Changes to BBC domains: bateau.com links
Re: Changes to BBC domains: bateau.com links
Do you mean that the last post you made in the forum pre-populated the submit form?
Maybe it's an unrelated problem, but at least for me the SK17 links to build threads & pictures still don't work. The links for other designs do work, at least all the other ones I tried.Jaysen wrote: ↑Thu Nov 05, 2020 12:11 pm Dang it! I knew there was a config defect that was missed. It is the same problems that gstanfield found with images. But I did not follow my post it and check the old forum config (missing trailing / on the domain redirect). I've put the fix in place. Give it about 30min and try again (should only be 5, but it appears to take longer to cascade if you aren't cheating like me).
Clear browser cache?
It seems that the 404 is being cached by some browsers (seems chrome is particularly bad for me). The page is setting no cache header so it shouldn’t be getting cached. But it is.
I had replied to some other threads before I got to the Cracker thread. When I went to reply there my last reply from that thread kept popping up. No big deal but I am sure it tells you something.
I just went back there and it all worked correctly so maybe it is fixed.
Two things: first, I tried clearing the cache but no go, but when I went to use Firefox instead of Opera it did work, so maybe it's a browser issue.
Secondly, I hit "reply", not "quote" when I went to write this, and I got the quoted messages above. Actually, only your reply is in quotes, my response which should be in quotes is not. Overall things are working great, though!
The quote issue is a know phpBB problem. That is due to “quoting quotes” creates a href loop. Not sure when a fix might be provided.
The Firefox vs Opera difference is likely due to a cache somewhere. It might be on the server in the session cache files. I’ll dump them 3ish. I see other reports of this for some boards that upgraded but not all. Not sure of it is a plug-in or a theme issue. Hopefully dumping server side caches will get it.
Fuzz, all the above is likely hitting you too. According to the Mrs it breaks down to “blah blah blah internet blah blah blah stupid”. Not sure that helps you but that’s her take.
