Pamet FS14
Re: Pamet FS14
If it makes you feel any better the kids here will take a shot at just about anyone. The good news is it is all in fun, we try very hard to keep it friendly and run off the butt-heads
Re: Pamet FS14
Thanks Fuzz! Everything about this effort to learn to build boats has been fun, fulfilling, and rewarding so far, especially this forum. My only concern is that my bad sense of humor will get me kicked out!
Re: Pamet FS14
Sorry, I was just ribbing you a little about your glasses being everywhere. I lose my on my head till I bump my head and they break. I have to wear glasses because I am far sighted in one eye and near sighted in the other and then have bifocals to read. But for boat building I use cheap reader glasses and buy them in different powers and even have a lighted magnify glass on an arm to see when I get splinters in my hands and fingers from the fine grain marine plywood.PametBW wrote: ↑Wed Sep 14, 2022 4:57 pmAh OrangeQuest, you're killing me. Of all my insecurities, not being able to see is the only one that I can afford to address. After reading your message, I counted 8 pairs scattered around my shop - not including the pair perched on the visor of my cap. Thanks for noticing, it is always nice to know that there is somebody looking out for me - even if it is for the purpose of abusing me...OrangeQuest wrote: ↑Wed Sep 14, 2022 3:46 pm Hmm? Are your reading glasses multiplying? One pair in one picture, 2 pair in another and then maybe 3 pair? You going to run out of sandpaper before you run out of reading glasses!
May want to stick with just one pair, before you are done, they will have epoxy on them.
Wait till your school age employees come to work and ask why you have a pair of glasses on top your head and wearing another pair. Hard to tell them because I lost one pair.
Re: Pamet FS14
It sounds like we are cut from the same cloth.
Don't worry about hurting my feelings, that requires a serious effort. My reply was a clear example of my twisted sense of humor - I buy cheap readers in packs of three for $9 a pack. I scatter them as Hansel and Gretel spread breadcrumbs and give them away freely to the bank, post office, and any wayward soul who visits the shop...
Re: Pamet FS14
Challenge accepted!
Re: Pamet FS14
Thanks OrangeQuest. I hope that your two coats of primer went well. Is this a boat you are building now and do you have a build thread?OrangeQuest wrote: ↑Wed Sep 14, 2022 1:28 pm When you fill in the gaps, use enough putty to bring everything up enough to sand and round over for the tape.
Now you know how fast the epoxy mix (putty) takes to kick, mix only enough for you to handle before you run out of time. Fill in the gaps and low spots quickly and come back to make it look neat once you get all the putty where it needs to be.
Really looking good and coming along nicely.
I put two coats of primer on my FS14 hull today.
Re: Pamet FS14
Filling the gaps seemed to go pretty well, up to a point...PametBW wrote: ↑Wed Sep 14, 2022 12:01 pm The spot welding seemed to go pretty well. I learned several things after struggling with the mix heating up and stiffening during the application process. Moving forward I will measure the volumes in cups but dump then onto a board (is this called a hawk?) for mixing to slow down the reaction. I thought using plastic bags for the application process was okay for the spot welding. I used the mixing sticks to move the putty around once it was in place.
Spot welding is not the perfect name because the process ultimately filled in most of the seams.
The gaps that are left are either where the stitches were or places that I had blue masking tape warning me about stringers or frames below. The next task is to fill in these gaps.
Unless someone has advice or other ideas I feel confident to take the next steps.
I see the steps for this process as:
1. Put tape below the stitch gaps (where I could not put tape earlier because the stitches were there) to support the wet putty.
2. Slide some plastic in places above the stringers/frames and below the gaps to prevent inadvertently gluing the panels to the frame.
3. Fill in the gaps with EZ Fillet (which I now know how to pronounce...)
Looking down the road, I expect to be preparing to tape the outside edges. I understand this to mean using putty to round the outside edges to a 1/2" radius. I am currently trying to visualize the steps, tools, and techniques that I will need...?
Thanks to all of you, I am very grateful for this forum.
The lesson that I learned is to begin at the keel and work outward and down. Another lesson learned the hard way, which seems to be my specialty.
I started with the bottom/side seams and the transom. Then I moved to the bow to work my way aft along the centerline. Of course reaching across the wet putty was pretty rough on the shirt that I was wearing. I don't have a good stool or platform to stand on and the putty was starting to harden by that time.
I decided to let it all harden overnight.
In the morning, I'll fill the gaps in the keel and build up the edges that are too square for the tape to lay smoothly.
On second thought, following the advice of this forum has given me evidence that I might be learning to do things the easy way. I have always wanted to learn from the mistakes of others instead of simply repeating them.
Thanks again!
Re: Pamet FS14
It may just be the way I'm reading what you are saying, but just in case . . . the way to achieve a rounded intersection that tape can lay over smoothly is to round the wood by whatever means you choose- sanding, rasping, routing. You are removing material, not building it up.
Your work is very neat and the fit of the panels is excellent. I'd assume you are going to get it right, but the above comment sounded odd!
Re: Pamet FS14
X2pee wee wrote: ↑Thu Sep 15, 2022 9:48 amIt may just be the way I'm reading what you are saying, but just in case . . . the way to achieve a rounded intersection that tape can lay over smoothly is to round the wood by whatever means you choose- sanding, rasping, routing. You are removing material, not building it up.
