The chines are a bit of a gamble sometimes.Cbuf wrote: ↑Tue Jan 18, 2022 10:43 am My lm18 runs 34mph with a 50 you will probably run around the same with a 40 because your planning lighter than I built. I'm not sure what the answers is for the skeg with a tunnel, but when you have a small boat running 30+ it is a lots faster than you think. Also, when I turn at speed, I couldn't imagine not having a skeg especially when it is bumpy because the back 6-8' of the boat is basically a flat bottom boat. Maybe two strakes, to not interfere with the tunnel. The chine might work, but it would have to be a pronounced.
I would make two beaching strakes. Determine where the boat hits the beach and they will double as bottom protection and prevent side slip.
Probably in the neighborhood of 1.5" wide and 1/2-3/4" thick in the y plane.
