In other news...
Because I'm bolting on a PT35 Tilt n Trim bracket, I designed a mounting plate for the transom bolts in the motor well. All the cool boats have them!
Btw the same font I'm going to also use to make some vinyl decals to go on the side.
My uncle has a 3 axis CNC in his garage and will be machining it for me. He finished the path planning and sent me a photo of it. Should be making a wooden trial piece this weekend before trying to cut the aluminum.
Cameron's FS14LS+5%
Re: Cameron's FS14LS+5%
Cameron just double the piece with a piece of 3/4" you are over thinking this. Tom
Progress is slow, but coming along. Just detailing the aft locker area. Getting wiring/plumbing situated.
Laying out hoses for the baitwell tank.
Made a mount for my Power Pole Anchor pump.
Working the wiring for the pump. It's a polairty switching motor so you need a 2 relay setup that flips power and ground. Power Pole has one for about 130 bucks...or 2 relays for 10 bucks a piece and some wiring and you have the same thing.
The PT35 Tilt N Trim bracket does the same thing, so I'm using it for guidance as well.
My uncle ran my transom bracket on a piece of wood this weekend. I think it looks good! Now for an aluminum one.
And how I left it tonight. Got some extra colors of wiring coming in this week to make my pump wiring a little more clear. Should be in soon. I'll wrap that up, tie everything up, and then figure out where to put lighting.
That is flipping SLICK!
Nice work!!! Jeff
If there's still time to weigh in, I like the vertical post idea if it's not going to be too much of a storage nuisance and the floor under that spot is supported. Otherwise, I think I like the transom-to-frame support since both ends will be fully supported and the connection is simpler than the diagonal.bamaguy0 wrote: ↑Tue Oct 05, 2021 10:44 pmThat is what I was hanging my hat on, but with the way the gutter pieces are simply butt bonded together, any flexing will result in cracks over time. I have to limit the amount the deck flexes, that much is true. Adding support helps that. Better to add a little more now than wish I had later.Mojosmantra wrote: ↑Tue Oct 05, 2021 10:41 pm And it could very well be that the plywood alone can handle that span and I'm making something out of nothing...
I just keep thinking "man that is a lot of stuff packed in a 14 foot boat"
That is going to be one nice boat
I want an uncle like that!
