Hi Everyone,
I figured it was time to share some photos of my boat build. Thanks to all who have answered my questions and helped me get this far!
https://photos.google.com/share/AF1QipN ... FoUzVtLVp3
Mike Schwind's SK14 Build
Re: Mike Schwind's SK14 Build
Nice! I like mine plenty and put a Minn Kota riptide with spotlock on the nose and a propane Tohatsu 5hp on the stern. I didn't build a seat into it and wish I had. What do you plan on power?
My plan is an 8hp Tohatsu. Hopefully that's not too much power for this little boat.
https://www.tohatsu.com/marine/int/outboards/MFS8B.html
No I think that'll be great. My 5 hp just runs me at 12mph or so. You'll do better. I carry a double paddle too and can maneuver and poke along with that as well.
I don't think 8HP is going to be too much power!!! Jeff
I have a question for you guys. After I added the foam, the port side of my boat warped and now I don't have that nice smooth curve. You can see it well in the second to last photo in my album. Do you think I will be able to straighten that out with some gunwales?
Well that's a bummer. I would clamp the rub rail on first to see if that takes care of it. I suspect it will. If not I might cut out a wedge of foam to relieve the pressure. First would be to clamp on the rail though.
- BB Sig
I had to cut wedges into the foam as Dougster said to do. You are supposed to add the rubrail prior to foaming. The note in the FS13 stated it was optional so I waited. The note for the FS13 was supposed to be altered. Not sure what the SK14 stated to do. Make sure you wait until the rubrails are on before filling in the foam wedges that were removed!
After cutting wedges and gluing rubrails, it straightened up a lot but will require a lot of fairing. Mine will be a 20' beauty!
Did you cut your wedges at the point where the frames meet the side panels, on either side of the frame? After looking at the boat yesterday, I am having a hard time figuring out where the wedges need to be cut in order to relieve the pressure.BB Sig wrote: ↑Mon Jun 01, 2020 1:11 pm I had to cut wedges into the foam as Dougster said to do. You are supposed to add the rubrail prior to foaming. The note in the FS13 stated it was optional so I waited. The note for the FS13 was supposed to be altered. Not sure what the SK14 stated to do. Make sure you wait until the rubrails are on before filling in the foam wedges that were removed!
Dougster,
What type of wood did you use for your rub rail? I was thinking about using Cypress. What are your thoughts on that?
