Winches be like:
Desirable?
Jaysen's Helms 24
Re: Jaysen's Helms 24
Winches be like:
Desirable?
Desirable?
Those are some sweet #6 there! What did they come off of?
Late 70's Leisure 22. Great little micro cruiser from england. Many/most are bilge-keelers, mine was a fin-keel with a bulb. Had in-mast main furling off a Rhodes 22. Trailerable, but not a trailer-sailor.
Btw, this is the 68 century cheetah I never stop talking about, I had it for about 10 years, sold it a few years ago for lack of use.
Bilge keelers are getting my attention of late. I have lots of places to sit a boat on an outgoing tide but find make me nervous. Bilgers win for that move.
Today was a semi bust. Put rebuilt rebuilt carb back on motor and no gas was squirting out the side. Motor ran 8min through adjustment and warmup. After 22min of simulated motoring (motor in gear so under load) the cough and die scenario returned.
Looks like I’m going to be finding a Mercury service center.
Well that sucks! I hate any form of power I can not count on.
Have you done anything in this area yet? Does the fuel cap vent work?
22 minutes under load is more than enough time for the motor to reach normal operating temps. Water stream warm or to warm? Any of the electrical stuff on the motor getting warmer than they should?
I removed the fuel cap on restart attempts. No help.
I have not completed the new fuel system install. Since I have to save $$ for the wrench time I’ll be completing that next.
Stream is good and warm. It is thermostat motor so I know when the motor is warmed up. I don’t feel that the water was hotter at the end than the beginning.
Electronics all seem to be functioning. Nothing smoking it hotter than other parts. It is a two cylinder motor so I can compare ignition components.
Start with the basics: fuel, spark and air. Don't know what you have done to verify these 3 things so, can you answer these tests?
Quick tests will narrow down where to look. As soon as it stops working, pull the plugs and see if they are dry or wet? 20+ minutes of run time under load they should be dry. If they are wet then is it fuel or water? While the plugs are out measure spark output at the coil wires. Simple spark tester made from old plug and alligator clip will work. If the spark seems good at both coil wires then pull choke and notice the sound change when cranking and more gas smell from cyl. Make sure plug wires are not anywhere near. If the choke is a butterfly valve style, and there is a sound change, that tells you the motor is getting air when the choke is open. No increase in fuel smell out of spark plug holes tells you it is the fuel system that is causing the problem.
I had a mid 80s 40hp Johnson that would do the same thing. Run like a top for 20-30 minutes and then run on one cylinder for a couple of minutes and then die. Damn thing left me drifting way too many times. After about ten trips to the dealer I gave up and bought a different brand outboard. I am sure it was electrical but the dealer could never fix the problem.
Today was “cut plywood” day. The plan was to cut washboards and frames. They are cut, but it ain’t pretty.
Laying out the center and edge lines.
Pattern fully laid out. Time to cut.
All cut. The big mistakes I made were cutting the frame tops too narrow and not being able to cut the beveled edge straight.
Tomorrow will be sanding, epoxy sealing/gluing and lil bit bottoms work.
And for those that wonder what other dumb things I do… painted bunting. Been trying to get him to sit still for a few months. Finally got him. Much better looking in person. Unlike me. Or Fuzz.
