Page 1 of 4
LM18 Tunnel Build - NC
Posted: Sat Jan 08, 2022 12:30 pm
by Ryan
I figured I’d move my stuff over to the build thread now…. Setting this jig up has been a pain in the a**! I still have some adjustments to make to get everything flush and square. Here’s some progress pics not in order sorry!
~Ryan
Re: LM18 Tunnel Build - NC
Posted: Mon Jan 10, 2022 8:54 pm
by Ryan
A little more progress! The tunnel wasn’t too bad to build… question for you vets! what are your thoughts about countersinking a brass fitting with a ball valve, hose, etc, to have the ability to vent or non-vent the tunnel. I wasn’t sure if water running across the surface of a fitting (even if recessed) would disrupt the water flow enough to negate suction?
I stole the 1/4 round idea from one of the gents on here.
~Ryan
Posted: Wed Jan 12, 2022 9:33 pm
by Ryan
First duh! Moment… cut one of the frames too long! No big deal though. I’ll cut it to size tomorrow.
Posted: Sat Jan 15, 2022 6:46 pm
by Ryan
Just about ready to spot weld!
Posted: Sun Jan 16, 2022 12:04 pm
by VT_Jeff
Looks good Ryan. Are you not using spacers intentionally?
Posted: Sun Jan 16, 2022 1:49 pm
by Ryan
Yes, just dry fitting the panels. I went back and spaced everything out this morning. Everything fit surprisingly well! I though something might be wrong… lol
Posted: Wed Jan 19, 2022 5:34 pm
by Ryan
Anyone see anything crazy? I’m getting ready to tape it tonight.. the hull looks fair (for the most part).
Posted: Wed Jan 19, 2022 6:11 pm
by VT_Jeff
Looks great from where I'm sitting! Is the bottom flat near the stern to your satisfaction?
Posted: Wed Jan 19, 2022 6:30 pm
by fallguy1000
Maybe jumping the gun, but you need radiuses on the chines and transom for glassing.
Might be what Jeff was getting at..not sure.
After you make the radiuses; the transom gets resharpened.
No radius will fail.
Posted: Wed Jan 19, 2022 6:41 pm
by Ryan
Good catch guys! I went back and re-read my plans. For some reason I was thinking the tape stoped at the stern. The plans call for tape on transom and keel.
