Lost my mind
Re: Lost my mind
Well I got all the leaves out of the hull but where the engine was is a greasy mess. I think the oil got changed by dumping it in the bilge and leaving it there. Any body got a favourite degreaser? something that will cut heavy crap. Dawn and Simple Green is not cutting it.
Re: Lost my mind
I’ve used TSP or powered laundry detergent with small amount of water on occasion.
Re: Lost my mind
I've had good luck with the industrial Zep degreaser.Fuzz wrote: ↑Mon Oct 25, 2021 1:26 am Well I got all the leaves out of the hull but where the engine was is a greasy mess. I think the oil got changed by dumping it in the bilge and leaving it there. Any body got a favorite degreaser? something that will cut heavy crap. Dawn and Simple Green is not cutting it.
Not sure if any of the people you know up there have a Hotsy you could borrow but they are the absolute best to cut heavy grease. Every diesel shop I've worked at or worked around used Hotsy's to power clean.
Eric (aka, piperdown)
Re: Lost my mind
Yeah. You need steam cleaning power.
Re: Lost my mind
We use oil eater. (I think Costco has 5gallon buckets)
For really stubborn stuff I will siphon spray the area down with diesel and let it sit a couple of minutes, then siphon spray it all down with oil eater, let it sit a few more minutes but not long enough to evaporate, then hose it down with the hottest water I can get. I have also used the siphon injection hose on pressure washers with the oil eater and hot water as well, but some stuff just needs a little soak time to loosen up first and diesel won't evaporate, so it gives it that soak time needed.
All of that makes the air pretty nasty though, need a mask and/or lots of fresh air and anyone around hates you for a bit.
If its cold out, and it can't stay in to dry out overnight, final rinse is gas instead of water to prevent anything from freezing up.
Re: Lost my mind
Thanks guys. I will look around and see if I can come up with some form of a Hotsy. I have the boat inside now and do not want to use any real nasty stuff that needs to be aired out.
Re: Lost my mind
I would try to stick with water soluble degreasers if you can. They are mostly bio-friendly so can be rinsed down the normal drain. If that isn't working may consider oven cleaner or a petroleum-based paint remover but you would be getting into the more toxic stuff, then.
Re: Lost my mind
It sounds like a big job, and the steam cleaning sounds sensible. I've used citrus degreasers when working on smaller stuff and it works well and smells nice, not sure how practical/cost effective it would be for your job.
Re: Lost my mind
This may seem extreme, but what about fire!
I've seen folks use heat guns to loosen the grease then scrape it up. That makes it easier for less caustic chemical options. I saw one idiot use a propane asphalt torch. That ended as expected, but I would encourage Fuzz to try it (but only if there is a video camera monitoring the event).
Re: Lost my mind
For now I will skip the methods involving fire but I am sure I will think of it many times during this project
Thanks to piperdown I found some Zep and gave it a try. It did a pretty good job for a first pass. One more shot and I think I will be able to work in the area without looking like a total grease monkey.
