GV11 - Vamouse
Posted: Sat Feb 03, 2024 11:03 pm
I was looking to build a tender for my sailboat (a J/120, a 40' racer/cruiser), and after going back and forth between a few boats, I settled on a GV10. So I went to the website and bought plans for a GV11 because bigger is better, right?
Here is Vamoose, the J120. Also where we came up with the idea of calling the dinghy Vamouse. Picture taken from the 45 lb. Minto dinghy I made, but we have outgrown.
Ordered plywood from a friend with a cabinet business and that came in on Jan 23rd. We couldn't find any good quality Okoume, so Aquatek it is. The rest of that day and the next were spent drawing lines, cutting wood out, and sanding them to final shape. Threw some epoxy on a few of the short pieces to make them long pieces. Heavy groceries keep things flat.
Once I had wood pieces, I put them together so they looked like a boat. Took about 4 hours to get it all stitched together and straight. I mixed some epoxy with some glass fibers and silica to hold the seams together while I flipped the boat to do inside seams.
I didn't get any pictures of doing the inside fillets and seams, because you've all seen that a brazillian times. Then I flipped it over and did the outside seams and a few reinforcement areas. I was going to leave it like this, but I can't convince myself that I shouldn't just glass the entire outside. I'm not going to be babying this thing, so I'll feel better to just glass the entire outside bottom.
But, before I decided to glass the entire bottom, I flipped it back over and started working on the seats. The plans call for a front seat and two small seats that sit athwartship. I decided that the extra weight of more seating would be worth it to me, so I started cutting some more wood. I'm not sure if I'll do a front seat or not at this point. I'm thinking yes, but the wife is thinking no.
I'll make under the seats storage and flotation. After this picture, I flipped it over and filleted and taped the bottom of the seat seams. Now my knees hurt.
That's where I am today. I have a 9.9 Suzuki coming on Monday. It might be a little less power than I would like, but it should be good enough. I'm struggling to come up with a good solution for a gunwale. I'd like something that adds stiffness to the boat, but also won't damage my sailboat's hull when climbing back and forth. Cotton rope? Something rubber? Not sure. Still figuring that out.
