Make the replacement pieces first. Then cut it out. It is much easier to ensure fit with that 2” shelf to help you out.Fuzz wrote: ↑Sun Dec 12, 2021 12:37 amThat being said I would break out the multi tool and then the grinder and get rid of that mess. You can always hot glue some cleats to the hull for supporting the new plywood till you glass it in.Randy Michaelis wrote: ↑Sat Dec 11, 2021 11:17 pm Let me try that again. I am not confident in the remaining plywood. Seems pretty weak.
Thanks
Randy
V-Berth Repair O’Day 20 (1974)
Re: V-Berth Repair O’Day 20 (1974)
My approach:
I would leave what's left, use it as cleats for the new panels, add the new panels and glass them in from above. I' d make a rough template from cardboard and use a deck of cards taped along the edges of the template to get the shape about exactly right. I'd add a stiffener under the new panel athwartships but wouldn't bother tabbing frames into the hull. It made it this long without them. Not sure if you can get a full width piece into the berth so there may be an installation puzzle, solvable.
I suspect the only thing under the vinyl is exposed, rough glass. I'd rip it out and replace it with the same thing, sans mold.
