Builders, et al:
I need a couple of 1/4" aluminum plates cut, drawing attached below. If someone can do this or knows someone who could, I'd be much obliged. Big thanks to Daniel S. Mullen for the quick sketch, saved me about 8 hours of pointing, clicking and swearing.
Simple Aluminum fabrication
Re: Simple Aluminum fabrication
I can't really help you out, and I don't know how tight your tolerance requirements are, but if it was me, I would:
1. Order 7"x7" piece of AL from onlinemetals.com.
2. Cut 1.25" diameter hole in the middle with a holesaw
3. Cut the plate in half.
4. Round corners with a file.
Phil
Phil
Diameter of the hole needs to be 2.5"..
That may well be what I end up doing. I don't have a good way to cut 7" of 1/4" aluminum, though I have several bad ways(Hacksaw/grinder). Real issue is that I'm out of time. We're leaving Friday for a long road trip and the thought of making them on a campground picnic table isn't super attractive. But if the cost is exorbitant, I may end up that route anyway.Cowbro wrote: ↑Mon Feb 28, 2022 12:17 am I can't really help you out, and I don't know how tight your tolerance requirements are, but if it was me, I would:
Phil
Find a small, local machine shop with a plasma, CNC cutter or an apprentice. Should be something they can cut simply (likely using the method Cowbro suggested) and quickly. Big question is if they will have work lined up.VT_Jeff wrote: ↑Mon Feb 28, 2022 8:29 amThat may well be what I end up doing. I don't have a good way to cut 7" of 1/4" aluminum, though I have several bad ways(Hacksaw/grinder). Real issue is that I'm out of time. We're leaving Friday for a long road trip and the thought of making them on a campground picnic table isn't super attractive. But if the cost is exorbitant, I may end up that route anyway.Cowbro wrote: ↑Mon Feb 28, 2022 12:17 am I can't really help you out, and I don't know how tight your tolerance requirements are, but if it was me, I would:
Phil
That said, I may have a guy here who can bid on it, but not sure how I would get it to you before friday.
Just spoke to a local shop who may be able to do it, we'll see. I don't need them by Friday, can just get them shipped to my campground de jour or (de week).......I can install them at a picnic table.Jaysen wrote: ↑Mon Feb 28, 2022 9:23 amFind a small, local machine shop with a plasma, CNC cutter or an apprentice. Should be something they can cut simply (likely using the method Cowbro suggested) and quickly. Big question is if they will have work lined up.VT_Jeff wrote: ↑Mon Feb 28, 2022 8:29 amThat may well be what I end up doing. I don't have a good way to cut 7" of 1/4" aluminum, though I have several bad ways(Hacksaw/grinder). Real issue is that I'm out of time. We're leaving Friday for a long road trip and the thought of making them on a campground picnic table isn't super attractive. But if the cost is exorbitant, I may end up that route anyway.Cowbro wrote: ↑Mon Feb 28, 2022 12:17 am I can't really help you out, and I don't know how tight your tolerance requirements are, but if it was me, I would:
Phil
Bid has been submitted and accepted, will be ready Wed Aft. Local shop in North Adams Ma. Stoked!
Excellent!!
The result:
I'm now thinking I probably should have made the plates longer. Hindsight's a beeotch.
Users browsing this forum: Yandex [Bot] and 2 guests
