise is to learn.
Posted: Tue Apr 20, 2021 5:33 pm
by OneWayTraffic
VT_Jeff wrote: ↑Tue Apr 20, 2021 5:00 pm
My impression:
What I know for sure is that in the discussion about the CS25, the designer stated explicitly that a
minimum of 1-2"
plus the whole thickness of the cleats was
required on top. In the thread I linked to, people with more knowledge and experience than I stated what the standard requirements of stringers are. It's worth a read and those requirements have been gained from millions of boats. I also think that the CS25 shown was worse in that all four stringers were cut, and in a similar place. Early hull failure would have been certain with that boat and how it was going to be used. So it was rebuilt. I would agree that if the sole attachment is thick enough, strong enough, and well attached enough then it shouldn't matter. Which is why I'd be putting some structure on top there.
There are requirements about location and size in documentation building codes for pre made I beams. This one for example allows holes anywhere in the web at least 2mm from a flange, but the flange is 33mm thick. There are a lot of other requirements as well.
https://nzwoodproducts.co.nz/media/prod ... .2a_LR.pdf
Anyway I've said my piece, and a lot more than I originally intended too. Apologies for any derail from the build thread.
Posted: Tue Apr 20, 2021 5:37 pm
by cracked_ribs
If I was seriously concerned about it - and I wouldn't be - I'd just add a layer of 12oz tape over the top of the stringers and cleats. The tiny height difference relative to the bulkheads would get eaten up in the peanut butter that goes to glue down the deck.
The 45/45 would tie the load in over top of the holes, and if you did it right before laying the sole, you'd get a strong primary bond across that whole load path. Top skin of that beam would be in tension from hull hitting the water; you could make it a little stronger in tension that way.
But I think that the large cleats and the connection to the sole would be plenty. All this stuff is overbuilt. Tom's C19 ran with fully delaminated...everything. Obviously you don't want that but people worry about minutae. I would have changed Peter's layout, and I agree with that call 100% but it was worse. I saw this in the pics and thought about it for a bit and decided to say nothing, but I understand the concern. But I don't think you'll ever find an issue that results from it.
If all the chatter put doubts in your mind, I'd chamfer the cleats with a roundover bit, put a layer of biax tape on over the conduits, and rock on.
Posted: Tue Apr 20, 2021 9:32 pm
by Dan_Smullen
Don't apologize, OWT. I enjoy the conversation.
cracked_ribs wrote: ↑Tue Apr 20, 2021 5:37 pm
None whatsoever.. Thickened epoxy around the tubes, to seal them, not to add strength.
Frames, stringers and caps, all melded together with epoxy. The entire torsion assembly is the most rigid thing I've ever built, and these little holes did little, if anything to weaken it, especially after the sole is laminated to the cap. It is more likely that the transom falls off, or the joint between the upper and lower side panel fails before this hull hinges at this point.
Moving on...
Station B is temporarily in place with some screws. Test fit modified "Frame A". Moved it back 24", minimizing the area of the forward step/seat/hatch area, but increasing the deck at the bow. (More room to stand up there and cast). Scratching my head how to make all of this work. It's just behind the PVC coming up out of the floor. Will be a floor behind it, supported on cleats on the side panels. A place to stash an anchor, some PFDs and maybe a square grouper, should I find one in the bay.
Posted: Wed Apr 21, 2021 3:04 pm
by cape man
and maybe a square grouper should I find one in the bay.
You just showed your age! I remember T-shirts and bumper stickers that said "Save the Bales!"
Posted: Wed Apr 21, 2021 7:06 pm
by OneWayTraffic
Are you planning to glass the inside above the side panel overlap? I'm thinking about whether I'll glass the inside of mine with light glass. I used 200g on the whole outside, and have some 100g cloth also. At this stage I'm leaning towards glassing every large surface.
Posted: Wed Apr 21, 2021 8:53 pm
by Dan_Smullen
OneWayTraffic wrote: ↑Wed Apr 21, 2021 7:06 pm
I want to run 6” of tape down the seam itself to add strength, but have been concerned about it laying flat with no bubbles.
After your question this evening, I ran a cabosil fillet along the top of the lower panel up forward, and laid tape over it. It seams to have stayed flat, and I’ll continue down the joint. Eventually...
10 or 6 oz over the tape on the upper panel will be nice. I should make it a point to lay it.
Posted: Thu Apr 22, 2021 12:46 am
by OneWayTraffic
I had a few issues with the outside cloth as well. I put a fillet on the overlap and that helped a bunch. Not even slightly concerned with strength there.
Edit: I did sand through the cloth here and there for fairing.
Posted: Thu Apr 22, 2021 4:58 pm
by TomTom
This I can attest to!
And thank goodness it was overbuilt - thats for all the dumb asses like me out there!
Interestingly - the same “sales guy” - and that truly is all he is - who sold me that resin that never fully cured back when I first built the boat messaged out of the blue and offered to send me some “new” samples of what they are selling ...
I was curious enough to accept and try as I might, I couldn’t get it to fully cure. It’s supposedly Araldite GY 257 ... but I think they mix the hardener components locally and they clearly don’t get it right. I hate to think how many substandard and wasted projects there are that have used this stuff.
All I can say is if you live somewhere remote and you have any doubts about your resin supplier just pay the extra and figure out how to import that right stuff.
This Ampreg 21 by gurit that I use now is like chalk and cheese compared to that other stuff.
Posted: Mon Apr 26, 2021 9:39 pm
by Dan_Smullen
Not much boat work this weekend. I made the trip to Manteo, NC to finish a small project on a friends Jarret Bay. Hull #4,
"Smoke Show"
While refurbishing the salon to be more suitable to charter fishing, an ac unit was removed, exposing the bottom of a wire chase. I extended the chase cover by scarfing a new piece of teak onto the existing.
I always jump at the chance to help out Jay, the owner, especially as tuna fishing heats up in April-June.
Resawn 4/4 teak to get 5/8' thick stock without sending 3/8" up the dust chute. At $25/bdft, it seems best to conserve.
Scarfed and glued...
3 coats of Epifanes...
Installed port and starboard...
Yellowfin poke bowl from their catch the day before...
Back to the C19, I added 3-1/4" to the height of station B, which will raise the seat, and give me a little more storage room underneath. I felt this was needed after raising the sole.
Talk about running out of tape just in time...
Posted: Mon Apr 26, 2021 10:13 pm
by TomW1
Nice work Dan, that Poke looks mighty good, Yum.
Posted: Tue Apr 27, 2021 7:39 am
by Jeff
Nice work Dan!! Jeff
Posted: Tue Apr 27, 2021 8:14 am
by Dan_Smullen
TomW1 wrote: ↑Mon Apr 26, 2021 10:13 pm
... that Poke looks mighty good, Yum.
Thanks, Tom. Fresh Carolina YFT is hard to beat!
Jeff wrote: ↑Tue Apr 27, 2021 7:39 am
Thanks, Jeff. Order for more tape just went in!
Posted: Tue Apr 27, 2021 8:48 am
by VT_Jeff
I'm sure you'd help out any friend with any boat but no one would blame you for putting that guy/that boat a little higher up the list!
Posted: Tue Apr 27, 2021 2:53 pm
by OneWayTraffic
I take it that varnish is preferred over epoxy for teak? Or is it because it's just interior furniture?
Posted: Tue Apr 27, 2021 3:29 pm
by Dan_Smullen
OneWayTraffic wrote: ↑Tue Apr 27, 2021 2:53 pm
Preferred for exterior is a seal coat of epoxy under several coats of varnish. Inside the house I took the easy route. I think the original finish in the salon is polyurethane.
Almost 2 years ago, I did a small tackle drawer that lives on deck. I sealed with epoxy and varnish coated with Epifanes, and it looks as good as day one. Picture is terrible, but it still looks and feels nice.
Posted: Fri May 07, 2021 9:17 pm
by Dan_Smullen
Plugging away on the forward sole/seat/casting deck/step. Small departure from the plans by adding 3.25" to the height of the seat, which feels more proportionate after the added height to the sole. Also, rather than the fore to aft center support, I like the athwartships approach which will not impede stashing gear under the bow.
Need to finish tabbing the sole support, and template for the anchor locker deck, and figure out how I want to integrate a hatch in the seat.
Lastly, cleaned up the clutter a bit to make her suitable for an IG pic.
Posted: Sun May 09, 2021 6:17 pm
by Dan_Smullen
A path forward on hatches has been defined!
Mold making to commence!
Posted: Sun May 09, 2021 7:40 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun May 09, 2021 6:17 pm
Looks great! Is that the "seat" you're referring to also? Will it have a cushion etc or just a bench.
Posted: Sun May 09, 2021 8:23 pm
by Dan_Smullen
Just a bench. Guests are welcome to have their teeth beaten out of their heads whilst punching through chop.
Posted: Sun May 09, 2021 9:09 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun May 09, 2021 8:23 pm
Mmmm. Maybe keep a jar of mouthguards for any whiners.
Posted: Mon May 10, 2021 1:27 am
by OneWayTraffic
Couple of marine beanbags. Movable and makeshift flotation.
Posted: Mon May 10, 2021 10:02 pm
by Dan_Smullen
OneWayTraffic wrote: ↑Mon May 10, 2021 1:27 am
I’ve been thinking about those. Put them on the bot when the kids are riding, but leave them on the beach when it’s the boys looking for fish.
Posted: Tue May 11, 2021 12:07 am
by OneWayTraffic
Adults like them too appaently. More comfy than any bench or chair. Good option. You can get in any size you care to.
Posted: Wed May 12, 2021 9:34 pm
by Dan_Smullen
One coat of Interlux Bilgecoat from BBC applied over Silver Tip Yacht Primer.
Went on well with a fuzzy nap roller, and will apply at least a 2nd coat.
Posted: Thu May 13, 2021 7:41 am
by Jeff
Nice Dan!!! Jeff
Posted: Thu May 13, 2021 9:33 am
by VT_Jeff
Dan_Smullen wrote: ↑Wed May 12, 2021 9:34 pm
Cleaner than my kitchen!
Just realized there are very few C19 build threads, you're a pioneer on this design.
Posted: Thu May 13, 2021 1:59 pm
by Dan_Smullen
VT_Jeff wrote: ↑Thu May 13, 2021 9:33 am
A handful of C17s, and a few 21s, but you're right, one has to dig a little for pics. I hope she's up there with Tom's and Welleflicker's when she's done.
Posted: Thu May 13, 2021 2:02 pm
by VT_Jeff
Dan_Smullen wrote: ↑Thu May 13, 2021 1:59 pm
Taking nothing away from those builds, I have little doubt you'll reset the bar.
Posted: Sun May 16, 2021 8:40 pm
by Dan_Smullen
Bilge Kote eventually dried. The heavy spots took a few days at 60-65 degrees.
Cut and dry fit the anchor locker floor. Butt joint in the middle with a run of 12oz tape, then worked on some support structure.
Laminated 2 pcs of 12mm together for the struts. White oak for the cleat on the bulk head.
I typically save the beer for the end of the day, but yesterday indulged earlier than usual, and in haste, mis-marked the center of this cleat, and glued it on in the wrong spot. Only off by and inch..
Quick fix with the multi tool on one end, and an "adder" on the other.
Posted: Sun May 16, 2021 9:09 pm
by VT_Jeff
Way to own it!
"I cut a board, it was too short. Cut it again, still too short".
Morbid curiousity: is this another drank-too-soon do-over? The glue line looks suspiciously like something that was scabbed back on.
- 20210516_210414.jpg (92.92 KiB) Viewed 7471 times
I like the bevel, btw, I skipped it on my bow sole and it cost me a lot of peanut buttet.
Posted: Sun May 16, 2021 9:20 pm
by Dan_Smullen
VT_Jeff wrote: ↑Sun May 16, 2021 9:09 pm
Way to own it!
It happens...
“Infill” sounds more deliberate than “scab”.
Infill on the bulkhead was to raise the step height a little. I cut it per the plans, but thought it low. Raised it 3-1/4” to make it easier to jump up on the bow and launch a 3oz buck tail.
Posted: Mon May 17, 2021 9:27 am
by fallguy1000
I'm a little worried my gutters are too little, so I am planning four drains in each one. But the issue is a bit counter intuitive. A larger gutter means more water can enter it. So maybe I am full of it or at least they'll work in heavier rains.
Posted: Mon May 17, 2021 9:32 am
by VT_Jeff
I did the same after I saw what the bow hatch looked like as a square, in-filled it with the triangles cut off the lid. It is nice how forgiving this method is for re-design on the fly.
Posted: Mon May 17, 2021 7:08 pm
by Dan_Smullen
fallguy1000 wrote: ↑Mon May 17, 2021 9:27 am
I’m venturing into an unknown with hatch gutters. Couldn’t wrap my brain around the geometry for a while.
I was able to measure some hatch gutter details on a Mako at Bass Pro, and I’m using those dimensions. These will also drain to the lip of the step. Hopefully...
by Dan_Smullen
VT_Jeff wrote: ↑Mon May 17, 2021 9:32 am
Sometimes more glue than stitch.
Posted: Sun Jun 13, 2021 8:43 pm
by Dan_Smullen
Been a busy month, fiddling with this and that on the boat. Keeping my attention on the forward section and watching you guys make blazing progress. Well done fellas!
Attending You Tube University trying to learn about molding hatches and gutters. Collecting supplies which includes better PVA than the cheapest option on Amazon, which I bought, but it was exceptionally runny. Maybe the good stuff is not so much so. Hope to have a report on them soon.
Before closing in the anchor locker I added a white oak backing plate and drilled for the 3/8" bow eye. Drilled oversize holes, 5/8", to install my home made fiberglass sleeves. I glued these guys in with thickened epoxy to seal the penetrations. Probably overkill, but they give me piece of mind. At this point in the project, there is no sense in taking the simple route. Backing plate was cut out of a short piece of 304 stainless angle.
Again, not the simple route, but I added this bulkhead, Frame A2, to support the enlarged bow deck. It's tabbed in place on the forward face. Will clad with Sapele on the aft face, facing the console.
Frame A was cut per plans, but wound up slightly undersize. I think the port side side panel is flared out farther than it should be, so it reads low and wide. Nothing to be done about it now, other than scab through it.
A few fishing breaks here and there. Puppy Drum are profuse in the marsh this year. Tried for tuna out of Oregon Inlet, but went 1-6 on bites. Redemption Round next weekend, hopefully...
Posted: Sun Jun 13, 2021 10:09 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun Jun 13, 2021 8:43 pm
Damn, looks like you earned your diploma! Is that a mold or a part?
please drop pin where you got that fish, Elaine is loading the car now.
Posted: Sun Jun 13, 2021 10:18 pm
by Dan_Smullen
C’mon down! These fish are shallow feeding on small crabs. You and Elaine will crush them on the fly.
This is the mold. Modeled in Fusion, cnc cut from 2 layers of 3/4 MDF.
Posted: Sat Jun 19, 2021 11:50 am
by Dan_Smullen
Posted: Sat Jun 19, 2021 9:08 pm
by Dan_Smullen
1 oz. CSM worked beautifully evening out the layers of tape and glass. I think it will be ready for primer after a quick lick with the sander.
Posted: Tue Jun 22, 2021 9:48 pm
by Dan_Smullen
Juuuuust a little short on foam, but first piece of main sole cut and fit is a milestone!
Posted: Wed Jun 23, 2021 12:33 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Jun 22, 2021 9:48 pm
Damn!
Nice!
Posted: Wed Jun 23, 2021 1:16 pm
by TomW1
One more step Dan things are looking good. What is the big chase tube for?
Posted: Wed Jun 23, 2021 2:08 pm
by VT_Jeff
TomW1 wrote: ↑Wed Jun 23, 2021 1:16 pm
That's a Herinal
Posted: Thu Jun 24, 2021 7:16 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed Jun 23, 2021 2:08 pm
That's a Herinal
Lol! As the originator of the Herinal name, I invite you to become an investor. We just first develop the molding process, but once we perfect that, we’re ready to launch!
Posted: Thu Jun 24, 2021 7:36 pm
by VT_Jeff
Dan_Smullen wrote: ↑Thu Jun 24, 2021 7:16 pm
That's a Herinal
I've already seen your molding process, it's perfect! Uploading bitcoin now, please stand by.
Posted: Fri Jun 25, 2021 6:29 am
by Dan_Smullen
It’s 4” PVC for engine controls and anything else I need to fit in it. It looks funny because it’s upside down in the pic. I cut and fit the elbow a while ago while determining the layout, but it’s been loose in the bilge ever since.
Posted: Mon Jul 12, 2021 8:42 pm
by Dan_Smullen
The few remaining voids have been filled with foam. I'm on the fence about foaming more compartments. In addition to the cost, reasons leaning towards the not, are the inability to inspect the inside of the hull in years to come. There is comfort in looking through an inspection hatch, and seeing the inside of hull dry and intact, as opposed to covering it all up with 11" of foam. Lord knows what could be brewing out of site and out of mind. I will continue to deliberate.
I believe the fuel line routing conundrum has been solved. Molded tray documentation is here.
viewtopic.php?f=2&t=64870&start=70
Neoprene rubber strips were laminated to the bottom of the tank by spreading 5200 with a notched scraper, which provided beautiful coverage.
The intent was to do the same to the bottoms of the strips, and them set the tank in the bilge, but my pervasive fear of commitment prevented me from doing so. At least for now.
I predrilled 1/2" holes at the mounting tab locations, filled the with epoxy, then pre-drilled for 5/16" s.s. lags, utilizing rubber grommets to insulate between dissimilar metals. Will it help or hurt? I don't know...
Still need to track down some innertube scraps to protect the lines and adjacent plywood where the hoses pass through the sole. Of all of the chaffing gear suggestions, I like this one the best. Also, smooth band hose clamps for the vent line will be in tomorrow.
In other news, we snuck out in the marsh the other night wading, and found good fish feeding before the tide slowed.
To do:
1. Cut piece for center section of forward sole and prep to recieve 8" inspection hatch centered of tank plumbing connections
2. Glue down forward sections and tape
3. Finish gutter mold and hatch lid
All for now...
Re: C19 in Richmond, VA
Posted: Fri Jul 16, 2021 4:17 pm
by Dan_Smullen
Pretty messy in the shop, and I'm getting low on epoxy, but I'll call this progress!
JimW suggests dielectric grease on the sending unit. This is advice I will take!
Posted: Fri Jul 16, 2021 5:32 pm
by fallguy1000
Sole is such fun.
Posted: Thu Jul 29, 2021 6:10 pm
by TomTom
How are you going to seal this flexible rubber hose and stop water coming between it and the sole? Or am I missing a step/ something?
Posted: Fri Jul 30, 2021 9:34 am
by Dan_Smullen
TomTom wrote: ↑Thu Jul 29, 2021 6:10 pm
Fair question. Rather than a single frame here, It will be boxed out with 2 frames spaced ~6” or so apart with a cap on them. 4” pie plate access panel up high at the gunwale to access the hose clamps at the fill.
That’s the plan anyway.
Posted: Fri Jul 30, 2021 12:04 pm
by VT_Jeff
Dan_Smullen wrote: ↑Fri Jul 30, 2021 9:34 am
I like it!
Posted: Mon Aug 09, 2021 9:46 am
by Dan_Smullen
Posted: Mon Aug 09, 2021 11:12 am
by TomW1
Dan why put off ordering the foam. Order it today and you will have it Wednesday or Thursday and you won't have to worry about adding it through the holes and maybe adding to much.
Regards, Tom
Posted: Mon Aug 09, 2021 12:02 pm
by Dougster
Adding foam thru 2' holes wouldn't be my choice either. Seems like it would be hard to get an even spread. Sure looked like a nice red on that lure
Dougster
Posted: Mon Aug 09, 2021 12:23 pm
by Dan_Smullen
TomW1 wrote: ↑Mon Aug 09, 2021 11:12 am
I get the thinking, but I've been financing the build Johnny Cash style, one piece at a time. Monthly budget essentially, and need more epoxy this month. Also, I hate buying foam. Big investment, and it's all gone in minutes. Then the leveling which creates waste...
I may not even pour anymore. I have a fair amount in the bow and forward. At least pouring after the fact will save me from trimming the top of it.
Dougster wrote: ↑Mon Aug 09, 2021 12:02 pm
I agree. Like most parallel paths, overcoming one challenge results in creating another. I think I can overcome this one with well placed holes, and ample amounts of material ready to pour.
This was the only fish to bite on that day. Slick calm conditions. It seemed like topwater would be a good choice. I love this pink Skitterwalk. It has been a producer for a while. 3rd set of hooks on this one, I think!
Posted: Mon Aug 09, 2021 2:37 pm
by Jeff
Nice trip Dan!!! Jeff
Posted: Mon Aug 09, 2021 4:06 pm
by TomW1
Dan I hear you on the funds point. But pouring through the holes is tricky. I would only pour 3/4 or 7/8 full. If you fill till it comes out the site holes, it will push up your decks as it expands, which is not good. It has a lot of force when expanding. As far as your cutting waste from the top, throw them in the bottom of the next compartment as filler. As far as where you are putting the foam are you following Jacques recommendation and just putting it in the compartments between the outside and the center compartments?
Well keep on going, as I think I have told you before I love the C19. Nice pics from the OB.
Regards, Tom
Posted: Mon Aug 09, 2021 5:37 pm
by Dan_Smullen
Jeff wrote: ↑Mon Aug 09, 2021 2:37 pm
Thank you, Bud! It always is!
TomW1 wrote: ↑Mon Aug 09, 2021 4:06 pm
Thank you Tom, and words of caution noted! To be continued!
Posted: Mon Aug 09, 2021 9:50 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Aug 09, 2021 12:23 pm
This is an amazing testament to Dan's angling skills: only a single fish bit all day, and Dan was in the right place with the right spoon to catch it!
Posted: Mon Aug 09, 2021 9:55 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Aug 09, 2021 9:50 pm
Kind of what I was trying to say, without saying it.
The pressure was on though. I caught a few earlier in the week, and some friends came down after I told them how hot it was. Towards the end of the day they were pointing and grumbling. I had to make something happen quickly.
Posted: Thu Aug 12, 2021 2:42 pm
by Dan_Smullen
Mental block/fear of commitment about permanently attaching fuel tanks in a bed of 5200 has been overcome, and it feels like the end is now in sight! Man, I was reluctant to glue these guys in but over it now.
These 1/4 neoprene rubber strips were laminated to the bottom of each tank by spreading 5200 to 100% coverage with a 1/4" notched trowel.
Another layer of the same was spread on the bottom of each, and the tank set in the hole and secured with stainless lags, which were threaded into epoxy plugs in the stringers. Rubber grommets insulate the dissimilar metals.
A little bit of securing of the last bit of PVC, but then it's time to stick the sole!
Posted: Thu Aug 12, 2021 3:53 pm
by Jeff
Nice work Dan!!! Jeff
Posted: Thu Aug 12, 2021 6:17 pm
by Dan_Smullen
Jeff wrote: ↑Thu Aug 12, 2021 3:53 pm
Thanks for the help this week, Boss!
Posted: Thu Aug 12, 2021 8:04 pm
by VT_Jeff
Wow! Big, mind-clearing step, nice work!
Posted: Thu Aug 12, 2021 8:48 pm
by Dan_Smullen
VT_Jeff wrote: ↑Thu Aug 12, 2021 8:04 pm
Thanks, Jeff. Nothing worse than being hamstring with indecision. I’m the past now, Bud!
Posted: Fri Aug 13, 2021 6:26 pm
by fallguy1000
I get stuck in analysis paralysis now n then..okay a lot.
Ask friends; it helps.
Posted: Fri Aug 13, 2021 6:53 pm
by TomW1
Nice job Dan, looks good. Tom
Posted: Sat Aug 14, 2021 8:07 am
by Dan_Smullen
fallguy1000 wrote: ↑Fri Aug 13, 2021 6:26 pm
Absolutely. Helps to talk it through and get unstuck.
TomW1 wrote: ↑Fri Aug 13, 2021 6:53 pm
Thanks Tom! C19, coming up!
Posted: Mon Aug 23, 2021 9:22 pm
by Dan_Smullen
Milestone alert! Sole glued in place!
Some last minute connections to cover up with foam. Drain chase from compartments via limber holes, draining to the bilge. Used cardboard tube as sacrificial mold under a layer of glass. These will all be covered from foam, poured into the compartment through a hole in the sole.
Glued the aft sections of floor together with tape and 12 oz on the back of the center section which will span the largest gas tank. Enlisted some help from a friend to dry fit this part, then set on to peanut butter spread with a 1/4" notched spreader on the tops of the stringers. No pics of this, our hands were full...
Fastened the sole pieces with truss head screws while the glue dried, and then pulled them out the next morning.
Ignore the image that appeared in the epoxy. I hope it's not a premonition of things to come.
One last look in the belly before setting the sole. Quick check to be sure nothing is left behind.
Uneventful, really. Dry fitting, trimming and setting took about an hour.
Edges taped this evening. Will work on boxing around the fuel fills and vents this week, as well as the other frames.
Old tire tubes wrapped around the fuel lines as suggested. Thanks for that FG!
I think after frames, it's time to mock up the console!
Posted: Mon Aug 23, 2021 10:43 pm
by VT_Jeff
She us gonna be a beaut, no question, despite any temporary sole silhouettes!
Uneventful is the Holy Grail of boat-building, your hard work, careful planning and incredible luck all came together!
Any after photos of the bounty drains?
Posted: Mon Aug 23, 2021 10:45 pm
by VT_Jeff
Just saw the drains in the photo, I was blinded by the pvc first glance, they look great!
Posted: Mon Aug 23, 2021 11:06 pm
by fallguy1000
I used a glue recommended by Aripeka Angler for the pvc and it seems to be exceptional. Name eludes me now...if you want to know I'll go look.
Posted: Tue Aug 24, 2021 9:37 am
by Dougster
It could be tricky pouring foam through a hole in the sole. Easier to foam first, then glue down sole when possible. If going through a hole I'd go easy, in stages, to prevent over expansion in some areas and warping the sole.
Dougster
Posted: Tue Aug 24, 2021 11:54 am
by Dan_Smullen
Dougster wrote: ↑Tue Aug 24, 2021 9:37 am
Dougster
For sure. Trading one set of challenges for another. Multiple holes along the length of the compartments seem necessary. Outcome will be documented and shared!
Posted: Wed Aug 25, 2021 9:29 am
by Dougster
Sounds good
Dougster
Posted: Tue Aug 31, 2021 12:41 pm
by Dan_Smullen
Adding frames one at a time. As with CR's build, these provide an amazing amount stiffness to the side, and I smile a little every time I pound them with the side of my fist and they do not yield.
Fuel fill and vent hoses box in the works. It feels like a console building primer.
Doubled up the frames to be 2 layers of 1/2" rather than one layer of 3/8", just because. They'll appear more substantial if nothing else. 2 down and 2 to go.
Posted: Tue Aug 31, 2021 1:42 pm
by cracked_ribs
It really is a great feeling! From "a hull I am working on" to "a boat I need to finish." Makes it much more satisfying to stand in and make motor noises.
Posted: Tue Aug 31, 2021 1:53 pm
by VT_Jeff
"2 layers of 1/2" rather than one layer of 3/8","
Un-yielding indeed! Will make a nice, walk-able gunnel and safegaurd against those pesky, unintentional piling hits.
Posted: Tue Aug 31, 2021 2:07 pm
by Dan_Smullen
cracked_ribs wrote: ↑Tue Aug 31, 2021 1:42 pm
Exactly!
VT_Jeff wrote: ↑Tue Aug 31, 2021 1:53 pm
Definitely prepared to bounce off of some bridge pilings. That's where the fishies live!
Posted: Tue Oct 12, 2021 8:27 pm
by Dan_Smullen
Life and side missions exposed cracks in my resolve to build on, but after a few hours on a completed BBC project compliments of VT Jeff, my resolve is renewed!
This forward hatch was right in the way of progress. I didn't feel like I keep keep glassing toward the transom leaving this opening untouched. Perhaps a case of paralyzation by analyzation, but nevertheless, early attempts at hatch gutter molding failed, leaving me stranded and incomplete. See below...
A vacation, home projects, and a busy few months at work later, armed with fresh knowledge from YouTube University, I reworked the gutter design, grabbed a gallon of professional grade laminating polyester resin, molded the hatch itself and and took a second stab at an MDF mold.
The trick this time was to neat coat the MDF so it could be sanded smooth rather than just sanded fuzzy. Sanded it smooth to 120. Sprayed with SilverTip YP, then sanded with 220. Coated with PVA, brushed with gel coat, and laminated with 3-4 layers of 1.5 oz CSM.
Dreamt about it all night, and returned to the shop this morning to pop her loose.
Cleaned up the hole and dropped her in place...
I think the things that made a difference this time were a properly prepped mold and quality ploy resin not over catalyzed, and clean CSM from BBC!
After gluing this in place, I will be free to glass around it. Finish the forward bulkhead, glass down the front of the step and sole nearly to the transom. That should keep me busy for a few weeks. Feels good to have a path in front of me again!
Posted: Tue Oct 12, 2021 10:07 pm
by VT_Jeff
Way to overcome and push over the hump, Dan! You now have a really nice part, a new set of really useful skills, and a path forward, that's awesome! And so glad we could help with some inspiration, I know we can all use some from time to time. Cars will be back in that garage in no time!
Posted: Thu Oct 14, 2021 5:36 am
by OneWayTraffic
That sure looks nice, but plastic hatches are so much easier. If you could let me know why you decided to make them yourself I might see the logic in doing the same.
Posted: Thu Oct 14, 2021 6:51 am
by Dan_Smullen
OneWayTraffic wrote: ↑Thu Oct 14, 2021 5:36 am
Out of pocket expense and stubbornness are the two greatest factors in going this route.
Hatch is 18x30. If I were willing to fork over the cash for an off the shelf option, i’m not aware of a plastic hatch of this size. There are some custom made fiberglass options available for $500 or more, and again, not willing to pry with the cash. 10 yards of CSM and a gallon of polyester resin totals about $90.
I also wanted to learn how to do it. Our shop has production capacity, and if I can get our guys building boat parts, that will be a win.
Posted: Mon Oct 18, 2021 1:50 pm
by Dan_Smullen
A bit of a sloppy mess, but the forward area around the hatch is glassed.
I've gotten used to wetting out glass horizontally, which works great for smaller pieces, but as soon as I got ready to roll up this 14" x 52" wet noodle of 12oz biax, did it occur to me that it wasn't going to work here. Threw the proverbial spaghettis at the wall, and this is what stuck. 60 grit on the belt sander got it to a point of moderate acceptability. Hatch gutter is surprisingly rigid, and shows almost no flex at all while standing on the lid.
Over bored holes in the hull for fuel vents, and refilled with thickened epoxy. Drilled out for 1-3/8" vent fittings.
Boat work is confined to the evenings while weekends are dedicated to the last bit of work to do in our house. A side quest if you will. First batch of living room built ins went in this weekend.
To be honest, I enjoy working on any project. Whether it is fiberglass and other goo in the garage, or a good old fashioned shop project. I'm grateful for the ability to do both.
Posted: Sun Nov 14, 2021 8:04 pm
by Dan_Smullen
I feel like I've taken almost a month off from the build. Hard to get it done like that...
After finishing our built ins in the living room, I enjoyed several hours making a mess in the boat this weekend.
Cut and joined the forward deck after spending a fair amount of time with a batten, marking, looking at, and power planing the the tops of the sides. The goal was to create a gradually rising sheer that afforded equal points of contact under the forward deck. It's not perfect, but within the wide spec S&G builders have come to appreciate.
Before gluing this down permanently, I'm making some time to fair to a work boat finish, the open compartment under the deck. For the horizontal surfaces, I mixed epoxy thickened with glass spheres to the consistency of honey, and brushed it and left it to self level. When cured, hit it with 80 grit, and I think the resulting finish is suitable for this and eventually, the sole. I also want to get a few thin layers of epoxy on this solid wood before gluing down the deck to allow for proper sanding for varnish.
Glued the fuel line fill and vent chase in finally, and had a chance to stretch a batten down the tops of the frames to get an idea of what the cap/deck/gunwales will look like. Finished width will be about 10-1/2". A little narrower than the 12" in the plans, but I feel like this width is Goldilocks.
New folder on my Desktop for this and upcoming pictures is labeled "Home Stretch" Maybe? I'm hoping for a productive winter!
Posted: Mon Nov 15, 2021 9:51 am
by pee wee
Looking good, it's all coming together!
Posted: Mon Nov 15, 2021 9:57 am
by VT_Jeff
Nice work on the built-ins, that's going to be a great spot for some photos of you catching big fish on the boat!
Home stretch indeed, just cut, fit, glue, repeat and you're done!
Posted: Mon Nov 15, 2021 10:20 am
by fallguy1000
How you gonna access the vent later?
Posted: Mon Nov 15, 2021 10:35 am
by Mojosmantra
The dog appears happy with your work and probably pleased that your back in the garage
Boat is looking real nice!
Posted: Mon Nov 15, 2021 11:50 am
by TomW1
fallguy1000 wrote: ↑Mon Nov 15, 2021 10:20 am
Yes Dan, you need to be able to inspect the hose and hose clamps for wear and tear every couple of years or so. The boat is looking great
Posted: Mon Nov 15, 2021 12:14 pm
by Dan_Smullen
6" pie plate hatch I think will work well.
Posted: Mon Nov 15, 2021 2:29 pm
by fallguy1000
Dan_Smullen wrote: ↑Mon Nov 15, 2021 12:14 pm
Sounds good; just tryin to help. Even a 4" may work.
The tank connection needs to be made accessible as well. Only mention cuz mine was cut in late!
Posted: Mon Nov 15, 2021 3:58 pm
by Dan_Smullen
fallguy1000 wrote: ↑Mon Nov 15, 2021 2:29 pm
I get it. Always appreciate the constructive comments.
The cut out for access over the connection on the aft tank needs to be cut in too due to momentary memory loss.
Posted: Sun Nov 28, 2021 5:18 pm
by Dan_Smullen
As it turns out, what was forgotten, running bonding wires from fill ----> tank.
Emergency temporary access panel, a coat hanger and assist from my oldest daughter facilitated fishing a pull wire through the conduit and up the side.
Don't forget your bonding wires, kids.
Posted: Sun Nov 28, 2021 5:27 pm
by Dan_Smullen
This weekend I was thankful for a lot, but also for lighting fast shipping from Reid and Jeff so my 3 gallons of epoxy and 10 yards of 10oz glass made it here in time for a few days off.
Bow deck and first section of gunwale cap glue in place, and tabbed from underneath!
Fixed a batten along the tops of the frames to scribe on the bottom of a piece of 1/2". Cut close to the line and faired before bedding.
Filleted with wood flour, tabbed with 12ox biax tape, and then covered the inside of the upper side panel with 10oz woven for consistent coverage and finish.
I think next is some glass on the forward half of the sole, and station E, on which the gunwale cap will tie in to. Engine well after simultaneously.
Feels like momentum now.
Posted: Sun Nov 28, 2021 9:31 pm
by TomW1
Looks good Dan. One thing I notice is you don't have a batten glued on each side of the frames to give you more gluing service area for the deck especially where they join the next section?
Posted: Sun Nov 28, 2021 9:33 pm
by fallguy1000
Also, Dan. Piling on some, but did you ground the metal sender screws?
Posted: Sun Nov 28, 2021 9:43 pm
by Dan_Smullen
TomW1 wrote: ↑Sun Nov 28, 2021 9:31 pm
True, but I doubled up the frames so they are 1” thick, and letting the joint sit in the middle. A good 1/2” under then end of each with a fillet. Still maybe need a little more?
Posted: Sun Nov 28, 2021 9:44 pm
by Dan_Smullen
fallguy1000 wrote: ↑Sun Nov 28, 2021 9:33 pm
Pile it on Dan, I’m clueless about grounding. No wiring yet, but a ground wire from the sending unit to the ground bar under the insole will be good. Right?
Posted: Sun Nov 28, 2021 10:42 pm
by fallguy1000
The sending unit is metal. The issue is fuel entering the tank can create static.
Despite the fuel sender being insulated by a rubber insolater; it is for some ungodly reason that the sender metal be grounded which means you need to back out a screw and put it back in.
I did not and have not done it, yet, but Tom has indicated it is required. And I believe he is correct. But I can't stand the idea of loosening one of the screws that seals my tank sender...
Posted: Sun Nov 28, 2021 10:58 pm
by fallguy1000
Or maybe I am confused and it completes the circuit.
Posted: Mon Nov 29, 2021 5:41 am
by TomTom
Dan_Smullen wrote: ↑Sun Nov 28, 2021 9:43 pm
Boat is looking great.
Are you/ have you done a fillet from underside of gunwale to frame and taped this joint? Will you glass the top as well?
I think it would be cheap insurance to add a 1x1 each side of the frame if not. I did a similar thing on my OD 18 and the butt joint "telegraphed" through the gunwale on the top side so you could see a faint line.
Posted: Mon Nov 29, 2021 8:37 am
by VT_Jeff
TomTom wrote: ↑Mon Nov 29, 2021 5:41 am
I had seen some photos of this "telegraphing", possibly yours, so I routed a V groove into the top of my deck splices and filled with woodflour/epoxy in hopes that the butt joint would stay hidden. So far so good.
Posted: Mon Nov 29, 2021 10:31 am
by fallguy1000
The cause of print through is variations in the materials.
The best way to defeat printing through is post curing the boat or part prior to paint.
Here are two pictures of my helm riser, not postcured with holes filled with cabosil and epoxy. The filler probably ought to have had some milled fiber. So interesting how the gravity affected the direction of the sag. The side ones sagged out and the top ones down.
The riser was probably sitting in the paint room for 30 days. These manifested themselves as soon as the riser was subjected to 100F, no direct sun here, in the tent.
Adding fiber to the filler should help some, but post curing is the only sure fix.
Posted: Mon Nov 29, 2021 11:50 am
by TomW1
Dan a 1/2" is really not a lot for a deck to rest on when they are flexing with the motion of the boat. While Jeff's boat is 14' and his fix may work for him, your going out in the Bay in bigger water and waves.
Well think about it. Tom
Posted: Mon Nov 29, 2021 12:25 pm
by TomW1
fallguy1000 wrote: ↑Sun Nov 28, 2021 10:42 pm
Correct fallguy fuel entering the fill to the tank can create static thus the need for the ground. Do it by loosening one of the nuts underneath and using a loop fitting on the end of the ground wire attach the ground wire. Then run the ground wire to the fuel guage fitting on the tank and do the same thing, loosen one of the screws put the loop under it and retighten it. In your case fallguy use seperate screws for each ground don't double them up on one screw, this will let you tighten them down properly. Of course use the smallest loop possible. Don't worry boat mfg's have to do this to all there boats. All the builders before you have all had to do iit if they did it right.
Posted: Mon Nov 29, 2021 1:09 pm
by Dan_Smullen
fallguy1000 wrote: ↑Mon Nov 29, 2021 10:31 am
The riser was probably sitting in the paint room for 30 days. These manifested themselves as soon as the riser was subjected to 100F, no direct sun here, in the tent.CA92A7AB-8829-47FC-B1BA-8071BC9BEDD7.jpegC3D2092E-6592-45D2-A9F7-E6A23A77E6F1.jpeg
What is "post curing" Allowing the material to go up and down within temperature range?
Also, were these filled holes covered with glass?
Posted: Mon Nov 29, 2021 8:37 pm
by fallguy1000
Dan_Smullen wrote: ↑Mon Nov 29, 2021 1:09 pm
No glass, no room for glass as it was already glassed and I did not want to fair the sides again. Top was same. Already glassed, so no glass.
Post curing is heating the item up to about 155F for two hours with a ramp up and cool down. I post cured the hulls for 8 hours in a 40' shipping can.
Posted: Tue Nov 30, 2021 9:09 pm
by TomW1
Dan post curing is not needed in your case. A properly constructed joint will prevent print trhough. I have no print through after 12 years on my OD18. Just make sure you have plenty of glueing surface for the decks to rest on. JimW built the first C19 down in FL in 1996 and it is still running today. Many have been built since then, I almost built one myself before buying CL OD18.
Posted: Tue Nov 30, 2021 10:27 pm
by fallguy1000
A dark paint on any of these s&g or foam/epoxy boats will print through all sorts of stuff.
White or light paint, good seams, low variation in materials all contribute to less print through. But the best way is to cook them.
Totally unneeded for almost every build here; save a dark paint. Even then, you can accept print through and address it @repaint time.
Posted: Wed Dec 01, 2021 9:53 am
by Dan_Smullen
My assumption is that print through is ultimately inevitable if not covered with glass, but can be minimized with all of the appropriate prep. The tops of these decks will be covered with 12oz biax. I hope this prevents any print through. Print through on the decks, if it occurs, will bug the sh*t out of me every time I see it.
Posted: Wed Dec 01, 2021 11:00 pm
by fallguy1000
Dan_Smullen wrote: ↑Wed Dec 01, 2021 9:53 am
You may get a bit of it. 12 oz biax has stitching that can show thru. I have not had much trouble, but the boat has not seen a ton of hot sun; just the cabin got some and yes, had some print thru.
If it happens at all; you'll fix it on repaint. But probably won't get any..
Posted: Wed Dec 15, 2021 7:50 am
by MDFeen
Dan, I am building the C19 In Maryland (north of DC). I am wondering where you got your fuel tanks from.
Steve Feeney
Posted: Wed Dec 15, 2021 7:47 pm
by Dan_Smullen
Cool, Steve!
Chad Martin at Martin’s Custom Marine in Gloucester made them for me. I’ll send you his contact info.
Posted: Thu Dec 16, 2021 1:45 pm
by Dan_Smullen
Got my hands on a few Sea Dog pie plate hatches to finalizing hole sizes, and started mocking up the final frame/splash well/seating area.
Having held the sole short from the transom to allow open access to the bilge provided the need to add a cleat between the stringer knee and the motorwell side, as well as a sole extension. These cleats extend under the sole by 9" or so. Will be glued to the bottom of the sole, along the outboard stringer, and tie into the clamping board.
I milled these 1-1/2" x 3" from a chunk of spansih cedar I had in the pile. I regret not using Spanish cedar in lieu of all of the doug fir I used for cleats and and chines earlier in the build. SC is lightweight and easy to machine. It should be considered for any solid wood needs from here on out.
Glass on the insides of the motor well sides and front. Temporarily screwed together for fitment and head scratching. Deck drain needs to be integrated somehow. I'd like to recess them into the deck, like someone did on their SK14; think it may was Mojo... I'm reluctant to route the drain tube until I know where the waterline will be.
What if I have made the boat so heavy, even with 1-1/4" of lift under the sole, deck level is below waterline.
Posted: Thu Dec 16, 2021 8:29 pm
by Mojosmantra
Hey Dan - yes, that was me with the recessed drain, which is actually a detail I borrowed from Seaslug’s FS14. In my case it just drains to the bilge and is not self bailing - so the relationship to the DWL is unimportant. Also, the bottom of the recess is the top of the sole butt block. Is your sole already installed? Not sure how you would pull it off if that is the case - but there’s a bunch or smart people around here that can probably help out.
Posted: Thu Dec 16, 2021 9:56 pm
by Dan_Smullen
Mojosmantra wrote: ↑Thu Dec 16, 2021 8:29 pm
Yes, sole installed, but inadvertently leaving it 6” short gives me the opportunity to add to it with a butt block that will hold the drain.
It’s a sharp, functional detail. Juice is worth the squeeze!
Posted: Fri Dec 17, 2021 8:23 am
by TomTom
Dan_Smullen wrote: ↑Thu Dec 16, 2021 9:56 pm
Dan - if your C19 is anything like mine was (it may well be much lighter) - but it is plenty self bailing at the dock, but water will come in through the scuppers if you are mucking around at the back/ slow trolling in a following sea, all peering over the back after your buddy dropped the gaff etc etc…
I eventually went with keeping the scuppers plugged (with easily removable plugs) and a bilge/ pump when using it. Scuppers out when moored or on the trot line and no one in the boat.
Be careful that your bilge area can’t flood the rest of the boat (ie through a leaky chase tube) and is small enough that it won’t add much weight when/ if full.
I haven’t tried the Gemlux duck billed scuppers - they look great. Toyed with the rib style “ flattened pvc trailing hose ones” - I think they work great but ugly doesn’t even describe them!
Tried flaps/ ping pong balls too without much luck.
Good choice putting a small bilge in I think.
Went for a walk yesterday and saw this and thought of you … don’t know what the box in front of the transom motorwell is for - but the side seating is in a similar vain to what I have in mind on your build?
Posted: Fri Dec 17, 2021 10:34 am
by VT_Jeff
Just some more food for thought.
My GW 19 had something pretty close to the rear seats you're looking for. The deck went all the way to the transom, the splash well was "floating" above the deck at its front edge, something stored under it, I forget what. Rolled up fastback maybe?
The boxes behind those jump seats did not come down to the deck, they were open. There were batteries and 2-smoke oil stored there, sitting on the deck.
Scuppers went right through the transom from the deck. Never really had water come in through them that I recall, it was a pretty dry boat. My marina had the same boat and put a 115 4 stroke on to replace the 115 2 stroke. that sunk the scuppers, they needed to move the batteries firward.
Totally different animal I realize, but interesting design I think.
Posted: Fri Dec 17, 2021 10:56 am
by fallguy1000
If you want to make that 2" wide look; just go wider and make it all from plywood, enough for cupholders like Jeff showed. Then you can get your hand down inside there for fillets and a good mat backed tape. After taping; sand it all roundish for outside glass. Two layers of 6 oz with a neat coat of resin would be my layup.
Posted: Fri Dec 17, 2021 12:19 pm
by joe2700
TomTom wrote: ↑Fri Dec 17, 2021 8:23 am
The gemlux duck bills don't let a drop in on my FS17 when standing at the back, and water does come in if you put something in one to hold it open, when I was testing them. They slow the last of the water draining out, but when there is any significant amount of water they don't seem to restrict the flow, I assume it just takes a little pressure to push them fully open.
Posted: Fri Dec 17, 2021 1:33 pm
by Dan_Smullen
Great points to ponder, Fellas.
Absolute worst case scenario is water coming in the back during normal idle or drifting. There is no feasible correction after the build is done.
Weight must be accounted for now more than ever.
Batteries will be better suited under the console, and abandoning deck drains for horizontal scuppers will provide at least another 1-1/2" of piece of mind.
Posted: Fri Dec 17, 2021 3:09 pm
by VT_Jeff
Dan_Smullen wrote: ↑Fri Dec 17, 2021 1:33 pm
Sandbags in the bow.
Posted: Fri Dec 17, 2021 5:00 pm
by Jaysen
VT_Jeff wrote: ↑Fri Dec 17, 2021 3:09 pm
Fish bodies in the bow!
Posted: Fri Dec 17, 2021 5:47 pm
by VT_Jeff
Jaysen wrote: ↑Fri Dec 17, 2021 5:00 pm
Next level thinking right there!
Posted: Fri Dec 17, 2021 8:40 pm
by Dan_Smullen
VT_Jeff wrote: ↑Fri Dec 17, 2021 5:47 pm
Stack ‘em up!
Posted: Fri Dec 17, 2021 11:25 pm
by fallguy1000
Wouldn't you want start batteries near engine?
Posted: Sat Dec 18, 2021 7:06 am
by Dan_Smullen
fallguy1000 wrote: ↑Fri Dec 17, 2021 11:25 pm
Wondering the same thing myself. I don’t know enough about it to say.
What are some disadvantages of having 6’-8’ of battery cable between the starter battery and the engine? Some power loss?
Posted: Sat Dec 18, 2021 7:11 am
by Jaysen
Larger, more expensive cables is how you get around a the power drop for long runs.
Undersized cables will get hot inter heavy use. Starters should never have usage that would make that a problem.
Weight balance would normally trump that as you can just bump up cables via jumpers for those situations. That or step up a couple sizes for the bat to motor run.
Posted: Sat Dec 18, 2021 9:31 am
by fallguy1000
My Yammies came with pretty long cables, but maybe not long enough for what you are doing.
If you are gpong through a rigging grommet, based on what Jaysen said; if you can't make it; you'd get a high amperage power post amd place it near the engine and accessible and run say #2 or so wires back to it.
Bluesea 2017
https://www.bluesea.com/products/2017/D ... n-16_Studs
This one has 3/8" studs versus the 5/16" typical of marine batteries, but you'd be cutting off the engine leads and making it all custom..
Posted: Sat Dec 18, 2021 4:50 pm
by TomW1
Here is a table from West Marine that is the same as Ancor Cable Co. that I could not get to come up. The longer the run the heavier the cable has to be. You need to determine the starting amps of your motor first. My Yamaha 75 with a Group 27 battery has Number 2 wires for a 4' run as the battery is in the box next to it.
https://www.westmarine.com/WestAdvisor/ ... d-Ampacity I will double check the wire size when it is not raining out side. This also applies to the wire you take to your circuiit breaker beaker or fuse box. If it 15' from your battery then you need to add up all the amps attached to it and multipliy the distance to the battery by two. So if the length to the battery is 10' you need to use 20' on the chart.
Posted: Sun Dec 19, 2021 3:35 pm
by joe2700
fallguy1000 wrote: ↑Sat Dec 18, 2021 9:31 am
Bluesea 2017
My start and house batteries are in the console on my FS17. I have a powerpost like you linked under the motorwell then ran 4awg to the battery switch in the console. Marine batteries(and the cables that came with my outboard) use a 3/8 positive stud and a 5/16 negative stud. The duel power post comes in exactly that configuration as well:
https://www.bluesea.com/products/catego ... _PowerPost
Posted: Sun Dec 19, 2021 7:40 pm
by TomW1
joe2700 wrote: ↑Sun Dec 19, 2021 3:35 pm
Bluesea 2017
Yep the Negative is always a 1/16th smaller.. Tom
Posted: Sun Dec 19, 2021 8:31 pm
by Dan_Smullen
Bluesea 2017
I see. It's like a junction box. Thank you both for the links.
Glued in the motor well sides, and filleted tabbed them all the way around, including to the transom. Installed my sole extensions on butt blocks.
In lieu of deck drains, ovular scuppers running straight back to the transom will be the play. Rather than take the quick route and build some out of plywood scraps, I have opted for the mold method: and by mold, I mean some wrapping paper tubes, a strip of fir and some pourable foam. (same tubes were used last year for a wire chase mold) I need these next, so structure on the boat is going to have to wait until I make these and am willing to cut some big holes in the transom.
Posted: Sun Dec 19, 2021 8:57 pm
by fallguy1000
fyi
All terminations in marine applications require crimping ...
Posted: Sun Dec 19, 2021 9:02 pm
by Dan_Smullen
fallguy1000 wrote: ↑Sun Dec 19, 2021 8:57 pm
fyi
Crimpin’ ain’t easy, Dan.
Posted: Sun Dec 19, 2021 9:16 pm
by fallguy1000
Dan_Smullen wrote: ↑Sun Dec 19, 2021 9:02 pm
fyi
I realize this...I spent quite a bit on my crimper after learning soldering is a no-no.
You can get a hammer crimper for smaller jobs.
Posted: Sun Dec 19, 2021 9:17 pm
by fallguy1000
Check n see if your sizes are in this one. Goes to 4/0. I have some 2/0 in the Skoota, and I am doi g a lot so I bought a big one.
https://www.solar-electric.com/hacrtofo ... 20Products
Posted: Thu Dec 23, 2021 3:08 pm
by Dan_Smullen
Posted: Thu Dec 23, 2021 4:45 pm
by fallguy1000
I avpid touching that shit like the plague. It gets into my finger webs and drives me up a wall. Lint rollers help, but yuk.
Posted: Thu Dec 23, 2021 7:09 pm
by TomW1
Dan here is a various size of scuppers from Hamilton Marine many of the guys here have used them.
https://shop.hamiltonmarine.com/inet/st ... D=scuppers
Posted: Fri Dec 24, 2021 8:41 am
by Dan_Smullen
Thanks for the link Tom. I'll need something like that if I out anything on the outside, but if they are high enough above the WL, I'm going to leave them open.
Strength is there...
Clean enough to leave open if I can...
From the inside...
Posted: Fri Dec 24, 2021 8:57 am
by VT_Jeff
Looks great Dan! To my eye it looks like you have plenty of freeboard below that scupper, will be interesting to see if your feet stay dry.
Posted: Mon Jan 03, 2022 1:33 pm
by TomTom
Nice looking tubes Dan. I hate to say this but am pretty sure that if you don’t have some sort of flap/ duckbill/ plug, water will come in your drain tubes at some point fairly frequently throughout the day when you have the right combination of someone at the back/ on one side of the boat and you are reversing/ turning etc. It even happens on my friends GS28, and my stretched C19 - which now has a pretty generous gap above the waterline. It’s the nature of the beast. The ugliest but simplest and most effective solution is the trailing floppy elephant trunk thingies you see on ribs. Looking fwd to seeing her in the water.
Posted: Mon Jan 03, 2022 7:41 pm
by Dan_Smullen
TomTom wrote: ↑Mon Jan 03, 2022 1:33 pm
Nature of the beast, for sure. Taking on a little water under certain circumstances is tolerable. Wallowing around ankle deep most of the day will be unacceptable. I'll post a question or two on your thread.
I took advantage of downtime around the holidays. Juggled some work stuff, ever present home projects, and of course, the boat.
Tabbed in aft framing/seating structural members, glassed in the scupper tube ends, and cut both port and starboard side decks, and glued and tabbed in the sb. More upside down tabbing that everyone wont admit that they love. Laying down makes it easier, and wetting out the plywood first, allowing it to tack, gives the tape something to stick too, otherwise, it's much like shooting pool with a piece of rope.
A few boards of spanish cedar on order for the interior combing, finalize seating aft, and then glass the whole thing!
Fit the side decks lengthwise, and then clamped a batten down the inside, and scribed the rub rail on the bottom, outboard. Cut to the line with shallow set skil saw blade, and planed to the line to remove the bumps.
Had I to do it over, I believe I would approach it as R Marsh and others have done. Bending the combing first, and then flush cutting the deck to it. Either way works fine, I suppose.
Posted: Mon Jan 03, 2022 11:34 pm
by TomTom
Making some great progress there. Looking good.
Posted: Mon Jan 03, 2022 11:41 pm
by TomW1
Looks real good Dan. Tom
Posted: Mon Feb 14, 2022 12:45 pm
by Dan_Smullen
It's been over a month since my last post. Work is progressing as I march toward the finish line.
With a coat of primer in the bilge, I was comfortable closing it up while accounting for the starter battery in the starboard compartment. Plastic hatches from off the shelf was a more direct route than molding water proof hatches for these 2 openings, and I think worth the expense.
Quick survey... Are these considered, inwales or combing or both?
I'll allow them to identify as either, but what they are, is re-sawn spanish cedar. I really like this material due to it's light weight, and ease of use. 3 layers at 5/16" laminated in place clamped to the inside of the decks, then removed, shaped and then permanently glued in place with fillets and tabs on the bottom side. Top edges left proud up forward to channel water away from the cockpit; flush from midship aft. I miscalculated the width of laminations needed to account for the sheer, so I skipped a layer of the aft laminations and accounted for the transition as such. More upside down tabbing wasn't too bad if i wet out the underside of the decks, lets it get tacky for a few hours, then pre wet the 6" 12ox biax tape. Again, every layer added contributes to the rigidity of the finished boat. Starboard side is done; working on doing the same on the port.
I think next is anchor locker hatch and glass on the top deck, then glass main deck, and then it will be time for the console.
Posted: Mon Feb 14, 2022 1:43 pm
by Jeff
Dan, nice progress!!! Great looking machine as well!! Jeff
Posted: Mon Feb 14, 2022 1:45 pm
by Dan_Smullen
Jeff wrote: ↑Mon Feb 14, 2022 1:43 pm
Yessir. Thank you Jeff. She’s a beast. Most of the time it just takes up space, but when we need it, it’s the right tool for the job.
Posted: Mon Feb 14, 2022 2:05 pm
by Jeff
I am sure!!! Jeff
Posted: Mon Feb 14, 2022 4:20 pm
by fallguy1000
I call it coaming.
Posted: Mon Feb 14, 2022 4:25 pm
by fallguy1000
I call it coaming. Out and in are for canoes, generally. Sheer clamp or rubrail often with gunwale.
Happy Valentines. Dan Fall finger sketch.
Corrections welcomed.
Posted: Mon Feb 14, 2022 5:02 pm
by TomW1
Dan by definition the outside is a rub rail, and the inner is an inwale. Both are structural and a rub rail is not needed if an inwale is present if someone wants to just wants to put a rubber piece on for protection and reduce beam for towing laws overseas. An inwale is stronger as it is cut into the frames and glued to them.
So, as fallguy says you have combing.
Am enjoyiing watching your C19 come together.
Posted: Mon Feb 14, 2022 9:25 pm
by Dan_Smullen
fallguy1000 wrote: ↑Mon Feb 14, 2022 4:25 pm
Happy Valentines to you too, Dan. The sketch made my day, and I'm picking up what you're throwing down. I trust a man of your experience from the Great North has intimate knowledge of the parts of a canoe.
I've always recognized combing as a vertical surface around an opening. The vertical wall around the seat well of a sit in kayak, or the apron around the opening of a fish hold on a seiner. Next, we'll discuss how to spell it.
Maybe, as a cabinet guy, I'll call it an apron.
TomW1 wrote: ↑Mon Feb 14, 2022 5:02 pm
Thank you Tom, I enjoy sharing my experience in the process. I have both rub rail and coaming, (or combing). Crazy strong. I can stand on the edge of the combing, which spans 42" or so, with absolutely zero flex. I think she can withstand bouncing off a dock.
Posted: Mon Feb 14, 2022 9:28 pm
by fallguy1000
Posted: Mon Feb 14, 2022 9:56 pm
by Dan_Smullen
Can’t argue with that FG. From here on out, it’s inwale.
https://www.merriam-webster.com/dictionary/inwale
Posted: Mon Feb 14, 2022 11:16 pm
by fallguy1000
Awesome DS. Thanks for the smile.
Posted: Tue Feb 15, 2022 10:16 am
by Browndog
Looking good. Keep it up!
Posted: Tue Feb 15, 2022 9:56 pm
by VT_Jeff
If you can stretch a skirt over it, I'll be good with calling it a coaming.
Great progress, and nice work on the super-sturdy apron, you're gonna be pleased with that when your occupants are getting thrown into it in the stink.
Posted: Tue Feb 15, 2022 10:30 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Feb 15, 2022 9:56 pm
In the stink. That’s when it’s gonna count regardless of what we call it.
Posted: Wed Mar 02, 2022 5:10 pm
by Dan_Smullen
Inwale complete and top decks sanded smooth. Still need to work on the bottom edge of the rub rail a bit, but getting there. Most of the deck is glassed with one layer of 12oz biax.
Posted: Sun Mar 13, 2022 1:47 pm
by Dan_Smullen
Sticking glass on any bare wood inside and spreading epoxy thickened with glass spheres on the insides of the sides, filling the weave and leveling things as I contemplate the level of fairing attention these areas will receive. Not much in the way of pictures.
We did quick spring break trip to Corolla, NC where I visited a small display of local boats. I was excited to see the shared DNA with my build and this 1957 strip planked runabout. This hull resembled a scaled down sport-fisher with rounded bow, exaggerated flare and tumble home at the stern. The bow deck and raised inwales reminded me of the C19.
Also, scored some jewelry at a boat salvage yard in Chesapeake, VA. A while yet before these guys are needed, but they will help me lay out deck penetrations prior to glassing.
Posted: Tue Mar 22, 2022 10:19 am
by VT_Jeff
That's an amazing haul right there!
Posted: Wed Mar 23, 2022 6:52 am
by Browndog
Sweet hardware!
Posted: Mon Mar 28, 2022 5:15 pm
by Dan_Smullen
Posted: Mon Mar 28, 2022 9:45 pm
by VT_Jeff
Boy that picture of the router setup is worth 1000 words! Did you need to vary the "depth" at all as you went around? The results in the photo look great.
Posted: Tue Mar 29, 2022 6:26 am
by Dan_Smullen
VT_Jeff wrote: ↑Mon Mar 28, 2022 9:45 pm
Yes. Varied the depth. Actually went a little too deep in some spots that I’m in the process of filling with goo. A bit with radius corners would have been ideal. Even at the right depth there was some sanding and cleaning up afterwards.
Posted: Tue Mar 29, 2022 6:35 am
by VT_Jeff
Dan_Smullen wrote: ↑Tue Mar 29, 2022 6:26 am
Yeah, that's exactly what I was wondering, if you were cutting into the side panel with the bit. But I'm guessing that's better/easier fix than being too shallow and needing to cleanup with a shoulder plane or a chisel or something along those lines. You can't spell "good" without 'goo".
Posted: Tue Mar 29, 2022 1:40 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Mar 29, 2022 6:35 am
You always mange to hit the nail right on the head. I can't spell "good enough" without "goo!"
Posted: Thu Mar 31, 2022 5:26 am
by Rmarsh
Looking really good. Anchor hatch came out nice.
I love working with Spanish cedar. Made a pair of exterior doors for a town library with some not to long ago....good stuff.
Have you come to any decisions on paint or paint colors? I know there's a lot more sanding and prep...but looks like you're getting close to that stage
Posted: Thu Mar 31, 2022 8:47 pm
by Dan_Smullen
Rmarsh wrote: ↑Thu Mar 31, 2022 5:26 am
Thanks! I love the cedar. Super light and fun to work with.
Actually feel like I’m getting close on sanding. I rolled on a good layer of micro spheres, then a layer of fairing compound. Sanded, and the. Skimmed any low spots. Sanded again, and I think about half of the sides are ready for primer. Will flood coat the sole and skip the fairing compound.
For paint, I’d like a flat gray for the sole and sides. Maybe Parker Duck Boat paint. Same stark white Alexseal I used on the bottom I’ll use on the deck. Kind of hell bent on Stars and Stripes blue for the hull above the waterline.
Posted: Sun Apr 03, 2022 9:27 pm
by Dan_Smullen
For mineratt, 1/2 of the side decks glassed. Tempted to add another layer just because. We’ll see.
Posted: Mon Apr 04, 2022 3:37 pm
by fallguy1000
I have some brand new casters if u r interested. I bought a bunch and no use.
Posted: Tue Apr 05, 2022 3:35 pm
by Dan_Smullen
fallguy1000 wrote: ↑Mon Apr 04, 2022 3:37 pm
I don't follow, FG. Wheels?
Posted: Tue Apr 05, 2022 3:57 pm
by fallguy1000
Yeah, wheels for the strongback.
Posted: Tue Apr 05, 2022 8:10 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Apr 05, 2022 3:35 pm
So you don't need to roll your strongback on pipes like ancient Egyptians building pyramids. I susoect you have casters, but the photo looks medeviel.
Posted: Wed Apr 06, 2022 10:46 am
by mineratt
Dan_Smullen wrote: ↑Sun Apr 03, 2022 9:27 pm
Dan, thank you for the picture. I wanted to try to fully encapsulate the rub rail with glass while it was upside down but I just could not do it with the 12 oz biax tape. I got the side of the boat tied to the underside of the rub rail then had to trim off the rest of the tape as it completely lifted off. I did go back and add two layers of 2 oz cut strips to provide a little protection when i flip it over. I was trying to attack it while it was upside down to control the drips. But I like how yours looks, I like how it ties the deck to the sides of the rub rail. I am thinking that seam will be under some pretty good stress with rod holders, cleats, peopling sitting on it, etc. When i get to this stage I think I will do what you are doing.
Posted: Wed Apr 06, 2022 5:53 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Apr 05, 2022 8:10 pm
More optimistic that in a few months I’ll be off the strong back and my casters will be available for someone else to use.
No pipes, but occasionally harness the power of the ancients and levitate the boat.
Posted: Mon Apr 11, 2022 10:10 pm
by Dan_Smullen
Flood coat a epoxy moderately thickened with glass microspheres. Leveling it with 60 grit and this leaves only a few depressions that I believe I can fill with fairing compound. You can seem them easily.
Grinding my way toward primer!
Posted: Tue Apr 12, 2022 8:45 am
by VT_Jeff
Maybe you can see them easily, looks pretty flat from here!
Posted: Tue Apr 12, 2022 5:40 pm
by TomW1
Looks good Dan. Tom
Posted: Sun Apr 17, 2022 3:41 pm
by Dan_Smullen
Pecking away, filling here and smoothing there, but real close to priming the deck and the inside. Will wait to do the sole until the console is glued in place.
Phenolic micro balloons thickened with cabosil has been the best. Goes on smooth and not too hard to sand.
Posted: Mon Apr 18, 2022 9:01 am
by TomTom
Looking good Dan - like what you did with the motorwell. Keeping my eyes open for the launch!
Posted: Wed Apr 20, 2022 12:39 pm
by glossieblack
Bet you're looking forward to getting primer on the decks and internal sides. Looking good
Posted: Sun May 01, 2022 8:20 pm
by Dan_Smullen
I took VT Jeff’s advice, and just spread the damn primer to “see what I’ve got.” It was the advice I needed to quit chasing little divots and such. I rolled a heavy coat of Inter Protect over surface sanded with only 60 grit, and sanded with 120 once dry. All feels smooth and any low spots I had missed were conspicuous, which I filled with Awl Fair, a beautiful product. It has the remarkable ability to stay in low spots as it’s spread with a rigid metal edge, and sands beautifully. I’m
Calling the cap ready for surfacing primer, but I think I’m putting this on hold to fiddle with the anchor locker hatch and mock up the console.
Posted: Mon May 02, 2022 1:07 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sun May 01, 2022 8:20 pm
I took VT Jeff’s advice.....
For the record, I begged him to take Trent or Cameron's advice on anything related to painting and use me for a "best way to cover Allman Brothers on solo acoustic" resource only.
Glad it worked out though, it is amazing how much easier a quick coat can make it to see your actual progress!
Posted: Thu May 05, 2022 1:38 am
by TomTom
For what it’s worth … there are places your eye is drawn to on a boat and well worth fussing over … and then there are places where once one has added all the fittings, hard ware etc one wonders why on Earth one fussed over them.
The gunwales tend to show imperfections - but places that I really think I wasted a lot of time include the motorwell, anchor lockers, inside the console, the sides inside the boat (although I have shelves that break this up) ….
One thing I can say is once it’s on the water you tend to forget about the places that niggled you…
I agree wholeheartedly that putting primer down sooner rather than later will help you see where these places are.
It looks very nice and fair to me though. Well done
Posted: Wed May 18, 2022 9:03 pm
by Dan_Smullen
I’ll save some time not fairing the bottom side of the gunnels.
Fairing in a good place for the time being. Moved on to console planning. Started with a big idea, but upon mocking it up in cardboard, it became apparent that it would be better suited for a 28’er. Will save it for the next one…
Trimmed it down and started assembling the base.
We consolidated our shops into one space this month. The layout is evolving, but we’re making noise and chips, so I’m back to spending some free time thinking about the boat.
Posted: Wed May 18, 2022 10:47 pm
by VT_Jeff
Dan_Smullen wrote: ↑Wed May 18, 2022 9:03 pm
"it became apparent that it would be better suited for a 28’er."
Is it a washer or a dryer?
Posted: Thu May 19, 2022 12:00 am
by fallguy1000
Nice to walk by the console. I messed mine up. Wheel too low, screens too low, footrest too low. Too far into it, but gonna add a high footrest.
Posted: Thu May 19, 2022 6:20 am
by TomTom
Hey Dan - have you bought a motor yet?
Is your transom for a 20" or 25" shaft?
If you haven't bought motor yet I would consider a 25" shaft and raising transom 5" (if its not that already).
I like the look of your console and how you are doing the corners - that's what I did.
Build going well!
Posted: Thu May 19, 2022 9:38 pm
by Dan_Smullen
VT_Jeff wrote: ↑Wed May 18, 2022 10:47 pm
Builder's tip: A console the size of a Viking range is not appropriate.
TomTom wrote: ↑Thu May 19, 2022 6:20 am
Build going well!
Thank you! Feeling a little slow, but we're making progress. Great minds think alike!
Regarding engine shaft length, way back when I was cutting the transom, I wish I had an appreciation for the differences between long and short shaft outboards. Had I it to do over, I would have made the cutout for a 25" motor. I looked at a number of different ways to raise the cut out, but not willing to undertake.
Unless I'm convinced otherwise, the juice is not worth the squeeze. Why would you consider it?
A guy who just got done stretching his C19 a few feet has a much different understanding of what juice is worth
Posted: Sat May 21, 2022 11:55 am
by TomTom
Dan_Smullen wrote: ↑Thu May 19, 2022 9:38 pm
Here is a picture of the old 20” Transom with on the C19 before the extension and after with the 25” transom.
I also had to raise the transom and it was pretty straightforward - I just removed a layer of plywood on either side about 6” down from the top on ones side and 4” on the other so I had a staggered joint.
For me it does make a difference - your engine is that much further from the water, you are much less likely to take water over the back and also it’s quite nice that the bottom set of mounting bolts are above the sole level and don’t have to be tightened in the bilge.
I thought I would mention it because you could still change it now without too much difficulty.
Obviously it’s not an earth shattering difference - but one I would consider.
Posted: Tue Jun 14, 2022 9:03 pm
by Dan_Smullen
Almost time for a monthly report! Console has been the focus. Paint is ordered for the hull, so it’s likely I’ll be more excited to spray it then I will be to fix transom cut out height.
All seams taped with 12oz, and flat areas covered with 10oz. The dash and top corners are Azec PVC. Epoxy and glass adhesion to the pvc was best on the raw routes corners, but barely adequate on surfaces that were only sanded with 60 grit.
Posted: Wed Jun 15, 2022 9:53 am
by Jeff
Nice work Dan!! Jeff
Posted: Wed Jun 15, 2022 10:14 am
by VT_Jeff
Console looking great Dan! What's you plan for the doors, fancy louver or just ply/glass? I suspect XP could output some very cool doors without breaking a sweat.
Posted: Thu Jun 16, 2022 7:30 am
by Dan_Smullen
Thank you Jeffs!
I got a piece of knock off Starboard and will do something with a rabbeted frame and piano hinge.
Posted: Sun Jun 26, 2022 5:20 pm
by Dan_Smullen
Productive weekend making progress on the leaning post and splash well deck area. It feels good to accomplish some small goals that I have been thinking about for almost two years. Last sheet of 1/2" Joubert. Must be close to done; no more material.
Splash well deck is solid with a layer of 1708 on it. The last piece of material to be integrated into the boat, and probably the nicest FG layout I’ve ever done. (Got it figured out for the next one). Also drilled the lumber holes oversized, filled with silica, and drilled out again.
When leaning post is done and glued in place, and console glued in place, it’s time for paint! Good July goal imo.
Alexseal
Stars and Stipes Blue!
Posted: Sun Jun 26, 2022 6:43 pm
by TomW1
Nice work there Dan!
Posted: Sun Jun 26, 2022 11:00 pm
by Fuzz
Hate to tell you this but you are never done working on a boat until you sell it
Posted: Mon Jun 27, 2022 9:33 am
by VT_Jeff
Your ability to print your ideas in plywood is incredible!
Does the top/opening of the leaning post become a backrest or just for storage access?
Posted: Mon Jun 27, 2022 11:56 am
by cape man
Posted: Mon Jun 27, 2022 1:33 pm
by Dan_Smullen
Fuzz wrote: ↑Sun Jun 26, 2022 11:00 pm
Much like any home project we have undertaken.
VT_Jeff wrote: ↑Mon Jun 27, 2022 9:33 am
Just a few hours with a computer and a cnc. It's a luxury for sure. Time saved cutting parts via cnc, is invested into indecisiveness and indecision over inconsequential details.
Not a backrest. Only flips up for storage. I'm talking to a metal guy about a backrest/rod holder.
Posted: Tue Jun 28, 2022 7:31 am
by TomTom
Dan_Smullen wrote: ↑Sun Jun 26, 2022 5:20 pm
Boat builders are never done - they just take a break sometimes to use their new toy
Progress looks great. Love the console.
Posted: Mon Jul 04, 2022 6:31 pm
by Dan_Smullen
Interprotect on the sides showed a few pin holes and missed spots. Spread a little AwlFair in those. Needs some time to cure.
Posted: Fri Jul 08, 2022 9:19 am
by VT_Jeff
Dan_Smullen wrote: ↑Mon Jul 04, 2022 6:31 pm
FTR, I found that gel-magic was great for pinholes. No drip, perfect consistency every time.
Posted: Sat Jul 30, 2022 9:52 pm
by Dan_Smullen
Chopped 2” off of the leaning post legs after a last minute lean check. Tabbed in place and then flood coated the 2nd half of the deck. Flood coat was epoxy slightly thickened with glass microspheres.
Posted: Tue Aug 02, 2022 12:59 pm
by VT_Jeff
Dan_Smullen wrote: ↑Sat Jul 30, 2022 9:52 pm
Phew!
Posted: Tue Aug 02, 2022 7:50 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Aug 02, 2022 12:59 pm
Phew!
Tragedy averted!
Posted: Sun Aug 14, 2022 8:54 pm
by Dan_Smullen
Was just reminded that I started this thread on 8/23/19. Looking unlikely I get it painted before the 3 year mark. Oh well. Progress continues.
Time has been spent fairing around the bottom of the leaning post, epoxy coating bright work and sanding with 320. Also fixed a flub that had been bothering me on the rub rail at the bow. A tough spot that’s wedged up in the corner of the garage, but I took the time today to fill it in with a few strips of 1708 and thickened epoxy against a batten covered with packing tape. A little more sanding required…
Anchor locker hatch opening needs some love. The ready for primer.
Posted: Sun Aug 21, 2022 8:10 pm
by Dan_Smullen
64oz of Alexseal surfacing primer on the top, insides, console and leaning post. Got me 2-1/2 coats on the cap, and a solid 2 on everything else. I’d like to do 3-4 coats to be sure there is enough material to sand smooth, but still leave a layer behind, but I’m saving the 1/2 gallon I have left for the outside of the hull.
Posted: Sun Aug 21, 2022 8:13 pm
by fallguy1000
Enjoying the build...
Am I an arse if I ask why you did not go full height transom? I suppose the boat is unsinkable, so less important..
Posted: Sun Aug 21, 2022 8:19 pm
by Dan_Smullen
fallguy1000 wrote: ↑Sun Aug 21, 2022 8:13 pm
Thank you! Me too!
I’m definitely not calling it unsinkable. Bad juju goes along with that phrase.
Not an ass. Good question. Early on, Jacques advised against a full transom and bracket on the 19, although I’d love it with a fish box across the back. With hindsight, I would have cut it for 25” shaft, but that ship had sailed and dont have the stomach for the mod.
Posted: Mon Aug 22, 2022 11:13 am
by VT_Jeff
No, that's not why you're an arse.
Looking great Dan (Smullen)!
Posted: Mon Aug 22, 2022 1:46 pm
by Cowbro
Dan_Smullen wrote: ↑Sun Aug 21, 2022 8:19 pm
Thank you! Me too!
I think FG1K might have meant full height motorwell bulkhead, not transom. In that case, i am also a little curious.
Phil
Posted: Mon Aug 22, 2022 3:16 pm
by cape man
Nice moose rack!
Posted: Mon Aug 22, 2022 4:05 pm
by fallguy1000
Yeah. I mean the motorwell full up.
I hate backing into oncoming waves and filling the boat.
Sorry I didn't see it sooner for timelier dialogue.
But backing does happen now and then; especially if trolling or drifting and snagging bottom..I always end up putting on fishing bibs, soaking my shoes, etc
And if you are priming; you could sneak it in, yet!!
Posted: Mon Aug 22, 2022 8:51 pm
by fallguy1000
Not tryin to cause a fuss. Heck, I need help on my boat because I really ought to have installed bait stations and kill boxes.
Posted: Mon Aug 22, 2022 9:31 pm
by Dan_Smullen
fallguy1000 wrote: ↑Mon Aug 22, 2022 8:51 pm
Ahhh. I gotcha. I’m usually a little slow in comprehension, but quick to to tap and type.
Man, I guess it was a design decision. I pushed that bulkhead back a few inches and lowered it for outboard clearance. You’re right. It could be a little low. I’ve been on a fair amount of skiffs with no splash well and have been fine. I hope to find out how it works soon!
Posted: Sun Aug 28, 2022 7:26 pm
by Dan_Smullen
All primer sanded with 320, but think I need another coat in some spots. Oh well. I guess primer is cheaper than paint.
Posted: Sun Aug 28, 2022 11:24 pm
by fallguy1000
I'd two coat that and then 320 again.
Posted: Mon Aug 29, 2022 12:22 am
by TomW1
Yes, use primer if you don't have all the wood, and everything covered by it. Follow fallguys suggestion and do not leave anything bare. Tom
Posted: Mon Aug 29, 2022 6:10 am
by Dan_Smullen
fallguy1000 wrote: ↑Sun Aug 28, 2022 11:24 pm
Roger that. 1 probably wouldn’t be enough.
Posted: Mon Sep 05, 2022 8:07 pm
by Dan_Smullen
Two extra coats of primer were worth the fuss. As I was waiting for the last few spots of primer to dry enough to sand, I was looking at other nicks and pin holes, and began to say things to myself like, “ that’s going to get nicked anyway.” And “that’s going to get covered by non skid.” I guess I got it close enough, but I had a window to paint, and didn’t want to miss it.
3 coats sprayed between 9 and 3. Plenty of dust jibs to buff out, and several runs to address, but this milestone is behind me, and I’m going to enjoy installing some hardware on the top side.
Re: C19 in Richmond, VA
Posted: Tue Sep 06, 2022 5:26 am
by cape man
Looks great from here!
Posted: Wed Sep 07, 2022 12:41 am
by Fuzz
Dang, even the run shines
going to be nice.
Posted: Sun Sep 25, 2022 8:32 pm
by Dan_Smullen
As the runs continued to haunt my dreams, I sanded the topside with 320 and shot it again. Also rolled 2 coats of dark gray surfacing primer on the outside to be sanded this week.
Posted: Mon Sep 26, 2022 9:11 am
by Jeff
Looks good Dan!! Jeff
Posted: Mon Sep 26, 2022 12:18 pm
by Fuzz
Dang dude even your primer is shinny.
Posted: Mon Sep 26, 2022 5:47 pm
by TomW1
Looking good Dan, step by step you are getting there. Tom
Posted: Sun Oct 09, 2022 11:07 am
by Dan_Smullen
The first preliminary photos of a painted boat are trickling in from the garage.
4 coats of Stars and Stripes Blue! If you get real close, you can see the orange peel, and we have some runs, but it’s time to move on.
Posted: Sun Oct 09, 2022 1:06 pm
by TomW1
It looks good as long as you don't mind your paint job no one else will notice the paint job either. I like the colors. Tom
Posted: Mon Oct 10, 2022 8:40 am
by VT_Jeff
Really impressed with that paint job, Dan. Color is great and the color combo is really nice with the white cap and bottom, very very sharp! Congrats and another huge milestone!
Posted: Mon Oct 10, 2022 3:42 pm
by Dan_Smullen
VT_Jeff wrote: ↑Mon Oct 10, 2022 8:40 am
Thank you, Jeff and Tom! I've had these colors in my mind for 3 years now. It is very satisfying to see them live. The product is very forgiving, user friendly, and the local rep was above and beyond helpful with coaching and available for advice in the heat of the battle on Saturday.
Finish will not meet the Cracked Ribs reflect a beer can standard, but will hazily reflect the image of a dog. So I have that going for me.
Posted: Mon Oct 10, 2022 3:55 pm
by VT_Jeff
Pickup some hazy ipa!
Posted: Mon Oct 10, 2022 4:37 pm
by fallguy1000
Keep on keepin on. Looks good from here..
Posted: Sun Oct 16, 2022 8:58 pm
by Dan_Smullen
Feels good to do some work on the boat that doesn’t require mixing, vacuuming, or a respirator.
Piddling with first coats of varnish and hardware. A variety of oval head screws sizes. #s 6, 8, 12 & 14 all have a place. I’m sealing all thru hulls with 4200.
Forward fuel vent was too close to in line with the fill hose, so it took some wrestling to get the fill cap and the vent tight to the cap and hull, respectively. It will be a bad day if any of this stuff ever need to be replaced.
Posted: Sun Oct 16, 2022 10:09 pm
by Fuzz
Bling time
Posted: Mon Oct 17, 2022 9:38 am
by VT_Jeff
Nice to finally do a little sledding after all that climbing!
Love the radius work on the console and cap, very cool look!
Posted: Mon Oct 17, 2022 10:46 am
by Jeff
Really nice work Dan!!! Jeff
Posted: Mon Oct 17, 2022 2:16 pm
by TomW1
Dan you are going to have a really nice C19 when you are finished with her. Keep up the good work.
Posted: Mon Oct 17, 2022 6:32 pm
by Dan_Smullen
Thank you, fellas! It is indeed nice to do some sledding!
There is finality in some of these details. Once a part is finish screwed in place, it is 100% done. With previous steps, there are always countless more steps to be done.
Posted: Sun Nov 06, 2022 6:48 pm
by Dan_Smullen
Non skid and paint touch up, not exactly done…
Did the ol’ sprinkle rubber sand in wet paint trick. Coverage was inconsistent and ran out of paint before the grit was sufficiently covered. More paint in the way, but outside of the safe to recoat without sanding window May present some challenges. I’m optimistic the Alexseal rep has some good advice tomorrow.
I’m certain we’ll overcome.
Posted: Sun Nov 06, 2022 7:16 pm
by OrangeQuest
Boat is looking absolutely beautiful.
Posted: Mon Nov 07, 2022 11:39 am
by Dan_Smullen
OrangeQuest wrote: ↑Sun Nov 06, 2022 7:16 pm
Thank you, sir!
Drilled for rod holders after the effects of my pre dinner hazy IPA wore off and did a few test holes on scrap. 2-1/8” hole saw drilled at a matching angle was required. It was helpful to use the tube insert as a drilling guide, and used the gaskets as a visual mock up.
Posted: Tue Nov 08, 2022 1:16 pm
by VT_Jeff
The bling fit-out continues, nice!
That top photo will make a good "before" photo along with the same "after" shot with 2 young Smullens in those seats with wind-blown hair and a rooster tail behind them. Can't wait!
Posted: Tue Nov 08, 2022 1:37 pm
by Dan_Smullen
VT_Jeff wrote: ↑Tue Nov 08, 2022 1:16 pm
Love it! This will be first order of business!
Posted: Fri Nov 11, 2022 10:36 am
by fallguy1000
Do those rodholders have drains?
Posted: Sat Nov 12, 2022 5:37 pm
by Dan_Smullen
fallguy1000 wrote: ↑Fri Nov 11, 2022 10:36 am
They’re open at the bottom. They drain on to the deck.
Posted: Sat Nov 12, 2022 5:47 pm
by fallguy1000
I gotta find some with drains...or 1" rail mounts. But I'd prefer to mount them in the deck and rest them on the rails.
Posted: Sun Nov 13, 2022 8:35 am
by Dan_Smullen
fallguy1000 wrote: ↑Sat Nov 12, 2022 5:47 pm
Gemlux and Boat Outfitters should have some, but cost is crazy.
Posted: Sun Nov 27, 2022 6:48 pm
by Dan_Smullen
Pecking away at loose ends while I work towards getting a motor and trailer, but with the bow deck complete, I think 12.5% of the boat is 100% complete.
Posted: Mon Nov 28, 2022 3:37 am
by OneWayTraffic
Dan_Smullen wrote: ↑Sun Nov 13, 2022 8:35 am
Can you get railblaza fittings in the USA? Good for when you might want to relocate a rod holder.
https://www.railblaza.com/
I've stolen two stainless holders off the donor boat, and along with four railblaza fittings/rod holders and some plywood/glass holders should be fine. Total cost under $100.
Posted: Mon Nov 28, 2022 9:25 am
by VT_Jeff
"I think 12.5% of the boat is 100% complete."
Reminds me of "Christine" for some reason. Are you pushing the boat around the neighborhood by any chance?
Posted: Mon Nov 28, 2022 9:26 am
by VT_Jeff
Love those hatch hinges btw, barely visible!
Posted: Mon Nov 28, 2022 11:04 am
by Dan_Smullen
VT_Jeff wrote: ↑Mon Nov 28, 2022 9:25 am
No, but often making motor boat noises in the garage.
Hinges are 2" Sea Dog butt hinges. I started with friction piano hinges, but had a hard time getting the margins straight enough to make the hatch fit in the hole with a tolerable margin around the edge. Not watertight, but probably splash resistant.
Posted: Mon Nov 28, 2022 2:02 pm
by VT_Jeff
Dan_Smullen wrote: ↑Mon Nov 28, 2022 11:04 am
Hey now!
In "Christine", a kid was rehabing an old car, but because the car was haunted, all he had to do was push it around the neighborhood at night and it would rejuvenate itself, but not in a logical pattern. E.g. half the front bumper would be brand new and the other half would still be old and rusty. So, like 12.5% was 100% complete. Like your boat, "Jenny's New Kitchen".
Posted: Thu Dec 01, 2022 7:18 pm
by Dan_Smullen
Aft starboard quarter is sorted. Maybe at 14% complete now. Also, a console glamour shot.
Posted: Thu Dec 01, 2022 8:10 pm
by VT_Jeff
Glamour indeed, looking sweet!
Posted: Mon Dec 05, 2022 9:42 am
by Jeff
Nice work Dan!!! Jeff
Posted: Mon Dec 05, 2022 10:17 am
by fallguy1000
What is the low cleat for?
Posted: Mon Dec 05, 2022 12:30 pm
by cape man
Very sexy!
Posted: Mon Dec 05, 2022 12:42 pm
by Cowbro
fallguy1000 wrote: ↑Mon Dec 05, 2022 10:17 am
Run the dock line through the fairlead and down to the cleat. It keeps the cleat off the gunnel.
Not often seen on boats of this size, but i love the execution.
Phil
Posted: Wed Dec 07, 2022 4:01 pm
by Dan_Smullen
Cowbro wrote: ↑Mon Dec 05, 2022 12:42 pm
Phil
That's it. Classic 19 deserves a classic detail!
Stumbled upon the layout when I bought the hardware at a marine salvage yard. Didn't find enough pop up cleats to go all the way around, but found these 2 hawse pipes and bolt on cleats.
Thank you for the compliments. They are encouragement! Sorting through electrical for now...
Posted: Wed Dec 07, 2022 6:18 pm
by Cowbro
Dan_Smullen wrote: ↑Wed Dec 07, 2022 4:01 pm
Phil
CL did the exact same thing on "No Excuse", if you check the last couple posts in the rebuild thread you can see them in there.
Posted: Sun Dec 18, 2022 8:12 am
by Dan_Smullen
Donor boat. Acquired.
Bought from a friend of a friend. Motor is an ‘03 with ~400 hours. The trailer is functional, and they’re a few bits that I can salvage from the boat. The rest of the hull carcass will likely end up in pieces. Writing that out sounds wasteful, so if anyone is looking for 1978 21’ Manatee, HMU.
In the meantime, she can stay put for a few weeks while I complete the punch list on the C19.
Posted: Sun Dec 18, 2022 12:22 pm
by TomW1
Dan that 115 will push you along nicely. The first C19 built with a SS prop reached the low 40's for a top speed. 400hrs is hardly getting a motor broken in, especially a Yamaha.
Posted: Tue Jan 03, 2023 9:58 pm
by Dan_Smullen
TV works, and marking fish in the garage!
Posted: Wed Jan 04, 2023 7:51 am
by OrangeQuest
I just had to power my Garmin up and it is like looking at a TV with its full color. The manual is a paperback novel.
Boat is really looking awesome. Hope she splashes soon.
Posted: Wed Jan 04, 2023 9:59 am
by Jeff
Nice Dan!!! Jeff
Posted: Wed Jan 04, 2023 10:07 am
by VT_Jeff
You southern guys are beyond lucky! Marking fish in the garage in Jan? Crazy!
The critical path is getting less and less critical! Steering parts & starting batteries?
Posted: Wed Jan 04, 2023 10:26 am
by Jaysen
VT_Jeff wrote: ↑Wed Jan 04, 2023 10:07 am
With the tides this week… likely to see them in the parking space.
Not really, but the neighborhood pond will get its annual salt infusion and redfish influx.
Posted: Wed Jan 04, 2023 10:42 am
by VT_Jeff
Jaysen wrote: ↑Wed Jan 04, 2023 10:26 am
A "Red's" tide!
Posted: Wed Jan 04, 2023 5:26 pm
by Dan_Smullen
Getting there...
Need one battery cable for the starting battery, and yes, hoses and cylinder. Fuel lines...
Gauges, VHF, and cup holders on the way!
And a switch panel.
Posted: Wed Jan 11, 2023 9:38 pm
by Dan_Smullen
Last call before drilling!
Posted: Thu Jan 12, 2023 1:05 pm
by Jeff
Very nice Dan!! Jeff
Posted: Thu Jan 12, 2023 6:16 pm
by OrangeQuest
Really nice and love the use of the wood.
Home Depot just had hole saw kits on sale. I needed a 3" hole saw and for a few bucks more than they wanted for the one saw, I got a 7-piece kit with box and all. Only a few of the hole saws were also in the kit I already had but mine were very worn from use. Worked out well!
Posted: Fri Jan 13, 2023 7:47 am
by mhd
Looks sharp. Very professional finish. Nice job!
Posted: Fri Jan 13, 2023 9:42 am
by OrangeQuest
Oh, I always cut my holes in a scrap piece of wood before cutting my dash open. Because you have to account for the epoxy coats to seal the edges back up.
Posted: Fri Jan 13, 2023 4:56 pm
by Dan_Smullen
OrangeQuest wrote: ↑Thu Jan 12, 2023 6:16 pm
Is there a 3-3/8” hole saw in that kit?
That’s what I need for the tach.
Posted: Fri Jan 13, 2023 6:27 pm
by OrangeQuest
I was lucky and free style cut out the opening for my tach while it was still a flat piece of plywood. But no, the set I bought only went up to 3" which was the size I needed for the in-dash compass. But it also replaced some of my dull bits.
The price of a single hole saw is very steep but if it is the only size, you need it could be worth it. Looks like the other two holes are the same size? Home Depot does have a kit that has that size and more that is 49% off right now, if you like collecting sets.
https://www.homedepot.com/p/Milwaukee-H ... /322153636
Like I stated, I always like to cut a hole in a scrap piece of wood to make sure that the hole is the right size after 2 coats of epoxy sealing.
The rectangular opens can be done with a multi-tool.
Posted: Sat Jan 14, 2023 8:31 am
by pee wee
You may be able to use a router and template to make a nice round hole of the dimension you need. They make template guide rings for routers, and you can usually get different size rings, which in concert with different diameter router bits gives you some range of offsets from your template. To cut the hole in the template you can use a larger hole saw (best to put in a drill press, but you can do by hand) or use a circle cutting jig, or if you've got some wiggle room, cut it out with a jig saw like a barbarian!
Posted: Sun Jan 22, 2023 8:43 am
by Dan_Smullen
pee wee wrote: ↑Sat Jan 14, 2023 8:31 am if you've got some wiggle room, cut it out with a jig saw like a barbarian!
Barbarian style won the day. Sharp blade, left the line and then cleaned up with a rasp!
ACR and two batteries, with some cables built to length by a local shop, Waypoint Marine get power to the breaker panel and custom switch panel from New Wire Marine. Panel came with grounds and jumpers on the back to control the lamps which saved me some education, I’m sure. Nav lights working with a switch felt like a milestone.
In addition to cleaning up the wire routing, remaining ticket items are fuel lines, control cables and steering lines and cylinder at the splash well.
Posted: Sat Feb 11, 2023 8:31 pm
by blueflood
What a great build, Dan. Nice paint job and joinery. Very pro
Spraying the boat must have been fun. Looking forward to splashing !
Marc
Posted: Sat Feb 11, 2023 8:38 pm
by blueflood
Marc
Posted: Sat Feb 18, 2023 9:54 am
by Dan_Smullen
blueflood wrote: ↑Sat Feb 11, 2023 8:38 pm
Marc
Thank you, sir. To say I'm getting excited about a launch soon is an understatement!
The clarification from Bamaguy definitely got me pointed in the right direction on my journey unlocking the secrets of Yamaha wiring. Thank you for that BG!
It has been a slow burn figuring out the minutia involved with simple details like what size nuts do I need to hold the neutral safety switch in the Morse control. (#4-40 should anyone else be concerned.)
Still some ciphering to do jumping these wires to the tach, but it is certainly coming into focus.
Posted: Sat Feb 18, 2023 10:27 am
by OrangeQuest
Dan_Smullen wrote: ↑Sat Feb 18, 2023 9:54 am
I spent a considerable amount of time studying my Suzuki shop manual wiring schematics to figure out how to connect an aftermarket tach to my 25HP. But was able to find them. Even found the key on power for not only my tach but the voltmeter too. If I spent the money and bought factory gauges, it would have been a simple plug and play.
Awesome job on the boat and console.
Posted: Sat Mar 18, 2023 4:59 pm
by Dan_Smullen
Let’s call it a milestone. On the trailer without incident!
Posted: Sat Mar 18, 2023 5:40 pm
by cape man
That is a pretty boat!
Posted: Sat Mar 18, 2023 9:28 pm
by Fuzz
Pretty and dang those are big 19 foot boats!
Posted: Sun Mar 19, 2023 12:06 am
by TomW1
Dan, beautiful!
It was the first set of plans I ever bought. I think you plan on a 115HP motor I will be glad to prop your boat and motor for you.
Posted: Fri Mar 24, 2023 8:19 am
by Sideslippa1
Looks really great. Love the colour scheme too.
Top job mate.
Re. Slippa.
Posted: Mon Mar 27, 2023 10:25 am
by Jeff
Nice Dan!! Jeff
Posted: Thu Apr 06, 2023 3:27 pm
by Dan_Smullen
Thank you for the compliments, fellas! I appreciate them and y’all!
Been pecking away at loose ends after installing the motor a few weeks ago. As has been the case with the rest of the build, I have underestimated what it takes to rig controls and engine electrics, make final electrical connections and install and bleed hydraulic steering.
With much help, coaching and counseling from VT Jeff and BamaGuy, it feels good to have gauges that come to life when the key is turned on, and tilt and trim works on the switch panel.
Got a title and registration from the Commonwealth of VA. Still need to plumb the last fuel line, but looking for a splash this weekend!
Posted: Thu Apr 06, 2023 3:31 pm
by Jeff
Nice work Dan!!!! Jeff
Posted: Thu Apr 06, 2023 5:44 pm
by TomW1
Way to go Dan! You know most people have pet dogs or cats your the first with a pet children
Posted: Fri Apr 07, 2023 9:13 am
by VT_Jeff
Way to keep up the full court press, Dan, can't wait to get a ride! Boat looks incredible!
Posted: Sat Apr 22, 2023 4:02 pm
by Dan_Smullen
I have a lot more to add when I can put it into words, but the gist of it is, this boat exceeds expectations re: attitude in the water, and her ability jump up on plane and skip along at 32mph.
Posted: Sat Apr 22, 2023 9:54 pm
by narfi
Nice!!!
Congratulations!!!
Posted: Sun Apr 23, 2023 10:45 am
by VT_Jeff
Whoop whoop whoop!
Huge congrats from every angle!
Dan's boat looks and rides amazing(ly)! Due to work and weather i only got a few quick rides but it is smooth as silk at idle speed, jumps on plane in a heartbeat, planes like a dream. Super impressed to see all that hard work come together in such a great boat, it will be at tge center of countless adventures, I'm sure!
Posted: Sun Apr 23, 2023 11:10 am
by OlivierP
Fantastic, that will be a hell of a boat, enjoy !
Posted: Sun Apr 23, 2023 1:58 pm
by mhd
Enough to put a smile on anyone's face - great work. Congratulations!
Posted: Sun Apr 23, 2023 3:14 pm
by Fuzz
There is a little fear in the belly the first time out with your baby. But when she runs and runs right there is no feeling like it.
Posted: Sun Apr 23, 2023 4:12 pm
by Aripeka Angler
Beautiful boat sir! Fantastic work!!!
Posted: Sun Apr 23, 2023 5:30 pm
by TomW1
Wow Dan beautiful boat, she sure looks fine in the water. Have you been able to take the motor up to max rpm's yet or are you still in the break in period? The max rpm's for a new Yamaha 115 is 6300 so at top speed your rpm's should be between 6000 and 6300 with the boat loaded as you would normally operate and load it. Take care and enjoy your boat.
Posted: Mon Apr 24, 2023 10:54 am
by Jeff
Nice!! Congrats!!! Jeff
Posted: Tue Apr 25, 2023 2:14 pm
by Dan_Smullen
Thank you, Fellas! I officially feel like I am in an exclusive club, in great company. The support from friends and family in the home stretch was as inspiring to me as the excitement of the launch.
Having Jeff and Elaine to assist was amazing, and they were invaluable punching out the last few bugs that kept us from getting moving. Loose wires behind the switches, and bugs in the fuel tank selector valve slowed us down, but no match for some salty hands like Jeff and myself! My only regret is not getting Elaine on a Virginia redfish or two. Maybe next time.
Boat exceeds expectations with a quick jump to plane and comfortable cruise. At one point we had 6 adults on board and easily cruised on plane, ~3000 rpm at 20mph. Looking forward to the next window to get some better calcs on speeds. I know we topped out at 32mph, and I think we were at 48-4900 rpm. I spent very little time messing with trim trying to get more RPM, and I cannot tell you what the specs are on the prop, other than it is aluminum. With some high level stuff like being in the water and running well, optimizing is up next.
Insurance for "invested" value was easy. Basically insured for sum of receipts, plus a little. Policy includes towing and generous liability limits. With a legitimate appraisal I believe it could be insured for comparable market value.
A few pics snapped by Jeff and Elaine. The fresh launch stoke on a beautiful evening and my bro from another mo and our host for the weekend enjoying a beverage.
Posted: Tue Apr 25, 2023 2:39 pm
by Jeff
Congrats Dan!!! Jeff
Posted: Tue Apr 25, 2023 9:52 pm
by TomW1
Dan once you get that motor broken in and with the right prop you should be able to reach 40mph at max rpm's. The top actual anyone has reported with a 115HP is 42mph. Hoping for the best for you.
Posted: Mon May 01, 2023 10:25 pm
by VT_Jeff
Dan_Smullen wrote: ↑Tue Apr 25, 2023 2:14 pm
Very happy to be a part of the launch and to lend a very small hand! I came extremely close to letting the magic smoke out of your meter, close call!
Great crew you've got down there, lotta smart, helpful hands (JT, Cory, John, Lenny et al)! Big hello to all for us!
I'm sure you'll get that sweet boat dialed up to 42 in no time with a little futzing, and then happily cruise at 32 thereafter!
Best,
Jeff & Elaine
Posted: Wed May 03, 2023 9:54 pm
by TomW1
Dan posted a new PM last night. Ask if you have any questions. Tom
Posted: Thu May 11, 2023 6:28 am
by Browndog
Congratulations Dan! Great to see the boat in the water. Enjoy and best wishes.
Posted: Sun May 28, 2023 7:37 pm
by Dan_Smullen
Thank you, Browndog.
We spent some time rebuilding the low pressure fuel pump, and showed no improvement in the issue, which was loosing fuel pressure at the injection rail. So we pulled the VST to find a little bit of suspect crud around the screen at the HP pump. Cleaned out all of the mess and reinstalled, but ran out of time to launch and test.
Fast forward two weeks, we launched late Friday evening in a stiff NE breeze and saw 5500 rpm’s screaming into the wind and chop, which we hadn’t before. The boat skipped over the chop comfortably at 33 mph.
I felt like the skeg, strakes and chines really made the boat feel “sticky”, and I mean that as a positive. It didn’t feel like it wanted to get squirrelly in the chop and wind. The boat feels like a heavy boat underway, but at the dock, it reacts quickly while people move from one side to the other, which to me, feels like a symptom of a light boat. The skeg seems to be most noticeable while docking and current and wind are opposed. The skeg is directly affected by the current, which minimizes the effect of any wind. It was only the other night, while blowing 20 or so, was the wind more effectual on the boat than the ebbing current.
The freeboard is amazing. Inwales that hit above your knee make you feel safe in open water. Ample room on either side of the console for 3 people to stand abreast.
While throttling up, there is a fair amount of harmonics that are felt throughout the boat, but these dissipate as the boat gets on plane. I surmise that this comes from the hull being under tension as the panels were bent into shape. Like the face of a stringed instrument, they resonate at the right frequencies. Maybe…
Downsides…I think the motor cut out in the transom wound up too high. After adding glass on top and at the keel, I have 21”. The motor mounts juuust low enough for the fin to align with the keel, but banking sharply in a turn, the prop seems to get a little dry, and momentum and power in the turn suffer. Also, I have a suspicion that she is too light, or maybe too bulbous, in the bow. In the water the stern sags a bit, but levels out nicely on plane. You tell me what you think. The underway pic is a from a few weeks ago while trouble shooting the fuel starvation. Way back when, while planking, the hull bottom panel lifted away from the jig, right about where the skeg turns up to the stem, and there has always been a bit of bump there. Effort at the time getting them to stay tight to the jig may have made a difference.
After our highest rpm sea trial, we changed spark plugs, and injector filters, but again ran out of time for another trial, so expecting the motor to perform even better.
While underway, I spilled a little Modelo in the cockpit, so I’m going to call that the christening, and I christen her “Simply Stubborn”.
WX is looking much better next weekend. I can’t wait to get her out again!
Posted: Mon May 29, 2023 2:45 am
by OlivierP
Congratulations for the christening, and she looks fantastic on the water, I wish my C17 looks half as good !
Posted: Mon May 29, 2023 8:54 am
by fallguy1000
Congrats on the launch.
Check the oil a few times after messing with the fuel pump before or after being out. You want to make sure there is no fuel leaking down which would overfill the crankcase and cause vibrations.
I think they make anti-vibration plates for these motors, too, if it is just a simple vibration.
Boat looks great.
Posted: Mon Jun 19, 2023 9:50 am
by Dan_Smullen
First fish in the boat! Stoked to hit this milestone on the first trip with wife, kids and dog on board. Great Father's Day for sure. Maybe best to date.
Posted: Mon Jun 19, 2023 11:55 am
by Cowbro
Dan_Smullen wrote: ↑Mon Jun 19, 2023 9:50 am
You should be incredibly proud of that boat and your accomplishment. She is a beauty! Nice fish too!
Phil
Posted: Mon Jun 19, 2023 12:47 pm
by Jeff
Congrats!! She looks great!!! Jeff
Posted: Mon Jun 19, 2023 1:27 pm
by TomW1
Great looking boat Dan! What is your top rpm's now in some calmer water? Nice first fish.
Posted: Mon Jun 19, 2023 4:24 pm
by OlivierP
Congrats, it's now officially a fishing boat ! I wish you many more.
Posted: Mon Jun 19, 2023 6:16 pm
by Dan_Smullen
Thank you fellas!
TomW1 wrote: ↑Mon Jun 19, 2023 1:27 pm
Maxing out at 37 point something at 57-5900 rpm. Cruising comfortably at 25mph @ ~4000 rpm.
Current prop, I think, is 13.25 diameter, 15p, aluminum.
Posted: Sat Jul 15, 2023 1:36 pm
by TomW1
Dan_Smullen wrote: ↑Mon Jun 19, 2023 6:16 pm
Thank you fellas!
Dan forgot to reply to this if you are reaching 5900 rpms you are fine and no need to do anything with the prop.
