I found some 4.5" adhesive-backed rolls which worked pretty well -- they were about $15-20 for a 30' roll. I believe the brand was Porter-Cable. What really helped extend the paper life was using compressed air to clean the surface every few minutes. Of course that only works if you are outside in a reasonable breeze (pretty common here in coastal NC) and are standing upwind!fallguy1000 wrote: ↑Mon Jan 04, 2021 1:15 pm The longboard is nice, but the abranet mesh wears out too fast per $. I like using festool papers; it takes 10-11 sheets at 50 cents each. But they last longer than the mesh.
SOBX Little Big Boat GV15
- BrianC
Re: SOBX Little Big Boat GV15
Nice use of the beveling and of the objective case!
- BrianC
I've finished adding the "top hat" style cleats to bump up the sole by 0.75" or so. If I ever used them again I'll pay a lot more attention when putting in the stringers and frames. The GV15's stringers and frames are just a single layer of 3/8" ply so don't go in perfectly straight unless you take care (which I didn't). Just a bit of wobbly (1/8-1/4") means the slot in the top hat cleat needs to be opened up. I had cut the slot on a router table and then cut them to length before I discovered the wobble issue. I spent about a week opening up the slots with a chisel.
Now onto finishing the chase tubes and cutting the floor panels. I picked up a sheet of 3mm ply along with the 12" Meranti ply for the sole. I've been using the 3mm sheet to make a pattern for the final cut. Here is the first sole panel pattern and cut Meranti sheet:
When you're ready to think about that new, bigger boat build, contact me & I can put you in contact with someone who cuts one heck of a jig for an awesome Carolina 25 hull. It won't be stitch & glue, but rather a cold molded boat. You'll have all the skill you need by then. And they are local to you & me here in NC. I won't post any links or mention the designer here out of respect for Bateau.
- BrianC
What is the best way to seal around chase tubes coming up through the sole?
- BrianC
All foamed and sole is in place. Rain is forecasted for tomorrow so I rolled on a quick coat of epoxy to seal it all up.
Up next, fillets and tape to firmly attach sole to hull and then a layer of 6oz. cloth. Sure is nice to be able to walk around inside without stumbling over stringers and frames!
Looking good Brian!
I think most seal the tubes coming up with either thickened epoxy or some type of flexible caulk.
Eric (aka, piperdown)
- BrianC
Yeah, I found this post from Jacques that lays it all out:
Are there alternatives to 5200 that aren't so gooey and sticky? I'm hesitant to use something not rated for the marine environment.jacquesmm wrote: ↑Wed Jul 01, 2020 10:36 am ...Epoxy does not bond to PVC pipes. At those points, your pipes must extend above the sole by a few inches and they must be sealed where they go through the sole. You can seal with 5200 or you can build a fiberglass sleeve all around to the top of the pipe. Think of the PVC pipe as a lost mold. To just glass a small lip around the pipe is not sufficient. Even with the methods above, if water gets over the top of the pipe, it will flood the pipe and go somewhere....
- BrianC
Today I added fillets then placed 12 oz. biax tape after the epoxy started to set.
Next up, 6 oz. woven over the exposed plywood sole.
- BrianC
It has been awhile since my last update. Boatbuilding was on hold for a few months but is now going again. The sole is covered in 6 oz. woven & the motor well bulkhead and casting deck frame installed:
The cut-outs in the motor well frame to the left and right of the motor well are for a pair of passenger seats and double as steps to the transom / side decks.
Next up are the above sole frames with cut-outs and the bow locker. I'll be posting a separate couple of threads on those to get suggestions / guidance from the forum.
Users browsing this forum: No registered users and 23 guests
