I have two old vhf antennas, both are the perfect size for the Skoota.
Both 8' long or so.
One is clearly older and thicker than the other, and its cabling is all shot. Does thicker just mean stronger or is there a reception gain?
Anyone ever restore these?
I can afford a new one, but they are like $200 and I have two!
VHF antenna restore
Re: VHF antenna restore
Can you measure them in anyway?
In my CB radio days you had to mount the antenna where it would be at and then measure the effectiveness of the whole system with a SWR meter.
Looks like one, if not both, of the for sure is a Shakespeare, contact Shakespeare and check with them. Local boat club would have a few HAM operators members, I bet, and they could also tell you about them. HAM Operator would even know how to test them and have the test equipment to do so.
Oh, thickness doesn't matter, it's the length that gets the signal out better.
Fallguy I don't know if I would use either of those. As you say the wire on the right one is cracked and broken and would cost a lot to replace at todays wire prices. The one on the left looks to have a cracked ferrule and I would not trust it. A new antenna is only $79 - 179 and will last you as long as that beautiful boat. Some even allow a splitter for AM/FM radio . https://www.westmarine.com/vhf-antennas There are of course other vendors.
Regards, Tom
Regards, Tom
This is off Shakespeare's website, you may need a longer ant anyway.
https://shakespeare-ce.com/marine/antenna-selector/
The place I got the best price on my VHF/GPS/chartplotter and stereo was here. They also had all the odds and ends like flush mounts for each unit
https://www.thegpsstore.com/
Even after you get everything mounted. I would find someone that can test how well your radio works. Doesn't take much to have really good operation verses something that doesn't reach to far.
I am like 20 feet above the water with an 8' antenna. Anything longer doesn't close down onto the cabin, so for now, until I move to Texas, not gonna go bigger.
A 16' antenna is going to be 28' above the water.
The db gain is less an issue on a catamaran.
