Filler Question
Posted: Mon Oct 28, 2019 11:18 am
by Reklus
I'm gonna need to drill some holes in transom maybe deck.... I am out of woodflour... Can I just use chopped glass to thicken it up a bit?
Re: Filler Question
Posted: Mon Oct 28, 2019 2:22 pm
by fallguy1000
Reklus wrote: ↑Mon Oct 28, 2019 11:18 am
Chopped glass is very lumpy and chunky and hard to work with without cabosil or flour.
Re: Filler Question
Posted: Mon Oct 28, 2019 3:07 pm
by Reklus
I still have the fairing stuff... I just need some way of thickening the stuff up a bit so I can apply it on a vertical surface.
Re: Filler Question
Posted: Mon Oct 28, 2019 3:30 pm
by cape man
I have a 3" hole in the bottom of my boat that is filled with "chopped" glass and epoxy for a shoot through hull transducer. I pulled apart the strands from some woven cloth and cut the glass fibers into tiny (less than 1/4") pieces and mixed with epoxy until I got the consistency I wanted. It certainly isn't as easy as wood flour to get the right consistency, but it will work. I also used the fairing mix sold here to fill gaps where my chase tubes came through the sole. I would not recommend the fairing mix for anything structural, like a filet or gluing pieces of wood together.
Re: Filler Question
Posted: Mon Oct 28, 2019 10:06 pm
by Netpackrat
I used milled glass fiber in a handful of places on my D5, and for sure you will want to combine it with cabosil/silica to smooth it out and prevent sagging. I would personally not use fairing mix; you would be partially defeating the whole point of using milled fibers by mixing it with a non-structural filler. Try to avoid using the milled fiber/cabosil mix anywhere you might need to sand. I used it in a few key places such as in the fillets around the daggerboard case, in the mast step area, fillets under the breasthooks (which also got a layer of bias cut glass), and anywhere that was drilled and filled for a fastener.
Re: Filler Question
Posted: Tue Oct 29, 2019 7:28 pm
by Dan_Smullen
You could go after a board with belt sander and a dust bag to create some wood flour.
