I have put stringers on frame 'C' but i've seen that on planes they are not used.
Are they necessary? Is there any good reason to mantain them on?
What should I do, use them or put them off?
AR15 FRAME C QUESTION
It's correct the way you did it and that's the way we show it on the plans but there are so many lines on the construction drawing that it is not easy to see.
The method is always the same, wherever we can't reach with a fillet and tape, we use a cleat.
Also called a nailer, even if there are no nails.
Your hull looks good.
Note how is workshop is set up: the computer is next to the boat, he doesn't have to walk far to ask a question on the message board.
Re: What Ply Thick
I just use 6mm ply, because in my plans (not updated) it was specified 6mm, this measure is correct.CO6AKA wrote:http://bateau2.com/content/view/96/27/
it this picture ply should be 8mm
In my plans it should be 6mm?
What is correct thickness? in the plans or in this picture??
Does it change a lot??
