Great point! At the beginning of my build I had no inclination whatsoever about advantages/disadvantages of short shaft or long, and this became predetermined by the first cut. Some built in flexibility would be good for all builders.VT_Jeff wrote: ↑Sun Dec 05, 2021 7:36 pm.
If I were BBC-master for a day, I'd do this: The plans would indicate that transoms should not be final-cut until the intended motor has been correctly measured, since it's pretty clear that a 20" motor is not 20" universally. Also, if possible, kits would not be cut until the buyer provides an accurate and correct transom measurement. This will avoid the need for people to build-up transoms, add extenders, or just live with a motor teetering on the top of the transom.
Fillets vs. Cleats
Re: Fillets vs. Cleats
All motors have a built in adjustiibility allowing you to lower it at least 2" up to 4" depending on the manufacturer. Tom
Just make sure that the surface is dry before gluing eh? I used that trick to check after flame treating UHMW polyethylene. Supposed to be impossible to bond, but my UHMW rubrails will rock the boat on its cradle if you yank on them.jonnymac wrote: ↑Sun Dec 05, 2021 8:00 pm what i thought was interesting about the report is you can actually test to see if the surface is correcy roughed up or has some other issue. water drop on the surface should be flat, not beaded up. I’m going to do some water tests once I get back to boat building after the holidays.
One advantage of the manual tilt models I'm familiar with is you can always unlock the tilt.
Thanks OneWay, I was overlooking that completely.OneWayTraffic wrote: ↑Mon Dec 06, 2021 3:32 amOne advantage of the manual tilt models I'm familiar with is you can always unlock the tilt.
Can make reverse interesting!!!!One advantage of the manual tilt models I'm familiar with is you can always unlock the tilt.
Our little 5HP has a system that only locks it in reverse gear but turns of more than 90 degs while in reverse unlocks anti-tilt. Forward or neutral, there is no locking tilt.
Some outboards have a system of sorts, that when the motor kicks up quickly while in forward gear, the motor is not allowed to slam back down very fast.
But, again, we are off subject!
Very much off subject. Unless somebody wants to fillet and cleat their outboard. That will protect it from navigational mistakes.
Users browsing this forum: Ahrefs [Bot] and 11 guests
