super hi tech diagram. nothing under the sole, everything under the gunwhales
FS18 on Cape Cod!
Re: FS18 on Cape Cod!
Just remember to over support the wiring. The gauges you have to use is heavy and when your pounding it add a bunch of snap weight. Back in my younger days I tried supporting 4 awg wiring for a trolling motors from the back to the front (22'). I was breaking zip ties and heavy duty ss straps where the screws were pulling out of the wood and breaking 3/8 pop rivits in the aluminum . Conduit would be the best option just support it every foot.
See my LM 18 build here.
viewtopic.php?t=64254
See my LM 18 Questions here.
Finished Boat Here
viewtopic.php?f=25&t=65173
Finished Boat Here
Good start but I do not see any return black negative wiring or green ground wiring. Also, what about the fuel fill. Also, on the fuel tank you have sounder on it I think you meant sender. Well as time goes on you can fill in your diagram for the other things. Will enjoy watching the rest of your build.
thanks Tom! I left out some stuff for sure!TomW1 wrote: ↑Sat Feb 12, 2022 9:13 pm Good start but I do not see any return black negative wiring or green ground wiring. Also, what about the fuel fill. Also, on the fuel tank you have sounder on it I think you meant sender. Well as time goes on you can fill in your diagram for the other things. Will enjoy watching the rest of your build.
I filled in some more. The thicker lines are conduit, i was planning on protecting the wires as much as i can!
So from the bow, the little house battery will run down to the side console neg bus bar and fuse box. led deck lights,led nav lights, and the fuel sender will run down the same conduit to the console. I dont have even a remotely large electrical load on that battery. bilge draws like 1.7 amps when on, i forgot what my 7watt fish finder takes but it aint much. i gets like a 2 amp fuse I think they recommended so it aint much! the led lights wont be much draw either.. so I dont think I need a huge cable between my little house battery and the neg bus bar/ fuse box in the side console.
the conduit coming from the transom to the console will have the bile wiring, anchor light, and engine wiring harness (which is pretty thick, it splits into a couple plugs that fit my side throttle key thing etc. im assuming the other wires are for the digital gauge and fuel sender etc).
the throttle and shifter cables I was gonna run in one conduit together, the steering cable its own conduit, and the transducer cable its own conduit going back to the transom.
The ground I left out because its one of the many questions i have! So the fuel fill and tank share a ground and that runs down to? the neg bus bar and then the engine? just the engine? whats else gets a ground in my setup and where does it goes?
fuse on the starter battery? no fuse cause it would be a huge ass fuse and take forever to change god forbid something goes wrong and I need to start asap?
There will be a ground screw on the motor that the green wire will go to. There should also be a ground post on the negative panel to ground all electricals on the boat. You can ground the fuel tank to this.
Redfish in cape cod?
someone had to field test the boat in its natural habitat had to test out and make sure the platform works
i was gonna stop by BBC but i was on the other side of the state and only had a week down there with the boat! def not enough time!
