Gv11 with 20 hp
- New Poster
Gv11 with 20 hp
What modifications would I need to do, if any to run a 20 horse on the gv11? I'm thinking I will glass the hull inside and out, pour foam in the floor and glass over the sole. As well as extra wood and glass on the transom.
Re: Gv11 with 20 hp
You also might consider a Foley catheter and collection bag so you don't wet your pants when you open up the throttle!
There's a picture of one built like a run about with a 40 Honda on it....
Re: Gv11 with 20 hp
Yep'er sir he will be into the 30's with that small boat.
- Evan_Gatehouse
Re: Gv11 with 20 hp
It's really not recommended unless you build it with a console. Having the weight more centered helps keep it stable in a turn.
Layer of biaxial on hull bottom, both sides.
I ran a GV10 with a 15 HP and that was a handful when just one person.
SK17,MM21/MT24
SK17,MM21/MT24
- New Poster
Re: Gv11 with 20 hp
Evan_Gatehouse wrote: ↑Fri Aug 20, 2021 7:44 pm It's really not recommended unless you build it with a console. Having the weight more centered helps keep it stable in a turn.
With that in mind, I could use water ballast in the bow to balance it out when riding solo and a 15 horse tiller. I'll also have a trolling motor and it's battery in the bow
- New Poster
Re: Gv11 with 20 hp
OneWayTraffic wrote: ↑Fri Aug 20, 2021 10:08 pm Or you could just not run it at 30mph. Easy on the throttle.
Where's the fun in that!? I think the 15 I'm also thinking trim tabs on the stern and skegs on the bottom. I've also seen a few people here add a foot to the overall length for better power handling. That Might be worth the cost of an extra sheet.
