jbo_c wrote: ↑Fri Jul 29, 2022 11:46 am
I can define a mil, but what does it really amount to.
Obviously, it’s not “fairing”. But what should you expect it to ‘fill’?
Maybe like “2.5 mils dry coat will fill scratches from ‘X’ grit sandpaper.” (Will it or should it be used to fill any weave at all?)
Or is that the wrong way to think about it?
Maybe another way to ask is: How do you know when to switch from fairing compound to primer?
I’ve never really tried to get anything other than a passable surface on anything.
Jbo
Each paint should specify how to prepare the surface on its TDS(Technical Data Sheet). The primer will tell you to sand with something like 80 grit or 120 grit. The topcoat will tell you to sand the primer with 240, 320, or 400 grit. Whatever grit the paint specifies just work your way up to that, your work with each grit should eliminate the deeper scratches from the grit before.
As an example here are the directions for painting epoxy coated surfaces with system 3 yacht primer:
https://cdn.shopify.com/s/files/1/1000/ ... 985314394
Epoxy resin‐coated surfaces: Some epoxy resin systems
leave an amine blush on the surface. Amine blush can
interfere with the adhesion of the SilverTip Yacht Primer.
Remove surface blush by using a Scotch‐Brite pad with
detergent and warm water. Then flush the surface with
fresh water.
1. Sand the epoxy surface with 100‐120 grit
paper.
2. Fill surface imperfections with SilverTip
Quikfair. Sand repair areas until smooth
using 100‐120 grit paper.
3. After sanding, vacuum or with clean, dry
shop air remove sanding dust.
4. Wipe the surface with denatured alcohol
and clean rags.
5. Apply SilverTip Yacht Primer with roller and
brush, or by spray application. At 70 degrees
SilverTip Yacht Primer can be recoated
without sanding in as little as 2‐3 hours.
After 72 hours, the SilverTip Yacht Primer
must be sanded, use 220‐320 grit paper.
Repeat steps 4‐5.
6. 2‐3 coats of SilverTip Yacht Primer are
necessary to achieve a smooth, uniform
surface.
7. After 24 hours @ 70 degrees, the SilverTip
Yacht Primer can be top coated. First sand
with 220‐320 grit paper. Repeat steps 3‐4.
