1964 Lone Star Triton
JohnC
Post by JohnC »
I haven't been on in awhile. This followed me home a few days ago. Lone Star Triton, needs some transom repair (PO already started) and general refurbishing. I will add a couple pictures as soon as I figure out how to do that.
JohnC
Re: 1964 Lone Star Triton
Post by JohnC »
JohnC
Post by JohnC »
VT_Jeff
Post by VT_Jeff »
Fun Stuff John!
I had a similar era Texas Maid Skijet 14 with a 58 evinrude 35 on it, ton of fun.
JohnC
Post by JohnC »
Life gets in the way sometimes, trying to get back to the Triton. Pictures of the transom and repairs needed. PO started.I have all the aluminum trim pieces for the transom. It already has some sealer (not sure what) on the wood. I am thinking epoxy coat, then drill the holes and epoxy for the screws that mount the aluminum trim pieces and paint for UV protection. This part will be covered by the trim. And then fiberglass repairs to the splashwell and top deck where it was cut to allow for transom replacement. Any thoughts on epoxy and fiberglass? FYI it will be getting n Evinrude 40 two-stroke motor.
fallguy1000
Post by fallguy1000 »
Typically, holes in wood are drilled, then overbore 2-3x, then filled with epoxy putty, then sanded if needed, then painted over, then redrilled and screwed with sealant.
Lotsa work, but this is the professional way.
viewtopic.php?f=12&t=62495
JohnC
Post by JohnC »
Fallguy1000 that's what I was referring to on drilling/filling epoxy holes. I have seen it on other posts here. Just making sure I have the right idea.
JohnC
Post by JohnC »
I didn't realize it had been so long since I have been online. Life got in the way AGAIN! 2023 was cataract surgery and then a broken hip (not at the same time at least)🙃.
Not much work on the Triton but getting back to it.
I did get a 1975 Evinrude 40 to put on it when that time comes.
Looks like the format is different, I haven't figured out how to add a picture yet.
More later,
JohnC
