Cavitation plates, waterlines and baselines.
Posted: Thu Oct 14, 2021 9:28 am
by fallguy1000
There has been some confusion here lately about waterlines and engine settings.
I believe the issue is that the waterline does not drive the cav plate location.
Is there a tutorial or sticky on engine heights here anywhere?
Re: Cavitation plates, waterlines and baselines.
Posted: Thu Oct 14, 2021 10:50 am
by OrangeQuest
On the old website, I think is where they were, was a lot of tutorials on building and transom height in relationship to the motor and the length of the shaft.
Waterline is not the same as the bottom of the boat and waterline is not used to set the depth of the motor. A waterline is usually used to judge how deep the boat is setting in the water. The bottom of the hull is used to set the Cav plate to start with and then the motor is moved up or down to maximize performance at all speeds. Adjustable jack plates makes the adjustment easier.
Posted: Thu Oct 14, 2021 11:11 am
by Jaysen
fallguy1000 wrote: ↑Thu Oct 14, 2021 9:28 am
OrangeQuest wrote: ↑Thu Oct 14, 2021 10:50 am
https://boatbuildercentral.com/support- ... ansoms.pdf
Posted: Thu Oct 14, 2021 11:14 am
by Jeff
All, All of the information on the old site can be found in our Tutorial Section: Link:
https://www.boatbuildercentral.com/tutorials/ Jeff
Posted: Sun Oct 24, 2021 2:55 pm
by TomW1
Jaysen posted the correct web site on transom heitghs and engine lengthss
