That might be your expected usage, but it's fairly common for these boats to outlive their owners. As well as you've built yours it's not impossible that a grandchild of yours will out offshore on it one day.FluidDynamic wrote: ↑Tue Jan 19, 2021 10:34 pm All great suggestions. This boat will never be anywhere i couldn't either swim to shore or just stand up in shallow water. I think I may keep the radio and simrad fused as is without a switch. I will add a circuit breaker between the on/off switch and the rocker switch panel. Add the fuses close to the batteries for the ACR for the + and close to ACR for the -.
PG 20 Wiring Critique
Re: PG 20 Wiring Critique
TrueOneWayTraffic wrote: ↑Wed Jan 20, 2021 1:41 amThat might be your expected usage, but it's fairly common for these boats to outlive their owners. As well as you've built yours it's not impossible that a grandchild of yours will out offshore on it one day.FluidDynamic wrote: ↑Tue Jan 19, 2021 10:34 pm All great suggestions. This boat will never be anywhere i couldn't either swim to shore or just stand up in shallow water. I think I may keep the radio and simrad fused as is without a switch. I will add a circuit breaker between the on/off switch and the rocker switch panel. Add the fuses close to the batteries for the ACR for the + and close to ACR for the -.
Forgive me for dumbing it down for a minute, on the schematic, what is the unit to the right of the battery switch?
Just a Bus bar to split the power. Im wondering if I can connect all the wires to the switch instead.
I think i'm going to put two more circuit breakers in. One going to switch panel and one in front of radio and mfd. That way I have the ability to trip the switches if needed.
I thought you said it was a push button fuse.FluidDynamic wrote: ↑Thu Jan 21, 2021 10:51 pm Just a Bus bar to split the power. Im wondering if I can connect all the wires to the switch instead.
I meant these circles were the push button fuses on the switch panel
Pretty sure you send the power right to breaker panel.
The power will go directly to the switch panel. However, it will be protected by a breaker before the panel as shown in image.
