Thought I'd share my SK14 build. I've been reading others posts and following along with some builds, and figured it was time to share my progress so far.
This will be my first boat, and I'm involving my two boys where and when I can. My goal is for it to be our father son project, and be able to fish off it together...while all three of us can still fit on it. I'm a hobbyist furniture/chair maker, and plan on using some of those skills in this project. I am a complete fiberglass/boatbuilding novice, and I am keen to learn some new skills along the way.
My build officially started on 16 Oct 2024, with a delivery of Okume ply from my local hardwood dealer. So far I've lofted the plans, stitched glued, and glassed the hull. A work trip took me to Switzerland for a week, and since I got back I've installed the stringers, frames, cleats, and started on the rubrail.
Next steps are to run conduit for my lights/fish finder, foam and install some wiring access hatches and cubbies.
My build plans for the skiff are:
- Rear sole mounted cubbies on either side of the transom supports, with internal conduit stub outs. On the back through the transom, I'm going to use some cable clam bulkhead passthroughs. The idea here is to allow my to have a transducer, and or alternator wire run through the transom
wall above the water line, into the watertight cubby, and have conduit to the front hatch fuse/switch box.
- Sole hatch mounted between the grab bar mounts, with internal conduit stub out in one of the grab bar feet. This will allow for future fish finder transducer/power runs through the conduit from the front hatch into the grab rail directly. The hatch will allow for ease of cable fishing from the conduit up into the grab rail.
- Front flush mounted LED red/green nav lights up front.
- Rear mounted telescoping anchor light, socket on top of rear cubbies to get the all around light above my head during use.
- LED courtesy light illuminating the sole from the back and the front, installed in the rear cubbies and the front step near the hatch.
- Tessilemare Radial 30 rubber rub rail.
- System 3 yacht/pennant primer
- Quantum 99 top coat
- Marine mat decking
