Well, life got in the way a bit and I had not had a chance to work on the boat for a bit. Finally got back at it yesterday. I thought things were going well and I have hit a snag. I wanted to make sure everything fit nicely before I started spot welding, and everything did not fit nicely. There is a lot of space between Panel A and the hull...
Here is a couple of closeups of the stringer with Panel A removed. There is a good 2 to 3 inch gap between the stringer and the hull near the bow...
Looking from the stern forward, there seems to be a lot of space between the hull and Panel B and Panel C, too...
I am hoping this is a common problem with a relatively easy fix. Any suggestions? I loosened and tightened things over and over and could not get that gap between the stringers and the hull near the bow closed. Thanks!
NC SK14
- New Poster
Re: NC SK14
Those cords across the top side panels constrict things. I'd take 'em off and start fooling with it. The side and bottom panels need to be able to float and find a fair curve. Panel A and maybe the port stringer look shifted to port, not centered. Start with removing the cords and see what happens. Post pics again after that. Other folks will chime in too, it just takes a bit to get things to fit right.
Re: NC SK14
Check your overall length, too. Some of these designs need the bow pulled back to get the sides to flare properly.
- New Poster
Re: NC SK14
Well...removed the cords and spent several hours tightening and loosening zip ties and it is a little better, but I am still having a few issues. Had to stop because I was getting frustrated. The stern is fine...nice and level, the bow on the other hand....
Panel A is still not fitting right...I have a lot of space between it and the sides and bottom and the center of Panel A is to the port. I can make it fit better by physically lifting the bow, but then the sides flare out too far. I am already concerned that the starboard side is flared out much further than the port...
I am sure this is related to the unlevel bow, but I have no idea how to fix it. The stringers are also still not meeting the bottom...
I really thought I'd be a lot further along by now, but I don't want to start epoxying everything together only to find things don't fit right. I think if I can fix the bow everything else will fall into place. I checked the table, it is level. I have to think there is some torque being applied somewhere that is slightly twisting the bow, just don't know where or what to do next.
Re: NC SK14
Run a string from the center of the transom to the bow and make sure it is square to the transom. And to all of the center of the frames/panels. I am a little surprised you are having the trouble you are and wish the other builders of the SK14 builders would step in and help you. The hull looks good and fair, so not sure if that is your problem.
Re: NC SK14
Your not frustrated, you're just resting the plywood! I rested mine several times too I do remember one day having a bit of breakthru when I pressed the bottom down hard against the table. First do Tom's suggestion though.Pulling the nose down while holding the bottom flat may pull things in too. Keep fooling with it, no epoxy yet. As you said this latest effort looks considerably better so your getting there. Perfect is not important and I always call 3/8" home free.
Re: NC SK14
If you can ignore the hull panels for a bit, and focus on squaring up the frames and stringers, you will minimize the number of factors to deal with. In the picture from the bow on Friday, the frames look twisted. If you can sight down a string on the centerline, and align tops of all the frames with the level at the transom, at least the structure will be right.
Building right side up seems to add a challenge by not providing a means to align the frame, and then hold it there while the hull panes relax.
Don’t loose patience! The whole is assembly is finicky, and only right in one spot. You’ll get it. Save the epoxy for the day after you think you’ve got it right.
Good luck!
Good luck!
- New Poster
Re: NC SK14
Thanks Dan, Doug, and Tom. I needed a little encouragement and some advice. Checked the alignment between the bow and transom, and it was definitely off. When I unscrewed the port side, this is how it lined up:
Got that fixed and just kept fiddling with things. Wedged the whole thing up so it had a little more room to flex, put some pressure on it while tightening the zip ties and ended up in a good place, I think.
I played around with putting weight on the bow, and the gaps on the sides pretty much disappear. Any advice before I move to the next phase? Thanks again!
Re: NC SK14
Keep sweet talking her into place.
Is that the deck on the right? If so, it could pay off to temporarily zip tie it to the sides. It could provide some lift to the sides as well as forming the shape at the rub rail.
