Hunch's XF20 Launched
Posted: Sat Dec 31, 2005 6:59 am
by Hunch
After 2 1/2 years my xf is ready for the water. I posted a few pics of her on the trailer. Hopefully I will get some decent shots of her on the water.
Everyone who has seen this boat is awestruck on the design. She looks like she will float on air.
News at 11
Posted: Sat Dec 31, 2005 10:16 am
by Randy
Looks sweet.
Plently of hatchs, is one of them a built-in live well?
You might get airborne withthat V-4 on the back of such a light boat, after seeing one running with a 35hp jet. No body will beat you to your favorite fishing hole.
Posted: Sat Dec 31, 2005 11:25 am
by gpratt
Good news Hunch! Looking forward to the report.
Posted: Sat Dec 31, 2005 5:30 pm
by FLYonWALL9
HUTCH,
Man really sweet looking boat. That topcoat should be very easy on your eyes, mine was just about the same color and stayed cool to the touch on the hottest of days.
On a sep note, would you have a picture of your braces under the gunwhales or a discription. Mine are going to be 10" or so and I have yet to figure out that part. Thanks for any help.
CONGRATS AGAIN!
Posted: Sat Dec 31, 2005 5:48 pm
by Hunch
Launched the old xf and christened her "Runamuck"
That 110 Jonnyrude is more than enuf power but between the 300 pound motor and the 65 pound Detwiller she still floats in 3" of water but without my fat ass in it and with the 35 live well empty.
She handles more like an air boat even with the keelson and 4 full length runners bolted to the bottom. Slippery as hell and windage at slow speeds coming to the docks is tricky.
The tunnel is raising a good size hump and is working fine.
I would say it is properly designed and proportioned right.
The Detwiller jack plate is an absolute failure. The lower cross bar catches the hump of water coming out of the tunnel when lowered all the way down. This cross bar at the lowest point rides about a inch or so above the tunnel. Forget about a good hole shot.
With the plate raised about 2" there seems to be clean water under the plate but it will cavitate badly above 4800 rpm. At 4800 my best guess at speed is 25+ A larger, deeper and cupped prop is in order. She should top out at 35+
She also cavitates in a turn at speed.
The water pressure is fine with the plate raised the full 6"
So I need to re-think this jack plate. I may attach a baffle that extends from under the plates bottom cross bar to the transom. This may prevent the leading edge from diggin into the hump.
The bar is the silver plate to the lower right of image.
If jury rigging the plate don't work its back to the drawing board. Perhaps a Bob's jack plate is in my future. The Detwiller is built like a tank and rated to 300 hp but it's not meant for tunnel boats.
The hull is a absolute dream to fish. Stable as rock. A very very dry ride. A little hull slap but not too bad. Jumped a few power boat wakes and she handled them well. I'm anxious to see how she will handle a steep chop in the bay when it kicks up. Should be a fine boat for Florida Bay once I iron out the prop and cavitation problems.
Posted a cpl more pics on the gallery
All in all it was a good sea trial and a good day
Tight lines.
Hunch
Posted: Sat Dec 31, 2005 6:21 pm
by Hunch
CONGRATS AGAIN!
The side gunwales braces are made up from 3/4" 1 1/4" mahogany on 12" centers. butt jointed, screwed and epoxied to a 3/8" x 1 1/2" white oak sheer clamp and 3/4" x 4" mahogany rail. Covered with 3/8" AC plywood and 8 OZ cloth as are all the decks. Epoxy coats all the plywood inside and out.
That top coat is Benjamin Moore Iron Clad. Oil base satin exterior enamel.
Good old metal paint has worked for me on all my fishun' scows.
Posted: Sat Dec 31, 2005 7:48 pm
by Mike Adams
Congratulations, Hunch - that is a really classy piece of work! You will be the envy of many a fisherman trying to stay steady in a less stable boat.
Mike
Posted: Sun Jan 01, 2006 1:22 am
by roob76
congrats on the boat man! she is a beauty!
poor fishies
you are gonna be terrorizing them florida bay reds!
by the way isn't that shot next to the dock in your gallery taken at gilberts in jewfish creek? i fish that area very often especially at night for snook!
Posted: Sun Jan 01, 2006 4:12 pm
by ks8
Great Job!
Some detail shots? And of course the pictures of some of the first catches to round out the thread!
ks
Posted: Sun Jan 01, 2006 7:13 pm
by Hunch
roob76 wrote:congrats on the boat man! she is a beauty!
poor fishies
YUp that's Gilbert's nasty ass ramp and dock. I used it to get to Lake Surprise to wring out the boat in calm waters.
You got a good eye.
Headin to Flamingo and Whitewater Bay tomorrow for some snook and trout. Hope I don't run outa gas. This thing is a pig.
News at eleven.
Posted: Sun Jan 01, 2006 8:00 pm
by chase
You might want to check to see if the ramp is open. I thought I read somewhere that only the freshwater side is open.
Posted: Tue Jan 03, 2006 12:17 pm
by Hunch
chase wrote:You might want to check to see if the ramp is open. I thought I read somewhere that only the freshwater side is open.
Whitewater Bay side ramp is open in Flamingo. No facilities, no bait, no gas. Ramp was packed.
Posted: Tue Jan 03, 2006 5:08 pm
by Steven
Looks nice, Hunch.
What color paint is that? Did you have them mix a color? I read the specs on the paint and it is self priming. Does it fill well, and can it be sanded between coats?
Thanks,
Steven
Posted: Tue Jan 03, 2006 5:56 pm
by Hunch
Steven wrote:Looks nice, Hunch.
Thanks,
Steven
The stuff is mixed #AC-7 is the Ben Moore number.
You can lay it on fairly thick and it does sand smooth with 220. If you want a super fine finish with no brush marks sand before the last coat with 220 and thin with spirits and Penetrol.
I would definately use a primer over epoxy. I used 2 coats Ben Moore M88 epoxy primer over the raw epoxy resin followed by 3 full coats of the Iron Clad.
My finish surface is durable not fancy. I didn't worry much about fairing all the whoops and dammits and brush marks with them gonna be covered over by all the fish blood and scratches from the mangroves.
Posted: Tue Jan 03, 2006 6:22 pm
by Steven
Thanks.
One more question. How much Primer and how much top coat did it take?
Posted: Tue Jan 03, 2006 6:29 pm
by Hunch
Steven wrote:Thanks.
1 gal kit primer and 6 qts top coat
