Serious help needed with epoxy
Posted: Wed Nov 25, 2009 12:40 am
by herocomplex
I'm building a D5, my first boat-building project, and I feel like I've read every post and how-to that there is on small boat stitch-and-glue. I'm extremely excited and I love this project but the whole epoxy thing is killing me. Seriously, I can't imagine how anyone can possibly use epoxy without it going nuclear in sort of reasonable amount of time. This stuff turns to stone before I can even figure out how to clean up my mistakes.
Full story: http://sagehobbs.com/index.php?option=c ... &Itemid=10
A few questions from a newbie:
  • -What is a reasonable sized batch of epoxy for a beginner?
    -Is a 3/4 cup batch really that sensitive?
    -Should I be spreading the epoxy out onto another container after mixing to maximize surface area and minimize heat?
    -Should I even be worrying about gluing in the frames? Perhaps fillets are ok.
Re: Serious help needed with epoxy
Posted: Wed Nov 25, 2009 3:36 am
by fmiles
Two questions:
* Have you inadvertently been supplied with RAPID hardner? You can get various 'speeds'.
* Can you use wider mixing pots? I found a source for these, and they are stronger, and can be used many times. Simply allow to cure, and with warm water, peel the unused epoxy out. The small plastic cups you have may be encouraging too much heat build up. I also found you need to be very careful with these cups, they have a coating that dissolves into the solution, and although it might not make any difference with epoxy, it really stuffed up my painting quality (loads of fisheyes)
Its odd the epoxy is kicking so fast.
Posted: Wed Nov 25, 2009 7:59 am
by rjezuit
Where are you located? What is the temperature at which you are working? Are you using slow, medium or fast hardener? It should not be kicking that fast if you are using the correct hardener. Rick
Posted: Wed Nov 25, 2009 10:04 am
by herocomplex
I am located in Arkansas and it was probably 50 to 55 degrees in my garage. The hardener is the medium speed from Bateau. I wanted to keep things as slow as possible since I have no experience. How long should I expect the reaction to take place under these conditions?
Posted: Wed Nov 25, 2009 10:06 am
by herocomplex
fmiles wrote:Two questions:
Unless the hardener is mis-labled, it's medium speed. I'll definitely switch to wider containers, these plastic cups are crap. As for a coating that dissolves, hell my entire cup dissolved. 8O
Posted: Wed Nov 25, 2009 10:12 am
Look here for the cure times.
Those are for a 3 oz. batch.
At 55 degrees, a 6 oz. batch of fast (half a cup) should have a pot life of at least 20 minutes, maybe more.
Medium should be slower.
Even if it was mislabeled, the fast should not kick that fast.
We will test the resin from that batch but I don't think that is the problem.
Posted: Wed Nov 25, 2009 10:31 am
BTW, what is your name?
Email orders@e-boat.net that way I can track your shipment and test the resin.
We have sold a good amount of medium lately and nobody else reported problems but I still want to check.
We rarely sell fast. It happens so rarely that our warehouse guy does not even label it.
The small amount we have sits on a shelf far away from the slow and medium hardener so there is no possibility of mix up there.
Can you do a test with a 3 oz. batch, write down the temperature and tell us when it begins to gel?
Update: I did read your blog once more and see some problems:
You mixed two cups of resin, used one for glue and let the other one sit there.
Don't. Mix the resin just when you need it.
You installed a frame, had a problem with a bad brush . . . all that takes easily 40 minutes and in that time, the resin waiting for you has cured. That's normal.
Solution: mix only what you need, like 6 oz. at a time.
Posted: Wed Nov 25, 2009 11:06 am
by herocomplex
jacquesmm wrote:BTW, what is your name?
Thanks for the reply Jacques. Like I said, I have no prior experience, so things feel like they happen incredibly fast. I simply have no baseline for comparison for how much time I should expect to have before things go nuclear. It really feels as if the medium hardener, at 55 degrees F, had less than 30 minutes before it was unworkable. My perception of time could have been off due to the stressful situation, though. Also, this was in a plastic dixie cup with little surface area. I'll do a test tonight to get real data. I'm sure that the problem is with my technique...I need to do a bit more research on working with epoxy. As it is, I can't imagine how I could even fiberglass the seams inside a single bulkhead
Posted: Wed Nov 25, 2009 11:13 am
by chrisobee
herocomplex wrote:Thanks for the reply Jacques. Like I said, I have no prior experience, so things feel like they happen incredibly fast. I simply have no baseline for comparison for how much time I should expect to have before things go nuclear. It really felt as if the medium hardener, at 55 degrees F, had less than 30 minutes before it was unworkable. My perception of time could have been off due to the stressful situation, though. Also, this was in a plastic dixie cup with little surface area. I'll do a test tonight to get real data. I'm sure that the problem is with my technique...I need to do a bit more research on working with epoxy.
I've done most of the epoxy work on my CV16 using 3oz batches. The smaller the batches the longer the pot life. 20 minutes is probably a resonable expectation for the amount of time that you have to apply the epoxy that you have mixed. The cadence goes someting like this:
1. mix up 3 oz of epoxy and precoat all the surfaces and edges . use any left over on the big surfaces of the panels.
2. mix up 3 oz of epoxy add wood flour to make glue ( catsup consistency ) use anywhere you need glue.
3. Add more wood flour and silica for fillets to the glue that you made earlier to use up an excess glue.
4. mix up 3 oz of epoxy add wood four and silica for fillets. Use left over for filling an gaping divots of which you are not proud.
5. cut fiberglass tape to size for all filleted seams.
6. Set the tape down on the still tacky epoxy precoated seams.
7. mix up 3 oz of epxoy and wet out tape. Smooth the fillets by running your gloved finger down the lenght of the taped and filleted seam. (very gentle pressure)
Work quick, work clean, plan on only doing what you can do in 15 minute blocks.
Posted: Wed Nov 25, 2009 11:18 am
BTW, use sturdier cups and also, if it feels too fast, you can, as somebody else proposed, spread the mixed resin in a tray.
Keep going with small batches at first, 3 oz, as Chrisobee propose is fine and as you get comfortable, increase the size if needed.
BTW, the cure time in the pot is different from the open time on the part.
Once the epoxy is spread on the part either as glue or fillet, you can work with it for a much longer time.
This means that you can install a bulkhead with 2 or 3 small batches.
Another trick is to put your resin jugs in the fridge but I don;t think that's necessary.
Try the small batches.
Posted: Wed Nov 25, 2009 11:32 am
by herocomplex
Thanks everyone, you've got me seriously re-thinking my methodology. Chrisobee's tips will definitely help set me straight!
Posted: Wed Nov 25, 2009 1:40 pm
by steve292
I agree with the others, your batches are to big for your experience. don't mix any epoxy until you are sure everything fits where it should, & all your tape is precut. I did dry runs on my frames before applying epoxy, to make sure my plan worked until I was a bit more sure of myself. You need to have everything to hand including some glove changes, spare rollers,brushes ect, it's no good them being in the cupboard :roll: .
Posted: Wed Nov 25, 2009 3:25 pm
by JamesT
i agree with everyone, i currently am working on my first boat, and have yet to have a single batch of epoxy go off on me.
Just have everything laid out...cups, gloves, mixing sticks, wood.....you get the idea.
Think ahead...if you have a small glue up job left, think about where you'd put the excess. All my batches have been small batches...not preaching just throwing in my 2 cents.
Also, pay attention and mix thoroughly, i didnt on one of my batches and had to use a heat gun to get it to cure out.
Live and learn.
Happy thanksgiving to everyone!
Posted: Fri Nov 27, 2009 2:36 pm
by herocomplex
I just wanted to thank everyone for their help. After following the tips and guidelines, my most recent epoxy attempt went swimmingly. Small batches put on the boat ASAP, and then I had more that enough time!
Posted: Fri Nov 27, 2009 6:43 pm
by chrisobee
herocomplex wrote:I just wanted to thank everyone for their help. After following the tips and guidelines, my most recent epoxy attempt went swimmingly. Small batches put on the boat ASAP, and then I had more that enough time!
Outstanding. Great news. Now the next challange will be to post pictures. :D
Posted: Mon Nov 30, 2009 3:05 pm
by herocomplex
Actually chrisobee, I've posted quite a few pictures in the gallery and I've been blogging the construction at http://sagehobbs.com. I probably need to link photos in a post for the old farts, though. :D
Posted: Mon Nov 30, 2009 6:38 pm
by chrisobee
herocomplex wrote:Actually chrisobee, I've posted quite a few pictures in the gallery and I've been blogging the construction at http://sagehobbs.com. I probably need to link photos in a post for the old farts, though. :D
Harsh man... harsh. Ok... I'm one with my inner old fart. Now start a build thread and feed the old farts what they need! :P
