Best method without a strongback?
Posted: Sun Jul 19, 2020 9:11 am
by Stinkyface
Likely to start an SK14 build in the next few weeks- looking for advice... that boat is not built on a strongback and I have seen in the forums they have been built on everything from the floor, to sawhorses to a table. I will be trying to get set up in the meantime and was thinking a table About 4x12 and about three feet high. Any pros and cons of each? Is it worth me wasting time and money on a table for the build?
Re: Best method without a strongback?
Posted: Sun Jul 19, 2020 10:08 am
by BB Sig
I built a 4x12 table for my FS13. It was too wide once I started on the inside. 2(or 3)x8 would work. I'm using saw horses now.
Posted: Sun Jul 19, 2020 1:14 pm
by Stinkyface
The SK 14 is 11.5 inches wider than the 13 according to the specs (49.5 in max beam vs. 38in). You think 3ft wise will be enough?
Posted: Sun Jul 19, 2020 3:12 pm
by BB Sig
It should work better than a full 4'. Let's see if Dougster replies. He built the SK14.
Here's his build:
https://forums.bateau2.com/viewtopic.ph ... hilit=SK14
There is a lot of good stuff in it. I bet his table is closer to 30" wide. That's just a guess from looking at the pictures in the first post of the thread.
Posted: Sun Jul 19, 2020 4:38 pm
by BrianC
I built the hull right side up like is described in the plans; I used the leftover pieces from a couple of the frames to act as a basket mold:
My full build thread is here:
SOBX Solo Flats Skiff SK14
Posted: Mon Jul 20, 2020 8:58 am
by Michael.Schwind
I just threw a sheet of 3/4" plywood on a couple of sawhorses and it worked great. I added some extensions to it while drawing out and cutting my panels, but took them down once the hull was stitched together. Here is a link to my build.
https://photos.google.com/share/AF1QipN ... FoUzVtLVp3
Posted: Mon Jul 20, 2020 9:27 am
by Dougster
Yes, 'Sig got it just right: 30" wide table on castors 36" high. I already had it so used it and it sure was convenient.
Posted: Mon Jul 20, 2020 10:31 am
by Stinkyface
BrianC that is a great idea. I took a look at Dougsters build, I’ll checkout the other one later today. I like the idea of wheels, keep the garage a little cleaner during some of the work...Thank you for the help!
