CS23
Re: CS23
the glass has 1708 grams per m2?
Re: CS23
1708 is ounces
600/225 is the measurement, but 400/225 is okay as well
If you only have 400g, two layers is best
Re: CS23
Glass wrap, min 1 layer 400/225 or 600/225 or two layers 400 or 4 layers 200
Stagger, one long piece first about say 10" wide and the other one 6" wide, or just one piece with mat done real well, not air holes..
Re: CS23
I agree with fallguy you want to strengthen the bracket. I would put 4 layers on the bottom, 2 layers on all of the insides, 3 layers on the out sides, 2 layers on each side of the top. You want to prevent any flexing of any surfaces. When you decide how high your motor bracket mount has to be cover it with glass also. Remember most brackets are made of aluminum and you want yours just as strong.
Well good luck.
Well good luck.
Re: CS23
hello thanks for the answers! i have been thinking about it what is better if I cut away 10cm then I have 53cm to the keel and the bracket is 43cm then I can use a shorter motor is that better?
Re: CS23
I am not certain that I understand the choice but a longer shaft motor is better, safer.
Re: CS23
Longer motor keeps engine higher up and less likely to drown in broaching waves/surf.
Keep what you have.
Keep what you have.
Re: CS23
ok thanks then i will have a long engine and will not shorten my bracket by 10cm because i don't know where the waterline is i hope under the (BL) Sole
Re: CS23
Good plan, but you do need to go over the top with glass or the ply will open on the endgrains and get water soaked..
Re: CS23
yes, I know that but I'll only do that later when I laminate the bathing platform then I do everything on top of each other then I don't need to sand down as much
Users browsing this forum: Yandex [Bot] and 3 guests
