Cleaning laminating rollers
Posted: Sun Sep 12, 2021 4:52 pm
by jbo_c
I’ve done a fair amount of fiberglassing, but never used a laminating roller. So I bought one with my last order from BBC.
But now I’m scared to use it.
How do I make sure it doesn’t get loaded up with cured epoxy? If I’m going to be spending a couple of hours glassing, how often do I clean it? Every time I reach the “kick” time for a batch of epoxy? How do I clean it and reuse it quickly while making sure residue from the cleaning isn’t still there to contaminate my new batch of epoxy?
I’m sure I’m overthinking. I definitely have that capacity.
Jbo
Re: Cleaning laminating rollers
Posted: Sun Sep 12, 2021 5:21 pm
by OneWayTraffic
If you put it in a cool place, and use it with fresh epoxy, it shouldn't be an issue. Otherwise dipping it in a bucket of acetone in between uses works well too.
Even if a little gums up on it, a heat gun, propane torch and a wire brush works well to get old cured epoxy off. Do outside for the fumes.
Posted: Sun Sep 12, 2021 10:31 pm
by fallguy1000
I keep 2" of acetone in a Home Depot bucket with a lid; soak the laminating tools that are solvent proof in it. If you get a little resin cured on it; use a dental pick to clean each row. I prefer a bubble buster.
Posted: Mon Sep 13, 2021 8:00 pm
by Evan_Gatehouse
I only use a yellow plastic squeegee to wet out fabric or tape. For flat areas just pour a large amount and use the squeegee to spread it out. Pour out a little more for wet spots.
For tapes, I use a laminating bench. Cover it with plastic dropcloth material. Wet out the tape there, roll up and then apply to the hull. Helps save your back
Posted: Tue Sep 14, 2021 10:48 am
by jbo_c
Definitely planning on the laminating bench for the tape. It saves backs and resin.
Jbo
Posted: Tue Sep 14, 2021 10:50 am
by jbo_c
Evan,
Are you saying you don’t use laminating rollers? Or just adding ideas for spreading?
Thanks.
Jbo
Posted: Tue Sep 14, 2021 11:30 am
by piperdown
I use a squeegee to spread the epoxy around or a tight knit dense foam roller. I also use my gloved hand to move it around and smooth it out. After that I use the laminating roller (assume you're talking about the fin roller for getting air pockets out) to work out any air bubbles there might be. I clean mine with white vinegar most of the time or use acetone.
