Thinking what the best lightweight interior wall material will be for my shanty. The walls will be insulated, so I need a finished layer for the inside.
I’m thinking luaun doorskins(3mm, I believe) will be an inexpensive and acceptable option. I can install them with rosettes and wood screws so they’re removable later if there’s ever a need.
Think moisture would be an issue? This boat won’t live in the water, but it will be stored outside(under cover).
Other good options?
Thanks.
Jbo
Lightweight interior wall material
Re: Lightweight interior wall material
If your using sheet foam for insulation you might use a light S2 glass , cut the foam shy on the bottom and add weep holes to drain and ventilate
