17´bow rider options
Re: 17´bow rider options
Did you consider the GV17 ? Seems to have the highest capacity amongst 17 footers, and reasonably high sheer. Exists in bow rider version.
Me too, I have a dog that I take everywhere with me, and I'm also not a big fan of people. I'm a teacher, so I have to deal with people on a daily basis, so maybe I wouldn't have 5 people with me when I go out boating...
I was thinking maybe 5" wide gunnels, really minimalistic consoles and so forth. The white OB17 with a red stripe, also built in Finland, looks good. The consoles are too big for my taste, but otherwise it seems to be a good starting point.
No, not really. The looks of her don't float my boat, if you know what I mean... Otherwise it would be a really smart choice.
I'm starting to think that the C17 would be the best option, allthough the engine would be limited to 50HP. I'll have to try and figure out the weight difference between the two, because at the moment it does not make sense to me, when looking at the BOM.
I'd go straight to the C17, if I were doing the same thing as you.
The first one built as a centre console, or at least I think the best known, is a beauty by a user Rmarsh. I would use pictures of his build as a starting point. It could be a terrific bowrider and I'd say 4 people easy and six on occasion...no problem in my mind.
I'm putting a 60hp on mine. According to the designer a "60hp or 75hp is fine, a 90hp is borderline and 115hp excessive."
Salty asked during his build. IF putting larger than say 75hp on you would need to double bottom and stringer glass, and also where it tabs to the transom. Moreover there's no need as the 60hp will push it as fast as you'd want it to go. If you really want more go for a C19 with 90hp as a standard engine.
You can build the C17 as standard without the cockpit roof, just the framing and use a canvas top to close it. That's an option that you could consider.
The C17 should weigh more than the OB17. I wouldn't focus overly much on hull weight. In some boats it includes fitting and rigging, in others a basic open version only. There are assumptions built in, including what options you will pick. Mine will be heavier than the published 300kg I'm sure. Focus on getting a good wetout so as not to waste epoxy, and also buying lighter plywood are the easiest ways to lose weight. Both boats have a similar DWL displacement and that is what matters. I have the plans for both, so if you want to make any comparisions I can do it for you.
Thank you, I'll let you know if there is something that needs comparing.OneWayTraffic wrote: ↑Sat Feb 06, 2021 7:51 pmI'm putting a 60hp on mine. According to the designer a "60hp or 75hp is fine, a 90hp is borderline and 115hp excessive."
I'm looking at alternative plywoods, but there aren't that many to choose from here. I know I shouldn't stress too much about the hull weight, but I'm an automotive engineer so I do tend to overcomplicate things in my mind.
I've looked at Salty's and Rmarsh's builds, they are both built kind of close to what I had in mind.
Hello Samikoo....I built a C17 .....center console version...and put a 60 HP on it. Higher cockpit depth is one of my favorite features of this design. My fishing grounds are out in a choppy bay here in the northeast....passing through a turbulent river inlet to get out there and back. Its nice to have the feeling of being "in" a boat rather than just on one. I can tell my passengers feel safer too. I've had four adults aboard....more than that would not be very good. The one negative trait of the higher sides is more windage when docking or drift fishing.....but I can deal with that.
I've looked at your boat several times, it sure is nice. Especially the build quality is great. Did you ever weigh her?Rmarsh wrote: ↑Tue Feb 09, 2021 6:27 am
No......never got a chance to weigh the hull. With the 60 HP 240 lb. outboard mounted on the transom, the hull floats level and very close to the designed waterline.
The boat gets up on plane very easily and quickly. Also the C17 design has a motorwell bulkhead, it keeps the water that gets past the transom from entering the cockpit .
Users browsing this forum: Ahrefs [Bot] and 2 guests
