I faired the bottom of my boats with quickfair in places. Sure, Oyster reefs hit hard will score it, but Graphite/epoxy mix over unfaired glass is not at all impervious to scoring either. I tend to just not look underneath the boat much
Graphite bottom application
Re: Graphite bottom application
I put it directly on a glassed and sanded bottom and then faired it with graphite mixed with epoxy to a thicker consistency in some low spots that showed up. Put over 4 layers on before I was satisfied. WEAR a mask when sanding!
- BarraMan
I faired the bottom then applied 3 coats of epoxy followed by 3 coats of epoxy/graphite, lightly sanding between each graphite coat.
All good stuff, seems that there isn't just one way to do it and it depends on a) what you want the finish to look like and b) how much you're willing to go through.
I'm definitely going to fair the sides and just put graphite/epoxy over that, but the bottom I'll have to wait until I'm done sanding and make the judgement call there on if I'll fair first.
Thanks everyone!
Thanks everyone!
Now THAT's a bottom!
I wanted to update what I did so someone else would know
I sanded the bare fiberglass and, while relatively smooth, it wasn't what I wanted to have as my surface before graphite/epoxy so I put a layer of quikfair down, sanded it smooth and then put 4 coats of graphite/epoxy over it. I could have done 2 thin layers of quikfair and then the graphite/epoxy and it probably would have looked real smooth but my outcome is good for what it is (the bottom of a small skiff).
I did have another question though. Has anyone done the entire bottom with graphite/epoxy? And by entire bottom I mean all the way up to the rub rail. I was thinking on my next boat of doing that and just using the UV resistant epoxy with the graphite for the last layer or 2 so that it doesn't fade/chalk over from the sun light. Any thoughts on this?
If it is above the waterline and exposed to the sun it is going to get VERY hot! While you might be able to protect it from UV I would worry about it getting softened by the sun and the heat.
This is a good point. The fact it'll be hot isn't much of an issue for touching since it's the outside of the boat but I didn't think about it softening or messing with the rigidity/quality of the epoxy/boat. I'll look into this and maybe some others can chime in. I searched and couldn't find where it had been done before.
Dark colors (paint or graphite) in a southern climate will heat up and can allow the pattern of the fiberglass to telegraph through. Don't know how much of an issue that would be for you.
Epoxy and black do not mix well in high heat areas or direct sunlight. Keep the epoxy/graphite mix to the waterline or a couple inches above it. Then use a lighter colored paint above that. The darkest I have seen in FL is a bright red, there may have been a smaller 14' in dark blue. The biggest thing to remember is heat weakens epoxy.
