Page 1 of 2
BBC fiberglass hatch lm18
Posted: Fri May 06, 2022 8:42 am
by Edd
I decided to scrap my hatches and go with the custom fiberglass hatches on BBC
Im going with the 22”x22” on the front deck, 22”x16” on the rear. I close up the deck and glassed. Then used the router to remove about 1/8” where the flange rests. I’ll epoxy it in place then glass the seams.
Has anyone used these any suggestions?
Re: BBC fiberglass hatch lm18
Posted: Fri May 06, 2022 7:41 pm
by fallguy1000
You gonna install drains?
Posted: Fri May 06, 2022 10:00 pm
by Edd
fallguy1000 wrote: ↑Fri May 06, 2022 7:41 pm
Yeah, I’ll probably do it with pvc like some other builders have done
Posted: Sat May 07, 2022 6:13 am
by Browndog
Those hatches will really kick your build up a notch.
More work I know, but the gains in having a flush deck and drier storage with better cosmetics is real.
You won’t be sorry. It will be worth it.
Posted: Sat May 07, 2022 10:23 pm
by Matt Gent
I'd venture it is quite a bit less work than making guttered hatches yourself. I had more time in making the hatch and surround for the skiff than rebuilding the casting deck and floor together.
A straight-edge could help as a guide for the router in cleaning up those relief cuts.
Posted: Sun May 08, 2022 5:48 pm
by Edd
Browndog wrote: ↑Sat May 07, 2022 6:13 am
Yeah I agree
Posted: Sun May 08, 2022 5:50 pm
by Edd
Matt Gent wrote: ↑Sat May 07, 2022 10:23 pm
Definitely less work
Posted: Sun May 22, 2022 9:26 am
by Edd
Epoxied the hatch in place. I temporarily screwed it down with drywall screws, which spread the epoxy out really good and contact all around.
Posted: Wed May 25, 2022 9:48 am
by Edd
I’ll glass these seems and it should be good.
Posted: Wed May 25, 2022 11:58 am
by Edd
