I am doing the electrical diagrams with Visio 2. Been paying for it $16/month for a year, finally got access today.
Anyhow, I am making diagrams today since my back is really bothering me.
I will add a picture here in a bit, but plan to laminate the diagrams into a binder to keep onboard. Maybe another for in the office.
Visio 2 electrical
Re: Visio 2 electrical
I'll see if I can find a better way to upload them. I am only using text boxes and dynamic connectors for it all. Maybe a fuse here n there.
I would consider actually labeling the wires with numbers or letters at each box, a wire color could change or some weird scenario where you end up changing the color of a wire in a pinch cuz its the only one you had and it got damaged. This is a great start on what I’m sure is a complicated wiring system.
For those working on the cheap, consider draw.io. Same capability just a bit free-er.
I second the use of numbers. Colors are helpful but time, great/dirt, light and colorblindness make mistakes a bit more likely. Using both together Would be ideal.
My labeling system is crap.
I can't imagine redoing it all, but perhaps. I'd need to go with a largerish heat sheink tube because the ends are all applied.
Does visio come with wiring templates or are you making all that up?
Just using text boxes and dynamic connectors. Quicker, jist not pretty.
Users browsing this forum: Google [Bot] and 7 guests
