SOBX Little Big Boat GV15
Re: SOBX Little Big Boat GV15
If there's a way to include painting the sides of the cockpit before the side decks go on it will make that step easier; obviously you can't paint where you're planning to tape. After the side decks go on it's an awkward job. The boat is looking good, you're making fine progress. Thanks for posting and including pictures!
- BrianC
Today was rainy so no epoxy but I did get all the holes drilled for the bungees hold downs:
Next up, swim platform installation. Details here: viewtopic.php?f=7&t=66072
Thanks, I’ve added this to the plan.Dan_Smullen wrote: ↑Mon Apr 11, 2022 5:35 pm There is also an opportunity to fillet and tab the top of the inwale to the bottom of the deck, which will add considerable strength.
Good idea, As you suggest, I’ll leave the upper part unpainted so there isn’t an issue with tapping the deck-to-hull seam.
Careful with those deep cutouts into frames. There must be enough material next to the hull side or you make a hinge point to concentrate stress. I'd seriously reinforce some of those cutouts if running through chop is ever going to be a thing this boat does.
Basically in terms of maths a reduction of 20% in thickness loses 51% of stiffness. It's a cubic relationship for the mathematically inclined.
Moreover since your frames are triangular in shape and there's a cutout in the thinnest part, essentially all of the side force will concentrate here. Worse case you will get cracking. This has happened before.
viewtopic.php?t=63093
You could consult the designer for advice, but as a guideline I'd leave at least 3" onto the hull everywhere. If you go below this then double up the thickness for each 20% cutout.
Users browsing this forum: Knottybuoyz and 4 guests
