It uses a flapper valve and I would guess you would follow a solid with a liquid to complete the flush. When I was looking at them in home depot they were the easiest to blow through but could not blow soft enough to get air past them, I bought 2.
Jaysen's Helms 24
Re: Jaysen's Helms 24
That's "the void". Back wall is transom. thing in the middle is the old muffler, and the foreground is the sail drive mount. When I started the day it looked like
By the end of the day
We had to cut out the metal bracket that was going to hold the gas tank. We removed all the "it will never be used" remnants that were removable (the muffler and the sail drive mount are integrated into the hull). All the old blower ducting, scrap parts, a lot of dirt, and random detritus collected over the years... gone. I'm going to head down and scrub it here this afternoon and will get a new mounting plan for the tank figured out. I'm hoping to push the tank further back.
The saildrive was what I did not understand, never been around one before. Kind of strange they would glass the muffler into the hull but I have seen some strange things done by the factories.
I feel like I must be missing something. All thru-hulls beneath the waterline should have ball valves. All hoses should be double-clamped with 100% stainless clamps. All should have soft wooden plugs on a lanyard next to the thru-hull. The white stuff around that pipe (what is that, galvanized??) gives me the creeps. "Plastic" thru-hulls aren't plastic, they're Marelon, which is fine and won't corrode. Why would you want a check valve? Not sure what the toilet is but most have them internally. That's no place for a check valve. Close it manually when not in use.
I'm sure I must be missing something but that setup looks very, very dodgy.
Tony
No plumbed head on my boat. The head stores was about racing the J30 and the head being a shite show due to wave action/back flow.
On Lil Bit More, the only below water thru hull is the sink drains. That bronze unit is all messed up from lack of care from PO. I will address it proper when she’s out for bottom job. When I do replace it I’ll make all kinds of bad decisions around rerouting the plumbing and material choices. One thing I really want to do is move that entire thing out of “the line of impact” relative to things stowed in the void. Not sure where it will go as the convenient locations are difficult to access for emergency shutoff.
Do you have any bonding system at all?
Use a different term than bonding.
Not being dense. Just want to answer the question correctly.
Also, I’m 100% sure the boat is not right.
OK, got it.
Fall guy is not wrong, but there is a downside to having the sink drain above the waterline, which is that the sink will probably only drain when at a berth or anchor. At least, it won't drain when you are heeled and the sink is on the low side. Maybe this isn't something that would bother you. But if you do place the thru-hull beneath the waterline, see above about proper installation.
Tony
Are all the things that are metal and below the waterline attached to a/the grounding system?
Obviously one is not.
Is the outboard a battery start or pull? Is the anode going to be connected to the bonding system?
