One 40 would allow you to run at displacement speed, 7-10 mph at a cruising speed. A little higher at full throttle say up to 12 mph, but you won't get on plane. Again this will depend on how your boat is loaded.Johnston wrote: ↑Wed Dec 30, 2020 2:25 pm Thank you everyone for your amazingly informative responses.
The build time of the Panga seems very fast in the study plans - is it significantly faster than some of the other boats and is this because only 2 stringers?
Working 9-5 could 2 people complete a basic Panga 25 in a month?
This is good news Tom. Does your calculator say what speed it would do with a single 40? Or one trimmed up?TomW1 wrote: ↑Wed Dec 30, 2020 12:29 am First I would not scale the PG25 it needs to have every dimension scaled due to its shape. Okay after running twin 40's or 80 HP through my calculator you would have a top speed of high 20's, low 30's. Cruise will depend on the prop you get, the load you have, etc, it should be about 1/2 throttle or a little less. Once you get on the water you will know, every boat is different.
Good luck
