Page 1 of 2
Rod builders?
Posted: Sat Sep 03, 2022 10:11 am
by fallguy1000
Anyone build or reguide fishing rods? I want to learn.
Re: Rod builders?
Posted: Sat Sep 03, 2022 2:50 pm
by TomW1
Dan several guys were doing their own several years back, I will look and see if I can find them. Tom
Re: Rod builders?
Posted: Sat Sep 03, 2022 3:17 pm
by TomW1
Dan, it did not take me long to find the rod building section. cape man was a contributor and Mudhole.com was mentioned as a vendor. If you want to search rod builders in this topic. Tom
Re: Rod builders?
Posted: Sat Sep 03, 2022 3:19 pm
by cape man
Made about a dozen as gifts. Go to Mudhole.com
They have everything and tutorials. Cheaper to buy one but very satisfying to make your own. A friend just gave me one he made for me. I will cherish it for ever.
Re: Rod builders?
Posted: Sat Sep 03, 2022 3:25 pm
by cape man
He made it from a gaff blank with an awesome Afco butt that can be switched out. Had an antique 9.0 Penn that fits it perfect. 1000 yds of 100lb test braid on it.
Re: Rod builders?
Posted: Sat Sep 03, 2022 5:33 pm
by BarraMan
I went through a rod building phase 20 yrs ago. My son still uses a rod I built for him when he was 14 - he is now 36.
I stopped building rods when I realised I could buy a Loomis cheaper than I could build the eqivalent.
I have a very good book on the subject - will find it and post the title.
Re: Rod builders?
Posted: Sat Sep 03, 2022 7:23 pm
by fallguy1000
I bought a collection of 18 offshore rods. My favorite one of them is the only one needs repair.
Think it was his favorite, too.
Re: Rod builders?
Posted: Sat Sep 03, 2022 9:38 pm
by BarraMan
If you are interested in rod building, I would suggest:
The New Advanced Custom rod Building by Dale P Clemens, from Winchester Press.
Cheers
Lee
Re: Rod builders?
Posted: Sun Sep 04, 2022 1:58 am
I have a rod that needs one new eye. How do you tell what number/size to order?
Re: Rod builders?
Posted: Sun Sep 04, 2022 2:47 am
by BarraMan
Fuzz wrote: ↑Sun Sep 04, 2022 1:58 am
If the line guide doesn't have a ceramic insert, measure the inside diameter of the ring in mm. eg 25mm inside diameter of ring = size 25 guide
If the line guide does have a ceramic insert, measure the outside diameter of the ceramic insert in mm. eg 16mm outside diameter of ceramic ring = size 16 guide
