MG20 questions befour start
Posted: Wed Sep 21, 2022 8:43 am
Hello, after many questions i have decided to build MG as a bass boat. I need to say that BarraMan and his enthusiasm was very convincing After downloading plans i started to study and making 3D model of bass boat layout. So I have fiew questions.
I would like to downscale , 90%. After scaling down, volum of hull will be way smaller, so is it possible to still use 250 hp engine or it will be dangerous becaus of overweight ? I would like to use jackplate so the height of transom after down should not be problem, im i thinking good ?
If this is going to be a fishing machine, there should be a lot of storage, i would like to have big central rod locker under the front deck, and two smaller on right and left side. The D bulkhead is reduced to minimum and it is under the sole, how much of C and B can be cut out ? May by "entrance" in bulkhead C could by cut all the way up to make a notch.
