I agree this would be much better. However, if the designer suggested it, then we don't cross that path.
HMD 21 starting - help
Re: HMD 21 starting - help
Mine has butt blocks on the two bottom panels. Not on the sides. The edges are tappered to allow the biax to lay nicely over the blocks.
- Evan_Gatehouse
Yes, fabric over the butt blocks. Butt blocks should have rounded edges so that the fabric lies easily over it.
SK17,MM21/MT24
SK17,MM21/MT24
Ok, thanks everyone. Had to try my chanceEvan_Gatehouse wrote: ↑Thu May 13, 2021 12:13 pm Yes, fabric over the butt blocks. Butt blocks should have rounded edges so that the fabric lies easily over it.
Hello all, can i put the water tank like this? Doesn't fit paralel to water length due to a wrong purchase
Yup. Don't forget to vent it! Center it is best. Boats are all weight sensitive.
Yes, build a platform so it doe's not set on only the end points. That looks like a pretty nice tank.
There will be 2 of them. Second one for waste water. I plan to put them next to each other with a seperation. And there will be pumps close to the tanks.
For the bottom support here what i plan according to what i read on forum. Please advice, thank you.
Duysal
Never have a board rest directly on the V. Do a support on either side of it. Or run a support underneath it glued to the hull sides.
Everything else sounds great.
Thank you Tom and Dan.
