Good luck to you too. Eventhough you dont need it.fallguy1000 wrote: ↑Fri Mar 05, 2021 11:13 amWell, you asked me. I gave my opinion.duysall83 wrote: ↑Fri Mar 05, 2021 10:16 am I'm close to İstanbul. Not crazy humidity here, at least compare to how i feel in Jakarta i learned not to complain about humidity after been there many times.
Dan i dont plan to glass above chine. Actually i worry if any structural problem occur if i dont renew the neat epoxy before primer.
Both Matt Gent and Cowbro are having issues with unsheathed ply. It is basically a week's work for insurance against paint issues later.
Any epoxy coating is NOT considered structural. If you sanded through glass below waterlines; those must be repaired with glass and epoxy.
Good luck. The boat looks like it is coming along nicely.
Fairing is a pain.
What is your name?
HMD 21 starting - help
Re: HMD 21 starting - help
after a long period of inactivity, i guess ready for flip tomorrow. Hope no incidents
Good luck with the flip. You'll be amazed with the size of the boat after the turnover. Mine sure seemed bigger when I was looking at the inside of the hull.
Good luck flipping.
Done for today. One friend and 4 manuel lifter plus many planning . Still airborne. Will feed old tires under tomorrow.
No problem until now Managed to flip with milimeters to the upper profile.
Congrats on the flip!!!! Jeff
Good work. Always a bit nerve wracking..now the work begins again.
Hello again,
I started laying tapes and next laying to the fabric inside of the hull.
Should the fabric cover also top of butt blocks? Or are those areas negligible?
If butt blocks are allowed, then they should be made in such fashion that allows for laminating over them I'd say. This is a Gatehouse design, iirc, so it would be best to ask him. If your butt blocks are not too thick, you would be able to fillet a triangle to get to them, but I encourage you to hear from the designer first.
Butt blocks are not usually used on boats the size of the HMD. Instead 6" biaxial tape is used on all the seams. It is as strong and allows for smoother lay out of the 12oz biax cloth.
