Scaling cnc plans
Posted: Thu Dec 23, 2021 4:51 pm
by fallguy1000
Hey Reid....is it possible to scale plans for the CNC? So, for example, if you wanted to build the PH22, but make it 10% wider and 10% longer, could you do the cnc work still, or is it a can of worms?
Of course, note here, I did not want to go deeper, so this is scaling in two dimensions, not three...
Also, do the cnc kits include jigs or stations? Can they?
Re: Scaling cnc plans
Posted: Tue Dec 28, 2021 1:15 pm
by Matt Gent
Any of the un-wrapped / developed surfaces won’t scale…particularly the hull bottom and topsides near the bow. You’d have to start with a new 3D model around the scaled frames.
Posted: Tue Dec 28, 2021 1:34 pm
by Reid
fallguy1000 wrote: ↑Thu Dec 23, 2021 4:51 pm
Fallguy,
Sorry I missed this question. Short answer is no.
Long answer:
If you have an understanding of how we make our CNC files this will probably answer your question. We start with the designer's CAD file in 3D. From there, Crystal "unrolls" the three dimensional drawing of the boat into two dimensional pieces. All of the parts of the boat (hull, frames, stringers, etc.) are then nested to on the appropriate plywood thickness. Once all the pieces have been extrapolated and nested we can then create a tool path or cut file in a program that works with our CNC machine.
So in order to scale a CNC file we would need the designer to first create a new "scaled" version of the boat in question. This is vital to ensure accuracy of the cut files.
Hope this answers your question.
Happy New Year!
-Reid
Posted: Tue Dec 28, 2021 9:37 pm
by fallguy1000
Thanks and darn at once.
