Day 61
Let's drill some holes.
Started by drilling two 1.5" holes along the bulkheads for the chase tubes:
This created a ton of plugs:
Once they were all cut out, I quickly sanded the PVC pipe with 80-grit sandpaper, ran them along the gunnels, and glued them in place with wood flour filets:
Then on both sides of the bulkheads I laminated 4oz cloth:
In a couple hours, all four chase tubes were laminated in place:
Since I was cutting holes, I also cut out the 3" holes necessary to route the heater vent tubes:
I know some of you, especially in the southern US states, laugh at the idea of adding heat to a boat, but in the Pacific Northwest, even in the middle of summer, we will have days (especially mornings) under 60oF. The heater is one of the features I'm most excited about on this build, and will help make this boat truly available for use year-round:
Mattkab's GV13
Re: Mattkab's GV13
We put AC in larger boats down here. So if your idea makes us laugh, you can laugh right back.
Re: Mattkab's GV13
Wow, never thought about a heater!!!! Pretty cool!!!! Jeff
Re: Mattkab's GV13
What are you using for a heater?
- mattkab
Re: Mattkab's GV13
I'm using a 2kw diesel "parking heater" like this.
I love these things... I have a 5kw on our 47'er and it keeps the salon and pilothouse toasty year round. I also have one to heat the garage while working on this boat -- it fights the drafts and never gets quite as warm, but definitely improves the temps. I consistently get the garage up to almost 70F, with outside temps in the 40s.
Re: Mattkab's GV13
I would have guessed those heaters are junk based on price alone. They are about 10% of most marine heaters. It is good to know you have had good luck and like them. Price makes it cheap enough to go ahead and try one.
- mattkab
Re: Mattkab's GV13
They are knock-offs, to be sure. By design they separate the heating element (burn chamber) and the cabin air, so unless there's an actual structural failure, they are very safe. And at that price, it's cheap insurance to just have one wrapped in plastic as a spare.
But the one on my 4788 is running strong after 4 years' use, no issues (and I have a couple CO monitors around the boat, all read 0ppm). The one in my garage is only a year old, but I've run it many times.
Edit: In case anyone else wants to do this, on boat or interior use, throw out the exhaust "muffler" -- it has a hole in it that can release exhaust gases and is designed to be used outside oly! The exhaust pipe also gets VERY hot, so make sure it's far away from anything flammable -- I also wrap them in heat shield tubing made for vehicle exhaust headers. I use stainless ports for both intake and exhaust as well.
Re: Mattkab's GV13
Please post more info as you mount that heater. I think that would be a great fit for my little HMD19. It would certainly make soaking bait in the winter more tolerable and it might help get the wife onboard more often.
- mattkab
Re: Mattkab's GV13
I will, I'm a big proponent of these little heaters.
Re: Mattkab's GV13
I went to your link and first thing I see is "will not ship to Alaska" I am really tired of this crap.
